Formlabs Stereolithography 3D Printers Tech Specs
Technology
Masked Stereolithography (MSLA)
Printer Engine
Low Force Display™ (LFD)
Key Components of the Print Engine
Backlight Unit
Light Processing Unit 4 (LPU 4)
Release Texture
Flexible Film Resin Tank
Intelligent Control Systems
High-Speed Automatic Resin Handling
Light Source
Backlight Unit: 60 uniform-wavelength LEDs, a plano-convex lens array, and integrated air cooling
405 nm optical wavelength
16 mW/cm² optical power intensity delivered to the cure plane
50 µm pixel size
Maximum Print Speed¹
100 mm/hour
3.9 in/hour
Typical Print Speed²
Average: 40 mm/hour (1.6 in/hour) across all materials
Range: 16-50 mm/hour (0.6-2.0 in/hour) depending on the material
Typical Dimensional Tolerances (XY)³
1-30 mm features: ±0.15% (lower limit: ±0.02 mm)
31-80 mm features: ±0.2% (lower limit: ±0.06 mm)
81-150 mm features: ±0.3% (lower limit: ±0.15 mm)
Reliability
98.7%, measured by an independent third-party lab in a series of comprehensive performance tests.
Materials
23 industry-leading Formlabs materials or third-party materials using Open Material Mode. More exciting new materials are currently in development.
Explore Materials
Biocompatible Materials
No (available on Form 4B)
Build Volume (W x D x H)⁵
20.0 × 12.5 × 21.0 cm
7.9 × 4.9 × 8.3 in
5.25 liters
Build Area
250 cm²
38.8 in²
Maximum Part Length⁶
27.3 cm
10.7 in
XY Resolution⁷
50 µm with pre-tuned anti-aliasing for subpixel resolution
Superior fine feature performance and sharp features compared to the Form 3 Series
Layer Thickness⁸
25–200 µm
0.001–0.008 in
Resin Cartridges
1
Resin Cartridge Type
Next-generation resin cartridge
5-10x faster filling
63% less waste
30% less shelf space
Resin Heating
High speed conduction resin heating with infrared temperature sensing
Internal Temperature
Auto-heats resin to 25–45 °C (77–113 °F), depending on material
Force Sensing
Z-Axis Force Sensor: automatically optimizes print quality and print speed based on part geometry and selected material.
Supports
Auto-generated
Light-touch removal
Design/CAD Specifications
Printer Dimensions (W x D x H)
39.8 × 36.7 × 55.4 cm
15.7 × 14.5 × 21.9 in
Minimum Access Dimensions (W x D x H)
40.7 × 47.8 × 84.4 cm
16.0 × 18.8 × 33.2 in
Printer Weight
18.3 kg
40.4 lb
Operating Environment
18–28 °C
64–82 °F
Power Requirements
100–240 VAC
4.8 A
50/60 Hz
480 W
Connectivity
Wi-Fi (2.4 and 5 GHz; IEEE 802.11 b/g/n/ac, WPA/WPA2)
Ethernet (1000 Mbit)
USB-C 2.0
Printer Control⁹
7" interactive touchscreen
1280 × 800 resolution
Languages: English, German, French, Spanish, Italian, Japanese, Simplified Chinese
Alerts
Touchscreen alerts
SMS/email via Dashboard
Speaker for audio alerts
Sensors and Control Systems
6 upgraded sensors that precisely control resin temperature, resin level, print forces, and print status:
High-speed conduction resin heating with infrared temperature sensing
Ultrasonic Resin Level Sense: controls resin in the tank
Z-Axis Force Sensor: controls and minimizes print forces
Resin Cartridge Load Cell: measures exact resin level in cartridge
Printer Leveling Sensor
Camera
Camera
Integrated camera
2592 x 1944 resolution (5MP)
Remote monitoring, print history, and print timelapses
Can be easily disabled, covered, or removed
PreForm System Requirements
Windows 10 (64-bit only, ARM not supported) and up
Mac OS X 10.15 and up
OpenGL 2.1
C++ runtime library from Microsoft (Windows only)
4 GB RAM (8 GB recommended)
PreForm File Types
STL, OBJ, and 3MF file input
FORM file output
PreForm Print Setup Features
One-Click Print
Adaptive layer thickness for faster printing with fine details
Remote Print
Auto-orient for optimal print position
Auto-mesh repair
Auto-generation of supports
Advanced tools for manually editing supports
Rotate, scale, duplicate, and mirror
Layer slicer for path inspection
Custom print settings
Available in multiple languages
Dashboard Printer Management Features
Manage prints and printers via the cloud
Track resin and tank usage over time
SMS and email alerts
Create enterprise group accounts with admins to more easily share printers and control access
Resin Tank Estimated Lifetime¹⁰
75,000+ layers with any Formlabs material
For example: approximately 190 prints using average height model (39 mm tall), any resin, and 100 µm layer height
Technology
Printer Engine
Backlight Unit
Release Texture
Light Source
50 µm pixel size
100 mm/hour
3.9 in/hour
Reliability
Materials
38 industry-leading Formlabs materials, including 15 biocompatible, or third-party materials using Open Material Mode. More exciting new materials are currently in development.
