What should I use to clean my Formlabs SLA printer?
Keep your Formlabs SLA printer clean to ensure maximum functionality over the life of the printer. Clean the printer with the appropriate substance, depending on what the component is made of. Check the chart below to learn about compatibility of cleaning substances with different components of Formlabs SLA printers.
Check the chart below to learn about compatibility of cleaning substances with different components of your printer.
  • A (check mark) indicates compatibility
  • A (cross mark) indicates incompatibility
IPA Novus 1 Soap and water Lens cleaning wipes or PEC*PADs Paper towel
Orange cover and shell
(Form 2 printers only)
Form 3/3L resin tank interior
Form 4/4L resin tank interior
Optical surfaces (glass optical window, LPU)
Resin tank exterior
Resin tank frame
Finish Kit components
Caution:
When cleaning the resin tank interior, do not use IPA or other cleaning solvents. Using cleaning solvents to clean the resin tank interior can cause damage to the flexible film leading to resin spills and print failures. Clean the resin tank interior using the tank tool or plastic scraper. For more information, see additional resources below.
Additional resources
