Note:
The following detailed settings comparison and guidance applies only to Fuse 1+ 30W printers. Fuse 1 guidance is given where applicable but is more limited.
Formlabs conducts extensive validation of new print settings before releasing on PreForm. All settings are validated to Formlabs recommended refresh rates.
Note:
Nylon 12
Fuse 1+ 30W
| Setting | Reason for use |
| Balanced (v6.1) | This print settings optimizes for the best surface finish, print reliability, and accuracy. |
| Speed Optimized (v5.3) | Recommended for default use. Offers best printing speed and part quality. |
| Legacy (v2.2) | Customers who developed specific printing parameters and wish to continue using the same printing profile. |
| Legacy (v4.1) | This setting was previously the default setting for customers, offering a good balance of performance metrics. Customers who have a fixed set of printing parameters and can achieve desired results with this setting may continue to use it. |
Fuse 1
| Default (v2.0) | Recommended for default use. Offers best printing speed and part quality. |
| Beta (v3.0) | Customers who are looking to mitigate layer shift issues. |
Detailed comparison of settings in PreForm
| Balanced (v6.1) | Speed Optimized (v5.3) | Legacy (v4.1) | Legacy (v2.2) | |
| Dimpling | Best | Best | Good | Best |
| Z-direction warping | Best | Best | Fair | Good |
| Fine feature resolution | Best | Good | Good | Fair |
| Z accuracy | Best | Best | Fair | Good |
| Birchbark/orange peel | Best | Best | Fair | Good |
| Print speed | Good | Best | Good | Good |
| Layer shifting1 | Best | Best | Best | Good |
| Print success | Best | Good | Good | Good |
1 For Fuse 1 printers, use Beta v3.0 print settings or later to mitigate layer shifting.
Details on Speed Optimized v5.3 and Balanced v6.1 settings
Both v5.3 and v6.1 settings provide the overall best printing experience with Nylon 12 Powder on Fuse 1 generation printers. Speed Optimized v5.3 prioritizes printing speed, while Balanced v6.1 prioritizes print completion. We recommend using Balanced v6.1 if minimizing print speed is not a major concern.
The following notes from the v5.3 release still apply to both the Speed Optimized v5.3 and Balanced v6.1 settings:
Z-axis warping and accuracy
Speed Optimized v5.3 and Balanced v6.1 settings setting significantly reduce the warping that occurs on long parts oriented along the Z-axis. Using either of these settings, warping is reduced by upwards of 50% to previous settings. As a result, the maximum part height when printing with this setting is 294.1 mm, approximately 1.4 mm shorter than previous print settings.
Surface dimpling
The rate of dimpling on parts printed with Speed Optimized v5.3 or Balanced v6.1 is comparable to that of Legacy v4.1, with no significant differences. Tuning the printer’s bed temperature helps reduce the likelihood of dimpling, but some geometries are still more susceptible to dimpling, particularly spheres. If your parts are more prone to dimpling, contact Formlabs Support for more advanced troubleshooting support.
Print speed
The Speed Optimized v5.3 setting is expected to be 14% faster than the new Balanced v6.1 setting, but with a higher likelihood of print interruptions due to powder dosing issues.
Print cooldown
Formlabs recommends the same cooldown period for both Speed Optimized v5.3 and Balanced v6.1. This is twice the cooldown time of Legacy v4.1 settings. This cooldown can happen outside the printer, freeing it up for the next print.
Due to the increased efficiency and fast print speed of Speed Optimized v5.3 settings, the powder cake will remain noticeably hotter after cooling for the same amount of time as parts printed with other settings. Take extra caution when unpacking parts, and refer to published print cooldown times in PreForm as a helpful guide for when your parts can be unpacked. Premature unpacking can cause parts to warp.
Downloadable FPS files for deprecated print settings
The settings listed below were released previously but are no longer recommended for use due to subsequent improvements. However, the settings are available here as downloadable FPS files for customers whose workflows may require them. After downloading, import the print setting into PreForm with the Print Settings Editor to set up a print.
Nylon 12 GF
Fuse 1+ 30W
| Default (v1.1) | Recommended for default use. Offers best printing speed and part quality. |
Fuse 1
| Default (v2.1) | Recommended for default use. Offers best printing speed and part quality. |
| Legacy (v1.1) | Customers who have developed specific printing profiles. |
Nylon 12 Tough
Nylon 12 White
| Default (v1.1) | Recommended for default use. Offers best printing speed and part quality, with best fine feature resolution. |
| Legacy (v1.0) | Customers who developed specific printing parameters and wish to continue using the same printing profile. |
| Default (v1.1) | Legacy (v1.0) | |
| Thin feature strength | Best | Fair |
| Surface roughness | Best | Good |
| Birchbark/orange peel | Good | Best |
| Print speed | Best | Best |
| Layer shifting | Best | Best |
Nylon 11
Fuse 1+ 30W
| Default (v2.1) | Recommended to be used as the default setting, with best surface quality and fastest printing speed. |
| Legacy (v1.2) | Customers who have developed specific printing profiles or are printing on Fuse 1. |
Fuse 1
| Default (v1.1) | Recommended to be used as the default setting. |
| Default (v2.1) | Legacy (v1.2) | |
| Vertical surface finish | Best | Fair |
| Fine feature resolution | Best | Best |
| Part depowdering | Good | Best |
| Z accuracy | Best | Good |
| Mechanical properties | Best | Good |
| Print speed | Best | Good |
Details on Default v2.1 settings
Bed Temperature Offset
Customers who had previously applied a bed temperature offset to their printers should remove it and reset the printer back to nominal bed temperature prior to printing with the Default v2.1 settings. After printing with the Default setting, customers can work with Formlabs Services to modify the bed temperature if needed based on part quality. A previously-set bed temperature offset used on a different set of settings is not applicable when printing with Default v2.1 settings.
Part depowdering
You may notice harder Surface Armor more frequently than on the Legacy v1.2 settings. To resolve this, first try reducing the bed temperature of the printer. If issues persist, reduce armor exposure by modifying the Armor Laser Power parameter using the Print Settings Editor. Reduce the value in 10% increments, testing between each change.
Recoater artifacts
Due to the faster printing speed of Default v2.1, you may notice more print-related debris around the build chamber. Vacuum the print enclosure and around the top of the build chamber between each print. Otherwise, the debris may be dragged across the print plane by the recoater, causing print defects or errors.
Nylon 11 CF
| Default (v1.2) | Recommended to be used as the default setting, with best surface quality and fastest printing speed. |
The new Nylon 11 CF Default v1.2 setting addresses part warping and accuracy in the Z direction and poor finish on vertical surfaces. When using these print settings, you should expect to print more accurate parts with fewer instances of poor vertical surface finish.
TPU 90A
Fuse 1+ 30W
| Default (v2.1) | Recommended to be used as the default setting, with best fine features, best accuracy, and fastest printing speed. |
Fuse 1