Explore Materials
Yes
7.9 × 4.9 × 8.3 in
5.25 liters
Build Area
250 cm²
38.8 in²
27.3 cm
10.7 in
XY Resolution⁷
Layer Thickness⁸
25–200 µm
0.001–0.008 in
Resin Cartridges
1
63% less waste
Resin Heating
Force Sensing
Supports
Auto-generated
Light-touch removal
Printer Weight
18.3 kg
40.4 lb
18–28 °C
64–82 °F
Power Requirements
100–240 VAC
4.8 A
50/60 Hz
480 W
Connectivity
USB-C 2.0
Printer Control⁹
Alerts
Touchscreen alerts
Camera
Camera
Integrated camera
OpenGL 2.1
PreForm File Types
FORM file output
One-Click Print
Remote Print
Auto-mesh repair
For example: approximately 340 prints using clear aligner models (22 mm tall), any resin, and 100µm layer height
Technology
Printer Engine
Backlight Unit
Light Processing Unit 4L (LPU 4L)
Release Texture
Light Source
Backlight Unit: 145 uniform-wavelength LEDs, a plano-convex lens array, and integrated air cooling
46 µm pixel size
80 mm/hr
3.1 in/hour
Average: 24 mm/hour (0.9 in/hour) across all materials
Range: 20-35 mm/hour (0.8-1.4 in/hour) depending on material
31-80 mm features: ±0.3% (lower limit: ±0.06 mm)
Surface Accuracy (Restorative Models)⁴
On average with Precision Model Resin:
99.9% of surfaces within 100 μm of CAD model
96.7% of surfaces within 50 μm of CAD model
71.4% of surfaces within 25 μm of CAD model
Reliability
Testing in progress.
Materials
19 industry-leading Formlabs materials or third-party materials using Open Material Mode. More exciting new materials are currently in development.
Explore Materials
No (available on Form 4BL)
35.3 × 19.6 × 35.0 cm
13.9 x 7.7 x 13.8 in
24.2 liters
Build Area
692 cm²
107 in²
Not measured
XY Resolution⁷
46 µm with pre-tuned anti-aliasing for subpixel resolution
Superior fine feature performance and sharp features compared to the Form 3L Series
Layer Thickness⁸
25–200 µm
0.001–0.008 in
Resin Cartridges
2
63% less waste
Resin Heating
Force Sensing
Z-Axis Force Sensor, automatically optimizes print quality and print speed based on part geometry and selected material.
Supports
Auto-generated
Light-touch removal
66.4 x 52.8 x 79.4 cm
26.1 x 20.8 x 31.3 in
88.9 x 116.9 x 81.3 cm
35 x 46 x 32 in
Printer Weight
58.5 kg
129 lb
18–28 °C
64–82 °F
Power Requirements
100-240 VAC
9 A
50/60 Hz
900 W
Connectivity
USB-C 2.0
Printer Control⁹
Alerts
Touchscreen alerts
Camera
Camera
Integrated camera
OpenGL 2.1
PreForm File Types
FORM file output
One-Click Print
Remote Print
Auto-mesh repair
Manual editing of supports
For example: approximately 190 prints using an average height model (39 mm tall), any resin, and 100 µm layer height
¹ Using Fast Model Resin and 200 µm layer height on the Form 4 Series. Based on actual print times from a collection of test parts covering common engineering, product design, manufacturing, and dental applications. Using Draft v2 Resin and 200 µm layer height on the Form 3 Series. Based on the 75th percentile actual print speed from reported prints in 2023.
² Average across all materials printed at 100 µm layer height, weighted by material popularity. Print speed will vary depending on the material, layer height, and part geometry. The range is based on the materials with the slowest median print speed and highest median print speed.
³ Using Grey Resin V5 and 100 µm layer height, post-cured for 5 minutes at room temperature. One test model with various feature sizes 3D printed on three different printers.
⁴ Using 50 µm layer height. Tested using a full arch restorative model with dies, four models per print job, printed on three different printers, and post-processed according to the recommended settings.
⁵ Actual achievable part size may be slightly smaller than the build volume, accounting for minor shrinkage during printing and part orientation. If you are printing a job that is taller than 19.0 cm (7.5 in) on Form 4/B, taller than 30.5 cm (12 in) in) on Form 4L/4BL, or taller than 18.5 cm (7.2 in) on Form 3/B/+, you have to remove the resin tank while removing your print. PreForm will warn users when their job is above these limits.
⁶ Assuming a part printed on supports that resembles a rectangular prism with 12.5 cm depth and 1 cm height.
⁷ XY resolution describes how precisely the printer can cure the resin in the XY (horizontal) plane. It corresponds to the pixel size of the Light Processing Unit 4 and Light Processing Unit 4L.
⁸ Layer thickness availability varies by material. View our materials compatibility table to confirm availability.
⁹ Languages beyond English will come in future firmware releases on the Form 4 Series.
¹⁰ The exact lifetime of an individual resin tank depends on layers printed, physical wear, and accidental damage.
Request a Free Sample 3D Print
See and feel the Formlabs quality firsthand. We’ll ship a free sample part to your office.
