BEGO™ VarseoSmile® TriniQ® Resin is a ceramic-filled material for highly accurate permanent restorative parts, provisional restorative parts, and denture teeth. Use this resin to create precisely fitting permanent single-unit restorations (crowns, inlays, onlays, implant-supported crowns) or up to three-unit bridges with accurate marginal adaptation. This resin can also be used to create provisional single-unit restorations, up to seven-unit provisional bridges, and denture teeth for full or partial removable dentures.
As a Formlabs Certified Material, BEGO™ VarseoSmile® TriniQ® Resin is fully compatible with the Form 4B automated resin dispensing system, the PreForm Dental workspace, and other aspects of the Formlabs ecosystem.
This resin is available in three commonly used VITA shades: A2, A3, and B1.
