PreForm downloads and release notes
This article summarizes the changes for each version of PreForm, the print preparation software. Review the firmware release notes to learn more about the improvements that come with each firmware release.
Latest versions
The latest PreForm version can always be downloaded from formlabs.com/software.
Version numberRelease dateWindowsMac
PreForm 3.57.2March 31, 2026 Link Link
Note:
The latest version of PreForm compatible with the Form 1+ is PreForm 2.20.0 (released March 12, 2019):
The latest compatible version of PreForm for computers running on a 32-bit operating system is PreForm 2.16.0:
2025/2026 releases
Previous versions of PreForm are available for download, as well as a list of their associated changes.
PreForm 3.57.2 — March 31, 2026
This release updates the print settings for Tough 1000 Resin V1 and Tough 2000 Resin V2 at 100 microns for Form 4L generation printers.
Windows Download: Link
Mac Download: Link
  • Print settings updates:
    • Promoted the Supports V1 print setting to Default (V2.0) for Tough 2000 Resin V2 at 100 microns for Form 4L generation printers. The previous Default (V1.1) print setting has been renamed to Supports V2.
    • Promoted the Supports V1 print setting to Default (V2.0) for Tough 1000 Resin V1 at 100 microns for Form 4L generation printers. The previous Default (V1.1) print setting has been renamed to Supports V2.
PreForm 3.57.1 — March 24, 2026
This release fixes bugs related to Windows auto-update preferences and the Hole tool.
Mac Download: Link
  • Bug fixes:
    • Fixed issue where auto-update preferences were not saved for Windows users
    • Fixed issue where deleting drilled holes crashed PreForm
PreForm 3.57.0 — March 18, 2026
This release introduces user controls that can enhance print accuracy on SLA and SLS platforms, as well as a variety of bug fixes and print settings updates.
Mac Download: Link
  • New features:
    • Minimum Layer Time (Fuse 1 generation): Set a minimum time to have more consistent layer times and control thermal build-up, simplifying print process development for third-party materials through Open Material Mode. Minimum Layer Time is accessible from the Print Settings Editor.
    • Z-Bleed Compensation enhancements (Form 4 and Form 4L generation): Updated implementation to protect large overhangs while still improving print accuracy on bottom-facing surfaces and threads. Z-Bleed Compensation is accessible from the Print Settings Editor.
    • Promoted Reduced Support Density print setting (V2.0) to Default for Tough 2000 Resin V2 at 100 microns for Form 4 generation printers. The previous Default print setting (V1.1) has been renamed to Supports V2.
    • Promoted Reduced Support Density print setting (V2.0) to Default for Tough 1000 Resin V1 at 100 microns for Form 4 generation printers. The previous Default print setting (V1.0) has been renamed to Supports V2.
    • Promoted the Beta print setting to Default (V1.0) for Tough 2000 V2 Resin at 50 microns for Form 4L generation printers.
    • Updated Default print setting (V1.1) for Tough 2000 Resin V2 at 50 microns for Form 4 generation printers to reduce support density.
    • Updated Default print setting (V1.1) for Tough 2000 Resin V2 at 100 microns for Form 4L generation printers to reduce support density.
    • New Supports V1 Beta print setting (V2.0) for Tough 2000 Resin V2 at 100 microns for Form 4L generation printers. This setting uses fewer and larger touchpoints compared to the Default setting.
    • New Supports V1 Beta print setting (V2.0) for Tough 1000 Resin V1 at 100 microns for Form 4L generation printers. This setting uses fewer and larger touchpoints compared to the Default setting.
    • New Beta print setting (V3.0) for Nylon 12 GF Powder for Fuse 1+ 30W printers.
  • Bug fixes:
    • Fixed issue where importing some .fps files would crash PreForm
    • Fixed issue where the Texture tool used the original model height, limiting where textures are applied
    • Fixed issue where PreForm underestimated total powder usage for a job (Fuse 1 generation)
    • Fixed an issue that caused crashes for some users
PreForm 3.56.2 — March 5, 2026
This release contains various bug fixes and an update to print setting options for Tough 2000 V2 Resin at 100 microns for Form 4 generation printers.
Mac Download: Link
    • New Default print setting (V1.0) for Tough 1000 V1 Resin at 50 microns for Form 4L generation printers
    • New Beta print setting (V1.0) for Tough 2000 V2 Resin at 50 microns for Form 4L generation printers
    • Corrected setting name for Default print setting for Tough 1000 V1 resin at 50 microns for Form 4 generation printers
  • Bug fixes:
    • Stability improvements
PreForm 3.56.1 — February 26, 2026
Mac Download: Link
    • Removed the Reduced Support Density preset support option for Tough 2000 V2 Resin at 100 microns for Form 4 generation printers due to redundancy with the Default setting.
  • Bug fixes:
    • Resolved an issue where Form 3B+ printers were not appearing in the printer list.
    • Fixed a problem causing the Layout tools to malfunction for Form 3/3B/3+/3B+ printers.
    • Addressed a bug in the Print Settings Editor (PSE) where fields containing arrays were disappearing.
PreForm 3.56.0 — February 24, 2026
This release updates the system requirements for macOS. It also introduces new print settings for Tough 1500 Resin V2 on Form 4L generation printers and for Tough 1000 Resin, Tough 1500 Resin V2, and Tough 2000 Resin V2 on Form 4 generation printers.
Mac Download: Link
  • Announcements:
    • This version of PreForm has updated system requirements for macOS. You now require macOS 13 or higher. There has been no change for Windows. Some macOS users may encounter an increased load time during the first application launch following the update. This is a one-time initialization process; standard startup performance will resume thereafter.
    • New Reduced Support Density print setting (V2.0) for Tough 2000 Resin V2 at 100 microns for Form 4 generation printers. This setting uses fewer and larger touchpoints compared to the Default setting.
    • New Reduced Support Density print setting (V2.0) for Tough 1000 Resin V1 at 100 microns for Form 4 generation printers. This setting uses fewer and larger touchpoints compared to the Default setting.
    • New Supports V2 print setting (V2.0) for Tough 1500 Resin V2 at 100 microns for Form 4 generation printers. This setting uses smaller and denser touchpoint sizes compared to the Default setting that make support removal easier while improving surface finish and part accuracy.
    • New Supports V2 print setting (V2.0) for Tough 1500 Resin V2 at 100 microns for Form 4L generation printers. This setting uses smaller and denser touchpoint sizes compared to the Default setting that make support removal easier while improving surface finish and part accuracy.
    • Updated Default print setting (V1.1) for Tough 2000 Resin V2 at 100 microns for Form 4 generation printers to reduce support density.
  • Bug fixes:
    • Several bug fixes and usability improvements to the new Supports panel
PreForm 3.55.1 — January 28, 2026
This release introduces new print settings for Tough 1000 Resin V1 on Form 4 and Form 4L generation printers, as well as several bug fixes.
Mac Download: Link
  • Bug fixes:
    • Fixed crash when switching between remote and local printers
    • Fixed issues with printer USB connectivity due to Another version of PreForm is using this printer and/or Unavailable Printer Detected errors
    • Fixed missing Download logs button in the Accessories dialog
    • New Default print setting (V1.0) for Tough 1000 Resin V1 at 50 microns for Form 4 generation printers
    • Updated Default print setting (V1.1) for Tough 1000 V1 at 100 microns for Form 4L generation printers with a minor accuracy improvement
PreForm 3.55.0 — January 13, 2026
This release introduces a new Print Settings Editor parameter for Form 4 and Form 4L generation printers and a variety of new Supports V2-based Reduced Density presets.
Mac Download: Link
  • New features:
    • Z-Bleed Compensation: Print fine features like threads and overhangs with increased precision. Available as a setting in the Print Settings Editor (Form 4 and Form 4L generation only).
  • Bug fixes:
    • Fixed issue where the model Replace function would fail on subsequent attempts.
    • Fixed issue where some FORM files with models imported from CAD could not be opened after adding part cages in PreForm 3.54.
    • Fixed bug where the Print Settings Editor would crash when deleting a setting.
    • New Supports V2-based Reduced Density (Alpha) presets:
Form 4 generation
MaterialLayer Thickness (microns)
Black Resin V525, 50, 100
Clear Resin V525, 50, 100
Grey Resin V525, 50, 100
White Resin V550, 100
Tough 1000 Resin V1100
Tough 1500 Resin V250, 100
Tough 2000 Resin V2100
Tough 2000 Resin V1.150, 100
Form 4L generation
Grey Resin V525, 50, 100, 150
PreForm 3.54.1 — December 9, 2025
This release introduces new print settings for Tough 1000 Resin V1 on Form 4L generation printers and Tough 200 Resin V2 on Form 4 generation printers. It also includes a firmware update for Form Cure V2 and Form Cure L V2.
Mac Download: Link
  • Announcements:
    • Formlabs will be sunsetting the following materials effective Sunday, March 1, 2026:
      • Temporary CB Resin V1
      • Permanent Crown Resin V1
      • Castable Wax 40 Resin V1
    • PreForm displays an end-of-life notice in the Job Setup screen if you select one of these resins.
    • See our article on material formulation updates for more information.
    • New Default print setting (V1.0) for Tough 1000 Resin V1 at 100 microns for Form 4L generation printers
    • New Default print setting (V1.0) for Tough 2000 Resin V2 at 50 microns for Form 4 generation printers
  • Accessory firmware updates
    • New Low Warp setting for Tough 2000 Resin V2 for the Form Cure V2 and Form Cure L V2
PreForm 3.54.0 — November 18, 2025
This release introduces a new measurement tool, improved scene viewing controls, and model grouping for SLA. It also introduces several new SLA Print Settings Editor parameters.
Mac Download: Link
  • Announcements:
    • Updated macOS requirements: Starting with PreForm 3.54.0, PreForm now requires macOS 12 or later.
    • Sunsetting command line support: Most command line functionality has been removed. The only remaining support will be for launching PreForm from the command line and automatically loading models or FORM files.
  • New features:
    • Tough 2000 Resin V2: Manufacture rugged parts that rival the performance of ABS. 3x higher fracture toughness and improved temperature and creep resistance compared to the previous generation with a rich, dark, matte appearance.
    • Tough 1000 Resin: Manufacture impact-resistant parts that rival the performance of HDPE. 5x fracture toughness, 3x impact strength, and 3x elongation at break compared to Durable Resin.
    • Supports V2: Get higher quality, more reliable parts with less work. Supports V2 cuts dimensional inaccuracy in half and uses 50% smaller touchpoints for a smooth finish, ensuring assemblies fit perfectly. A new crushable lattice structure makes support removal fast, easy, and less likely to damage your part. Available for:
      • Tough 2000 Resin V2 (default)
      • Tough 1000 Resin (default)
      • Black Resin V5 (beta)
      • Clear Resin V5 (beta)
      • White Resin V5 (beta)
      • Grey Resin V5 (beta)
      • Tough 2000 Resin V1.1 (beta)
      • Tough 1500 Resin V2 (alpha)
    • Print Cost Estimator for SLA: Get estimated part costs for your SLA prints. Input your material cost per liter in the new cost estimator panel, and PreForm will display the total part cost in the print summary.
  • Improvements:
    • When changing views with the Viewer Cube, you can now frame just the selected part or the entire build volume. Pick your preferred behavior in the View menu.
    • New Default print setting (V1.0) for Tough 2000 Resin V2 at 100 microns for Form 4 and Form 4L generation printers
    • New Default print setting (V1.0) for Tough 1000 Resin at 100 microns for Form 4 generation printers
    • New Supports V2-based Beta print settings for Form 4/4L generation printers. These settings are under validation and are expected to work for most applications. Expect reduced print success rate.
      • Black Resin V5
      • Clear Resin V5
      • White Resin V5
      • Grey Resin V5
    • New Supports V2-based Alpha print settings for Tough 1500 Resin V2 for Form 4/4L generation printers. These settings are unvalidated and for advanced users to test. Expect a higher than usual print failure rate.
  • Bug fixes:
    • Fixed bug where rotation values were not displayed while rotating the model.
    • Fixed issue where values from the Measure Tool would appear over other elements on the screen.
PreForm 3.53.0 — October 21, 2025
Mac Download: Link
  • Announcements:
    • Updated macOS requirements: Starting with PreForm 3.54.0, PreForm will require macOS 12 or later to run.
    • Sunsetting command line support: Starting with PreForm 3.54.0, most command line functionality will be removed. The only remaining support will be for launching PreForm from the command line and automatically loading models or FORM files.
  • New features:
    • Measure tool: Quickly validate dimensions and clearances by measuring precise distances between any two points in your scene, with ΔX, ΔY, and ΔZ components in the summary panel. Hold Shift to snap to mesh vertices for accuracy. Eliminates the need to switch to external CAD software for simple dimensional checks.
    • Viewer cube: Navigate the scene and quickly jump to standard orthographic views.
    • Model grouping for SLA: Organize parts in the model list by grouping them. This builds on the grouping feature we released for SLS last year.
  • Improvements:
    • New SLA Print Settings Editor parameters:
      • New squish parameters: Directly modify the Formlabs smart squish algorithm. This allows for much more robust tuning of the squish phase to eliminate print problems or increase the speed.
      • Resin LevelSense: Control the level at which the printer throws a low resin warning. This will also change the level that the printer keeps the resin tank filled to for Formlabs materials.
      • Resin viscosity: Input the resin viscosity for a print. This can impact some print behaviors.
  • Bug fixes:
    • Fixed several issues with the new Support flyout to ensure it correctly respects selected settings.
    • Fixed a crash that could occur when selecting support profiles in the new Support flyout.
    • Fixed missing FORM file thumbnails on Windows.
    • Fixed incorrect mesh selection behavior when slicing along the X- or Y-axis.
    • Various minor UI improvements and fixes.
  • Known issues:
    • Keyboard shortcuts for the new Support flyout are not displayed in the shortcut dialog, but hovering over the button will display the shortcut.
PreForm 3.52.1 — September 25, 2025
This release introduces new functions to fill the build with models, expands the Slicer tool to let you examine your models along the X-, Y-, and Z-axes, and adds support for importing CAD assembly files. It also introduces a streamlined interface for the new Supports tool.
Mac Download: Link
  • New features:
    • New Support tool: Gain precise control over support generation with presets, customizable touchpoint generators, and comprehensive support structure customization. Use the new flexible visibility controls to inspect models and supports.
    • Section in all axes: Inspect internal geometry, complex support structures, and packed build volumes with confidence. Use the Slicer tool to see inside your model from any orthogonal direction, ensuring a perfect print every time. This is perfect for verifying internal support placement while you work, as the slice view is active while you move, rotate, or edit supports.
    • Fill the Build: Maximize throughput and minimize setup time for both SLA and SLS printers. Automatically populate the entire build platform or build chamber with as many copies of a selected part as can fit, turning a tedious manual layout task into a single click. Fine-tune your layout with advanced controls for part spacing, rotation, and even raft overlap (SLA) to achieve maximum packing density.
    • CAD assembly import: Import assembly files and split them into individual parts.
  • Improvements:
    • CAD import settings: Configure tessellation options for CAD imports.
    • Print time estimator control: Toggle the real-time print time estimator on/off to improve performance on demanding print jobs. Disable real-time print time estimator updates through File > Preferences to prevent interface lag while maintaining estimation accuracy when needed.
    • New Default print setting (V1.2) for Precision Model Resin V1 at 50 microns for Form 4 and Form 4L generation printers with improved dental die fitting.
  • Bug fixes:
    • Fixed an intermittent crash that could occur during cup detection in printability checks.
    • Fixed an intermittent crash when triggering the part cost calculator.
    • Fixed an intermittent crash when applying support presets.
    • Fixed an issue where parts imported into the dental workspace could have an incorrect orientation.
  • Known issues:
    • Keyboard shortcuts for the new Support tool are not displayed in the shortcut dialog, but hovering over the button will display the shortcut.
    • The support generation keyboard shortcut does not correctly apply updated settings. It reuses the last settings submitted via the button, ignoring any subsequent changes.
    • The last-used touch tip size in the Manual Placement tab is reset when supports are generated.
  • Compatibility:
    • Fuse 1: compatible with firmware version 1.15.3 and later
    • Fuse 1+: compatible with firmware version 1.15.3 and later
    • Form 4B: compatible with firmware version 1.7.2 and later
    • Form 4: compatible with firmware version 1.7.2 and later
    • Form 4L: compatible with firmware version 1.9.0 and later
    • Form 4BL: compatible with firmware version 1.9.0 and later
    • Form 3BL: compatible with firmware version 1.10.8 and later
    • Form 3L: compatible with firmware version 1.10.8 and later
    • Form 3B/3B+: compatible with firmware version 1.19.7 and later
    • Form 3/3+: compatible with firmware version 1.19.7 and later
    • Form 2: compatible with firmware version 1.19.25 and later
PreForm 3.51.1 — August 29, 2025
This release fixes a variety of bugs related to the new support tool introduced in PreForm 3.51.0 and adds an option to revert to the old interface.
Mac Download: Link
  • Improvements:
    • Added an option to switch to the previous support tool interface under Preferences.
  • Bug fixes:
    • Fixed bug where PreForm was unable to open some STL or FORM files
    • Fixed bug where PreForm would crash while editing supports manually
    • Fixed inconsistent accordion collapsing behavior
    • Fixed bug where clicking the Generate Structure button would remove manually created touchpoints
    • Fixed bug where PreForm would freeze when manually placing supports
  • Compatibility:
PreForm 3.51.0 — August 19, 2025
This release introduces a revamped SLA supports tool, allowing for precise control over touchpoint locations, streamlined manual placement, and support structure customization.
Mac Download: Link
  • New features:
    • Precise control over touchpoint locations: Adjust touchpoint placement by customizing the Minima, Overhangs, Stabilization, and Reinforcement touchpoint generators.
    • Streamlined manual placement: The Support Brush is now in its own dedicated tab for easier access for power users.
    • Support structure customization: Precisely control how support structures are created, from touchpoint properties to pillar and raft parameters.
    • Support visibility control: Inspect supported models without the support geometry getting in the way. Instantly toggle between showing the model with supports, transparent supports or only touchpoints.
  • Improvements:
    • Bundled Supports turned on by default: PreForm will cluster support pillars into bundles that can be easily removed during post processing. Bundled Supports are turned on by default for select materials and layer thicknesses.
  • Bug fixes:
    • Fixed issue where custom print settings could not be saved in Dental Workspace
    • Fixed issue where some STEP files could not be imported into PreForm
    • Fixed issue where deleting the current print applied print setting would crash PreForm
    • Speed Optimized Beta v5.3 setting promoted to Default v5.3 for Nylon 12 Powder. Default v4.1 renamed to Legacy v4.1
    • Legacy v1.2 setting for Nylon 12 GF Powder removed. Legacy settings can be found on the Choosing the right print setting (SLS) support article
    • Speed Optimized Beta v2.1 setting promoted to Default v2.1 for Nylon 11 Powder. Default v1.2 renamed to Legacy v1.2
    • Beta v1.1 setting promoted to Default v1.1 for Nylon 12 White Powder. Default v1.0 renamed to Legacy v1.0
    • Speed Optimized v2.1 promoted to Default v2.1 for TPU 90A Powder. Default v1.1 renamed to Legacy v1.1
  • Known issues:
    • Touchpoints may not render or display correctly when switching between support visibility modes
    • In the new Support tool, input fields do not show undo option until another input field is interacted with
    • Support tool window will not scroll if the mouse is over any input field
    • Keyboard shortcuts do not work correctly in the new Support tool
  • Compatibility:
PreForm 3.50.2 — August 4, 2025
This release fixes a bug related to uploading the same Form 4 generation print jobs multiple times.
Mac Download: Link
  • Bug fixes:
    • Form 4 generation: Fixed a bug that caused PreForm to crash if the same job was sent to a printer more than once.
  • Compatibility:
PreForm 3.50.1 — July 30, 2025
This release introduces new and improved print settings for Grey Resin and Clear Resin on Form 3, Form 3L, and Form 4L generation printers. It also fixes two bugs related to custom print settings and support editing.
Mac Download: Link
  • Bug fixes:
    • Form 4 and Form 4L generation: Fixed issue where the printer would not squish for prints with custom squish settings.
    • Fixed bug where touchpoint size was not being applied in Supports Edit mode.
    • New Default print setting (V1.0) for Grey Resin V5 at 25 microns for Form 4L generation printers
    • New Default print setting (V1.0) for Clear Resin V5 at 25 microns for Form 4L generation printers
    • New Default print setting (V1.0) for Grey Resin V4.1 at 25 microns for Form 3 generation printers
    • New Default print setting (V1.0) for Grey Resin V4.1 at 25 microns for Form 3L generation printers
  • Compatibility:
PreForm 3.50.0 — July 22, 2025
This release introduces a limited beta support visibility feature as well as new and improved print settings for Grey Resin V4.1 on Form 3 generation printers and Flame Retardant Resin V1, Black Resin V5, and Tough 1500 Resin V2 on Form 4L generation printers.
Mac Download: Link
  • New features:
    • Support visibility control (Beta): Easily inspect models by cycling through new support visibility modes—fully visible, translucent, and touchpoints only. Inspect, edit, and validate touchpoint locations and support geometry easily. Ideal for all SLA users seeking to speed up their support workflow and more efficiently verify support placement. Note: This is a beta feature and is available to select users.
    • New Default print setting (V1.0) for Grey Resin V4.1 at 160 microns for Form 3 generation printers
    • New Default print setting (V1.0) for Flame Retardant Resin V1 at 50 microns for Form 4L generation printers
    • New Default print setting (V1.0) for Black Resin V5 at 25 microns for Form 4L generation printers
    • New Default print setting (V1.0) for Tough 1500 Resin V2 at 50 microns for Form 4L generation printers
  • Compatibility:
PreForm 3.49.0 — June 17, 2025
This release introduces support for Color Resin V5 and True Cast Resin, as well as a new color coding feature. It also includes new and improved print settings for general purpose resins.
Mac Download: Link
  • New features:
    • Color Resin V5 support: Now print with Color Resin V5, offering custom-ordered resin manufactured in just one week to your exact color specifications. This allows you to achieve rich, vibrant, and accurately matched colors for parts with versatile mechanical properties, all through a fast, affordable, and print-ready workflow. Ideal for users needing to create brand-aligned products, striking prototypes, functional color-coded parts, or unique end-use applications.
    • Introducing True Cast Resin: A new wax-filled material engineered for precise casting of detailed jewelry and complex components up to 5 mm thick. This high-performance resin enables the production of accurate parts with crisp features, smooth surfaces, that have a clean burnout, making it ideal for demanding casting applications. Whether you're a jeweler crafting medium to heavy jewelry pieces, medallions, or figurines, or an engineer producing small, complex parts, True Cast Resin offers a reliable and refined casting solution.
    • Part color coding: Easily assign distinct colors to individual models or entire model lists within your PreForm build, either manually or with one-click random generation. This feature significantly improves build organization and makes identifying specific parts faster, especially in densely packed jobs. Ideal for SLS users who frequently manage and pack numerous models into a single build.
  • Known issues:
    • Unable to add label after using Scan to Model
    • New Default print setting (V1.0) for White Resin V4.1 at 50 microns for Form 3L generation printers
    • New Default print setting (V1.0) for Grey Resin V4.1 at 50 microns for Form 3L generation printers
    • New Default print setting (V1.0) for True Cast Resin V1 at 50 microns for Form 4 generation printers
    • New Default print setting (V1.0) for True Cast Resin V1 at 25 microns for Form 4 generation printers
    • Changed raft text font for compatibility with more system configurations.
    • Lowered printing temperature for general purpose resins for 100 and 50 micron settings for improved resin stability.
  • Compatibility:
PreForm 3.48.0 — May 27, 2025
This release introduces a face selection mode in the Texture tool, a Reduced Supports print setting for certain resins on Form 4 generation printers, and four new parameters in the Print Settings Editor for Form 4 generation printers. It also includes new and improved print settings for Form 3, Form 3L, Form 4, and Form 4L generation printers.
Mac Download: Link
  • New features:
    • Face selection mode in Texture tool: Now you can apply textures to specific faces of your 3D models rather than the entire object. Import color-coded CAD files and easily select faces by color in the Texture panel, giving you greater precision and control over your printed parts' surface finish and appearance.
    • Reduced Supports print settings: reduce support touchpoints by up to 30% resulting in cleaner surfaces and less post-processing work. Heavy or complicated models may not print successfully.
  • Improvements:
    • Debris detection setting in Print Settings Editor: Prevent the printer from stopping a print when it encounters higher than expected forces.
    • Preprint mixer speed setting in Print Settings Editor: Control the speed at which the mixer moves before a print.
  • Bug fixes
    • Fixed incorrect Broken Models Detected warning when importing certain model files
    • Fixed issue where PreForm would incorrectly flag overlapping models
    • Fixed issue to reduce mixer collisions using 160 micron Fast Arch setting with Fast Model Resin on Form 4L generation printers
  • Known issues:
    • New Default print setting (V1.0) for Grey Resin V4.1 at 100 microns for Form 3L generation printers
    • New Default print setting (V1.0) for Grey Resin V4.1 at 50 microns for Form 3 generation printers
    • New Default print setting (V1.0) for White Resin V4.1 at 50 microns for Form 3 generation printers
    • New Default print setting (V1.0) for Tough 1500 Resin V2 at 50 microns for Form 4 generation printers
    • New Default print setting (V1.0) for High Temp Resin V2 at 50 microns for Form 4L generation printers
    • New Default print setting (V1.0) for ESD Resin at 50 microns for Form 4L generation printers
  • Compatibility:
PreForm 3.47.1 — April 28, 2025
This release fixes the names of some Beta print settings for Formlabs SLS printers.
Mac Download: Link
  • Improvements:
    • Fixed print settings names for Formlabs SLS printers
  • Compatibility:
PreForm 3.47.0 — April 23, 2025
This release improves support generation and print time estimation speeds. It also includes new and improved print settings for Fuse 1+ 30W printers.
Mac Download: Link
  • Improvements:
    • Faster support generation: Spend less time waiting for supports to generate on your SLA prints thanks to performance improvements.
    • Saved Print Validation settings: PreForm now remembers your Print Validation toggle choices between sessions, streamlining your setup workflow.
    • Faster, smoother print time estimates: The rapid print time estimator now provides quicker feedback and uses less of your computer's resources.
  • Bug fixes
    • Printer selection remembered: Fixed an issue where the last used printer wasn't always saved. PreForm now reliably remembers your printer choice in Job Setup.
    • Updated Speed Optimized Beta setting for Nylon 12 Powder for Fuse 1+ 30W to improve surface quality while maintaining speed and accuracy.
    • New Speed Optimized Beta setting for Nylon 11 Powder for Fuse 1+ 30W with significant improvements to surface quality and for fastest printing speed.
    • New Default setting for Nylon 11 CF Powder for Fuse 1+ 30W to combat warping in the Z direction and improve surface quality.
    • New Beta setting for Nylon 12 White Powder for Fuse 1+ 30W which improves fine feature resolution and strength.
  • Compatibility:
PreForm 3.46.1 — April 7, 2025
This release improves noise mitigation for Form 4 and Form 4L generation printers. It also includes new and improved print settings for Form 3L, Form 4, and Form 4L generation printers.
Mac Download: Link
  • Improvements:
    • Improves printer noise mitigation: In PreForm 3.46.0, Formlabs released a new feature that made the Form 4 and Form 4L printers quieter. We have further improved the feature to make sure the printer is quieter for most prints.
    • New Default print settings for Precision Model Resin V1 at 25 microns for Form 4L generation printers
    • New Default print setting for BioMed Clear Resin V1 at 50 microns for Form 4BL printers
    • Minor accuracy improvements for:
      • White Resin V4.1 at 100 microns for Form 3L generation printers
      • Tough 1500 Resin V2 at 100 microns for Form 4 generation printers
      • Tough 1500 Resin V1 at 100 microns for Form 4L generation printers
    • Faster on-rafts prints for:
      • Precision Model Resin V1 at 50 microns for Form 4L generation printers
      • Clear Resin V5 at 50 microns for Form 4L generation printers
      • Tough 2000 Resin V2 at 50 microns for Form 4L generation printers
  • Compatibility:
PreForm 3.46.0 — March 24, 2025
PreForm 3.46.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release includes a new feature to add parts to a running job on Fuse 1 & 1+. It also has bug fixes for file uploading issues and mouse scrolling, and new Default Settings for Form 4, Form 4L, Form 4BL, Form 3, Form 3L and Form 3BL printers.
Mac Download: Link
  • New features:
    • Maximize printer efficiency with Add to Running Job (Beta): The "Add to Running Job" feature (Beta) for Fuse 1 & Fuse 1+ enables adding parts to ongoing prints, eliminating wait times between jobs. Quickly respond to urgent orders, streamline daily workflows, and minimize downtime—perfect for dynamic environments and efficient production management.
  • Improvements:
    • Grouped prints in Voting Center (for SLS): The SLS voting feature now groups prints by date, making it easier to find and vote on prior prints.
  • Bug fixes:
    • Fixed issue where some Form 4B jobs could not be uploaded to a printer group with Form 4B printers.
    • Fixed issue with mouse scrolling on the slicer slider.
    • New Default print setting for Tough 1500 V2 Resin at 100 microns for the Form 4 and Form 4L generation printers.
    • New Default print setting for Grey V4.1 Resin at 100 microns for the Form 3 generation printers.
    • New Default print setting for White V4.1 Resin at 100 microns for the Form 3L generation printers.
    • Minor Default print settings update for Grey and Black V5 Resin at 50 microns to version 1.2 for the Form 4L generation printers to reduce print failures for very large, solid parts.
    • Minor Default print settings update for Clear and White V5 Resin at 50 microns to version 1.1 for the Form 4L generation printers to reduce print failures for very large, solid parts.
  • Known Issues:
    • When creating new jobs as part of Add to Running Job, the total print time will not update correctly.
  • Compatibility:
PreForm 3.45.2 — March 11, 2025
PreForm 3.45.2 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release includes print settings updates for BioMed Black, BioMed Amber, Surgical Guide, and Color Base resins for Form 4L and Form 4BL. It also has a bug fix to prevent mini-rafts from intersecting with models printed directly on the build platform.
Mac Download: Link
  • Bug fixes:
    • Fixed issue where some mini rafts would intersect with the model when printing directly on the BP for the Form 4 and Form4L generation printers.
    • Added Default setting for BioMed Black Resin at 50 microns for the Form 4BL printer
    • Added Default setting for BioMed Amber Resin at 50 microns for the Form 4BL printer
    • Added Default setting for Surgical Guide Resin at 50 microns for the Form 4BL printer
    • Added Default setting for Color Base Resin at 100 microns for the Form 4L generation printers
  • Compatibility:
PreForm 3.45.1 — February 28, 2025
PreForm 3.45.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release includes new features for auto-layout (SLA), packing (SLS), print voting (SLS), and print time estimation (SLA). It also has bug fixes for file uploading issues, and new Default Settings for Form 4L, Form 4BL printers, Form 3L and Form 3BL printers.
Mac Download: Link
  • Bug fixes:
    • Fixing a potential software crash that could occur under certain conditions.
  • Compatibility:
PreForm 3.45.0 — February 25, 2025
PreForm 3.45.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release includes new features for auto-layout (SLA), packing (SLS), print voting (SLS), and print time estimation (SLA). It also has bug fixes for file uploading issues, and new Default Settings for Form 4L, Form 4BL printers, Form 3L and Form 3BL printers.
Mac Download: Link
Note:
Note: PreForm 3.45.0 no longer supports Windows 7 and 8, our new minimum version is Windows 10 October 2018 Update (version 1809)
  • New features:
    • Enhanced Layout feature (SLA): The automatic Layout tool has been optimized to utilize 25% more build platform space. This enhanced space utilization reduces the need for manual part arrangement while delivering more efficient print layouts.
    • Print time estimation (Form 4): When preparing Form 4 builds, you'll now see print time estimates that update in real-time as you modify your setup. This immediate feedback helps you better plan and schedule your print jobs, improving workflow efficiency.
    • Distance to Wall setting (SLS): PreForm’s powerful auto packing feature now allows you to configure a Distance to Wall setting. When a value is set, the algorithm will ensure an offset of that distance from the build chamber walls.
    • Print voting in PreForm (SLS): Vote on your earlier prints.
  • Improvements:
    • Statistics tracking update (SLS): We've refined our statistics tracking by excluding cages from model counts. This change provides more accurate metrics for actual part printing, giving you a clearer picture of your printing activity.
  • Bug fixes:
    • Fixed issue where FPS files were disappearing: When closing PreForm, some users’ FPS files would disappear. This has now been fixed.
    • Added Default setting for Rigid v1 Resin at 50 micron for Form 4L generation printers
    • Added Default setting for Black v4.1 Resin at 50 micron for Form 3L generation printers
    • Added Default setting for Clear v4.1 Resin at 50 micron for Form 3L generation printers
PreForm 3.44.2 — February 17, 2025
PreForm 3.44.2 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, an Form 4BL printers. This release introduces new print settings and optimizations to enhance print quality and expand material capabilities across our printer lineup
Mac Download: Link
Note: PreForm 3.45.0 and above will no longer support Windows 7 and 8.
    • Added Default setting for Durable v2.1 Resin at 50 micron for Form 4L generation printers
    • Added Default Setting for Precision Model Resin at 100 microns for Form 4L and Form 4BL printers
    • Updated Speed Optimized V5.1 to Speed Optimized Beta V5.2 setting for Nylon 12 Powder for the Fuse 1+. This setting provides significantly improved accuracy and reduced z-axis warpage while maintaining the same print speed as v5.1
PreForm 3.44.1 — February 10, 2025
PreForm 3.44.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features bug fixes for job uploading issues with Fuse 1 generation printers, minor UI fixes for the Print Settings Editor, and new Default Settings for Form 4L and Form 4BL printers
Mac Download: Link
  • Bug fixes:
    • Fixed issue in PreForm 3.44.0 where some users encountered the error FL0 generation failed when uploading jobs to Fuse 1 generation printers
    • Fixed issue in PreForm 3.44.0 where Download History (CSV) feature did not work for Fuse printers
    • Minor UI fixes for Print Settings Editor
    • Added Default Setting for Grey V5 Resin at 150 microns for Form 4L and Form 4BL printers
    • Added Default Setting for Premium Teeth Resin at 50 microns for Form 4BL printers
    • Added Default Setting for Rigid 10K Resin at 50 microns for Form 4L and Form 4BL printers
PreForm 3.44.0 — January 29, 2025
PreForm 3.44.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features a new bundled supports feature for SLA printers, new language support in PreForm's UI, faster CAD imports, and bug fixes.
Mac Download: Link
Note: PreForm versions 3.45.0 and later will no longer support Windows 7 and Windows 8.
  • New features:
    • Bundled Supports: Groups support structures together for easier support removal, reducing post-processing time, and improving supported surface finish. Enable the option under the Supports flyout.
    • Language support: Switch PreForm’s UI to any of the supported languages: English, French, German, Italian, Japanese, Spanish, Simplified Chinese or Traditional Chinese. Select the language in the Settings window.
  • Improvements:
    • Streamlined job setup: Simplified visual feedback during print setup by turning the Undersupported model warning (indicated by red shading) off by default for some users. You can toggle this visualization in Print Validation settings if you prefer the previous behavior.
    • Faster CAD import: Improved performance when importing CAD files for faster print setup
  • Bug fixes:
    • Fixed issue where opening a FORM file would sometimes not select the correct printer type
    • Fixed issue preventing users from printing or saving FORM files with Castable Wax Resin on Form 4L/4BL
    • Tough 2000 v1.1 update: Released new Default V2 print setting at 100 microns with significant support structure improvements for better surface quality and easier support removal. The previous Default V1 print setting remains available as Legacy V1 for existing workflows.
  • Known issues:
    • The Form Wash and Form Cure updater is currently not working. For updating these units, Windows and MacOS users should use PreForm 3.39.0.
PreForm 3.43.2 — January 21, 2025
PreForm 3.43.2 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features added support for IBT Flex Resin V1 and updated BioMed Flex Resin V1 on Form 4BL printers.
Mac Download: Link
    • Form 4BL: Added support for IBT Flex Resin V1 with 100 micron print settings
    • Form 4BL: Updated BioMed Flex Resin V1 at 100 microns to improve dimensional accuracy
Older versions
