Using ESD Resin
Static electricity is a challenge for the manufacturing industry. Materials that build up static electricity can discharge when close to conductive materials, damaging electronics and other sensitive components.
alttext
Most plastics, including Formlabs resins, are insulators that may build up static electricity and discharge it when they come into contact with conductive materials. Formlabs ESD Resin safely dissipates static buildup that can damage sensitive electronics, making it ideal for producing robust custom parts that comply with ESD safety standards.
Ensure ESD Resin parts are properly grounded to prevent damage to components they may come into contact with. Use materials like ESD mats or grounding cables to allow static charges to safely dissipate.
ESD Resin prints at 50 microns and 100 microns.
Note:
To learn more about the performance or specific material properties of ESD Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
Surface resistivity measures the resistance to current running along the surface of a material. The higher the resistivity, the less conductive the material. ESD Resin is more conductive than other Formlabs resins, allowing electric charges to flow in a controlled manner.
alttext
See the table below for a comparison of relevant material properties:
 ESD ResinTough 2000 Resin
Surface resistivity (ohm/cm2)105 - 108> 1012
Ultimate tensile strength (MPa)4446
Tensile modulus (GPa)19372140
Elongation at break (%)1245
Izod Impact strength (J/m)2640
Heat deflection temperature (HDT) @ 1.8 MPa54.262.0
Heat deflection temperature (HDT) HDT @ 0.45 MPa (°C)62.253
To learn more about the performance properties of Formlabs resins, refer to the library of material properties data sheets.
Printing with ESD Resin
  • ESD Resin is conductive in its liquid state and should be handled carefully to avoid contact with any electrical components, especially those inside the printer. Promptly clean and inspect the printer after a resin spill to minimize any damage to the printer. Monitor the printer closely if ESD Resin has reached the inside of the printer, as it may present a smoking hazard.
  • To avoid damage to equipment, check the resin tank compatibility table in Choosing the right material to confirm you are using a resin tank that is compatible with this material.
  1. Open a model.
  3. Orient to preserve fine details.
  4. Generate supports.
Before printing, ensure ESD Resin is mixed thoroughly for best results. Shake the resin cartridge and stir the resin in the tank with the wiper or a spatula with rounded corners. Mix new resin cartridges and any ESD Resin stored in the cartridge or tank after several weeks.
Finishing
The Form Wash agitates the solvent bath and removes parts from the bath after a set time. Wash parts according to the support article Form Wash time settings.
Use a separate wash bucket to prevent ESD Resin from transferring to other parts.
Post-curing requirements
ESD Resin requires post-curing to reach its optimal mechanical properties.
Refer to the support article Form Cure time and temperature settings for post-curing recommendations.
