Using BioMed Amber Resin
BioMed Amber Resin is a rigid material for biocompatible applications requiring long-term topical skin or short-term mucosal membrane contact. BioMed Amber Resin can be sterilized by autoclave, E-beam, gamma, and ethylene oxide.
alt text
Note:
To learn more about the performance or specific material properties of BioMed Amber Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
 BioMed Black ResinBioMed White ResinBioMed Clear ResinBioMed Amber Resin
Can be sterilized✔✔✔✔
Transparent  ✔✔
Can be polished✔✔✔✔
Compatible with Form 2✔✔✔✔
Compatible with Form 3B/3B+//3BL✔✔✔✔
CertificationsUSP Class VI
ISO 10993-5, -10,-23
USP Class VI
USP <151> Pyrogen + ISO 10993-11 Acute systemic Toxicity Testing
USP Class VI
ISO 18562-1,-2,-3,-4
ISO 13485
Layer thickness50 microns
100 microns
50 microns
100 microns
50 microns
100 microns
50 microns
100 microns
Ultimate tensile strength (MPa)35.745.85273
Tensile modulus (GPa)1.52.02.12.9
Elongation at break (%)14101212.3
Flexural modulus (GPa)1.72.02.32.5
IZOD Impact strength (J/m)24.815.13528
Heat deflection temperature (HDT) @ 1.8 MPa49.452.45465
Heat deflection temperature (HDT) HDT @ 0.45 MPa (°C)68676778
Required resources
Made by Formlabs:
Printing with BioMed Amber Resin
For full compliance and biocompatibility, BioMed Amber Resin requires a dedicated resin tank, build platform, and Finish Kit which should not be used with any other resins.
  1. Open a model.
  3. Orient to preserve fine details.
  4. Generate supports.
Shake the BioMed Amber Resin cartridge for 5 minutes to ensure the resin is mixed completely. Insert the cartridge along with a resin tank and build platform, and start the print.
Washing
Follow the part washing recommendations in the manufacturing guide for the clearest and best possible results. Improper washing can lead to suboptimal mechanical and biocompatibility properties.
Post-curing requirements
Follow the post-curing recommendations in the manufacturing guide for the clearest and best possible results. Improper post-curing can lead to suboptimal mechanical and biocompatibility properties.
Additional resources
