Printing with an improperly assembled Build Platform 2L can damage the build platform, your resin tank, or your printer.
The Build Platform 2L enables a quick and controlled release of printed parts from the build platform, allowing for an easier and more reliable post-processing workflow.
When using the Build Platform 2L, make sure that both the build platform and your models are properly prepared before printing. Ensure that the build platform is clean and properly assembled. Certain part orientations and support options release more easily from the build platform than others, so set up your print with this in mind.
For the best print results:
The Build Platform 2L is made of two components: the build platform body and the print surface. The print surface is attached to the build platform body with magnets positioned within the alignment channels and throughout the top surface of the build platform body. The print surface bends when you push the part release paddles inwards, causing printed parts to release for easier post-processing.
Printing with Formlabs resins
Inspecting the print surface
Before printing with the Build Platform 2L:
Preparing your models in PreForm
Step 1: Orient models perpendicular to the front of the build platform
Align the long edge of the models perpendicular to the bend axis of the build platform so that parts are more likely to release. Place models perpendicular to the front of the build scene for easy part removal as the surface flexes.
Step 2: Overlap support rafts on smaller parts
Parts that are three centimeters at their longest point may be too small to completely release from the build platform when the surface flexes. Place these models close together in PreForm so that their rafts overlap and create a larger surface area. If you are using the automatic layout tools in PreForm, check the Overlap Rafts box in the Layout window.
Note:
Avoid using mini-rafts with the Build Platform 2L. The surface area on mini-rafts is too small to release from the print surface when it bends.
Step 3: Print parts with large flat surfaces directly on the build platform
Printing parts directly on the build platform can reduce print time and resin consumption, as well as simplifying post-processing steps.
Removing parts from the Build Platform 2L
Warning:
Wear gloves when handling printed parts and surfaces that are contaminated with solvent or liquid resin to prevent skin contact.
Caution:
Do not point the print surface of the Build Platform 2L toward your face. Flying parts or debris may lead to injury.
The Build Platform 2L’s print surface bends, releasing printed parts for post-processing. Released parts may separate entirely from the build platform or remain partially adhered due to liquid resin, allowing them to be removed by hand.
Remove the build platform from the printer and wash the attached parts using your solvent of choice.
For large or fragile parts:
If parts remain on the build platform, use a part removal tool or scraper to manually remove them or pull them off with a gloved hand.
Clean the print surface if you plan to print again with the same resin, or thoroughly clean the entire Build Platform 2L to completely remove all traces of resin before printing with a different material.
Store the build platform inside the printer or somewhere out of direct sunlight.
Other removal methods may be effective, depending on your part geometry. Experiment to find the method that works best for your parts and your workflow.
Troubleshooting with the Build Platform 2L
Non-adherence
When printing solid rectangular parts, the print surface may flex or decouple due to the internal stresses of the printing process. If this occurs, do not print the part directly on the build platform. Add support rafts to prevent the part from decoupling from the Build Platform 2L during the printing process.
Warped parts
Printing large parts directly on the build platform surface near the short edges may cause warping. If this occurs, do not print the part directly on the build platform. Add support rafts and reorient the part to prevent warping.
Mixer decoupling
The Build Platform 2L print surface attaches to the build platform body using magnets positioned within the alignment channels and throughout the surface of the build platform body.
If the printer experiences a Mixer Error due to a high volume of resin or particularly viscous resins like Rigid 10K or BioMed Clear, the magnets in the build platform may pick up the decoupled mixer. The printer pauses the print when this happens and displays an error message.
If the printer experiences mixer decoupling when printing with the Build Platform 2L, follow these steps:
Do not use the part removal tool, scraper, flush cutters, or any other metal tool to inspect the resin tank or remove cured resin from the tank. These tools may damage the tank film, leading to failed prints or resin spills.
If the mixer moves incorrectly or erratically, or fails to park, be sure that you are inserting the mixer correctly: magnet side down, with the arms pointing to the right. If the arms or magnets are damaged or missing, the mixer may not move properly.
