Meet the Form 3+
What's New With the Form 3+
A two minute intro of the key updates in the Form 3+.
Meet the Form 3+
High Quality Parts, Fast and Affordably
Reduce costs, iterate faster, and bring better experiences to market with our advanced 3D printing materials designed to deliver beautiful final parts for a wide range of applications.
Rapid Prototyping
Draft Resin
$9
4 hours
Note: Print time and cost will vary based on part geometry, material, layout, and orientation.
Truly Rapid Production
Quickly go from design to finished part with the streamlined, end-to-end workflow of the Form 3+.
Laser Power
Layer Thickness
Rapid print speeds
A powerful, high-intensity laser and precisely tuned settings for every material deliver rapid print speeds.
Easy support removal
Enhanced light touch support structures detach from parts in seconds to save post-processing time.
An efficient ecosystem
Automated post-processing solutions simplify and streamline the entire 3D printing workflow.
Reliable High-Quality Parts
Reliable, High-Quality Parts
The Form 3+ refines Formlabs' patented LFS technology to consistently deliver presentation-ready parts with unbelievable surface finish.
XY Resolution
Laser Spot Size
Crisp, Clean, Accurate Features
The next generation of stereolithography (SLA) 3D printing, LFS technology accurately resolves fine features by delivering a clean, uniform laser spot across the entire print surface.
Production-Like Surface Finish
A flexible resin tank and refinements to the Light Processing Unit (LPU) create near perfect alignment between printed layers, giving parts a production-like finish.
Adaptive Layer Technology
Adaptive Layer Thickness automatically analyzes the geometry of parts and assigns layer heights throughout to maximize print speeds while preserving fine detail.
Maximum Efficiency
Maximum Efficiency
The Form 3+ is rich with features that improve ease of use so you can spend more time ideating and less time monitoring your printer.
Print From Anywhere
Prepare your printer before you leave, then start jobs from anywhere with our cloud based Remote Print technology.
Minimal Printer Interactions
No specialized technicians required. Get started right away and let the printer do the work.
Hassle-Free Materials Management
Switch between a wide range of functional materials in seconds with our swappable resin cartridge and tank system. Form 3+ dispenses resin automatically as parts print.
The Form 3+ Workflow in Five Minutes
Get more done and work more efficiently with an end-to-end 3D printing workflow. From printing, to post-processing, each step of the process was designed with efficiency in mind.
Design
Wash
Remove Part
Remove Supports
Cure
Quick Release Technology
Build Platform 2 with patented Quick Release Technology quickly and easily releases parts from the build platform without tools.
Enhanced Light Touch Supports
Decrease post-processing time with our enhanced light touch supports structures that break off easier and cleaner than ever before.
30+ Functional Materials
Make any idea a reality and seamlessly switch between a library of over 30 functional materials with a cross-compatible cartridge system.
Automated Wash and Cure
Deliver strong, ready-to-use parts with less time and effort. Form Wash and Form Cure streamline and automate rinsing and post-curing of prints.
Support When You Need It
Get helpful, human service when you need it from a Formlabs expert, with plans that scale with your business.
Industry-Leading Software
Plan and manage your print queue in PreForm and manage printers and teams through your online Dashboard.
85,000,000 Parts Printed With Formlabs Technology
Start scaling your prototyping and production today.
With faster than ever print speeds, advancements in post-processing, and continued refinements in part quality, the Form 3+ allows you to quickly and reliably go from design to part in hand at an accessible price point.
