Tip:
- Hold Shift to snap to mesh vertices for accuracy.
- The measurement stays active and updates as you translate or rotate a model.
- Press Tab to cycle between selected models without clicking and starting a new measurement.
Starting with PreForm version 3.53.0, you can measure distances between points on a model or between two models within PreForm. Use this tool to measure feature dimensions, check part spacing, and more.
To measure distances in PreForm:
Tip:
