Warning:
Resin and solvent may cause skin irritation or an allergic skin reaction. Wear gloves when handling liquid resin, resin-coated surfaces, or solvent. Wash skin with plenty of soap and water.
Get ready to print with the Form 3L/Form 3BL. Learn best practices to set up and use the Form 3L/Form 3BL and its resin tank, build platform, and resin dispensing system.
Turning on the printer
To turn on the printer:
The first time the printer is connected to power, the touchscreen displays a series of onboarding steps. The onboarding steps include instructions for inserting consumables (resin tank, resin cartridges, and build platform) into the printer, additional details for which are given below. Follow these steps to prepare the printer for use.
Inserting the resin tank
Resin is dispensed out of the resin cartridges into the resin tank. During a print, two lasers pass upwards through the flexible film of the resin tank and cure resin onto the build platform to form a printed part.
Warning:
Resin may spill over the tank walls if the resin tank tilts more than 5–10 degrees. Hold the resin tank level with two hands. To inspect and clean the resin tank's underside, empty the resin tank and/or take care to avoid spilling resin outside the resin tank.
The resin tank is the primary container for holding resin after it is dispensed from the cartridges. Resin is cured onto the build platform when the laser passes through the tank's bottom film.
To insert the resin tank:
Avoid contaminating the resin tank's underside with fingerprints or liquid resin.
Inserting the mixer
Each resin tank includes a mixer that improves print consistency by clearing the build area and circulating the resin. Scrapers on the top and bottom of the mixer clear the build platform and flexible film, respectively.
To insert the mixer:
Inserting the build platform
The build platform is the surface onto which parts are printed. It is secured in place on the build platform carriage during a print with the platform lock.
Hold the build platform by both handles when inserting it into or removing it from the printer.
To insert the build platform:
Inserting the resin cartridges
Resin cartridges hold liquid resin before it is dispensed into the resin tank. Given the Form 3L’s build volume and the size of the resin tank, it uses two resin cartridges at once.
Note:
A print can be started with only one resin cartridge inserted. Monitor the printer to ensure it does not run out of resin during the print.
To insert the resin cartridges:
Do not remove the flexible, rubber bite valves at the bottom of the resin cartridges. These bite valves control the release of the resin. Removing the bite valves allows resin to continuously flow and causes extreme damage to the printer. This damage is not covered by the warranty.
Tip:
Make sure the material in the resin tank always matches the resin type in the installed resin cartridges.
Printing with the Form 3L/Form 3BL
Now that the printer is set up:
