Formlabs-approved distributors for supplies (SLS)
The Fuse 1, Fuse Sift, and Fuse Blast need regular maintenance to ensure full functionality. Some maintenance tasks require supplies that are not available for sale at formlabs.com but can be acquired through an external seller. In addition to maintenance, a range of tools and miscellaneous items can be purchased from external suppliers to ease your SLS workflow.
Before maintaining your Fuse ecosystem, check the required resources in the corresponding support article and ensure you have all required supplies at your disposal. For more information about approved distributors in your region, please contact your local certified service provider.
Do not use swabs, pre-moistened or dry wipes, surfactants, denaturants, or any other tool, chemical, or cleaning agent to maintain the Fuse 1's optical components that are not explicitly recommended by Formlabs or a certified service provider.
Tip:
Visit the following support articles to learn more about which maintenance procedure requires which supplies:
ItemSupplierPriceNotes
nTopnTopCall nTop for pricenTop is the leading computational design software for developing high-performance parts quickly and efficiently. Get dramatically better products to market sooner with nTop by using data to automate design exploration and optimization. By seamlessly fitting into established workflows and integrating with existing design, analysis, and simulation tools, nTop makes it easy to share design knowledge, accelerate iteration, and drive innovation faster than ever before.
GrasshopperRhino 6
Grasshopper
USD 995
Free
Most ubiquitous topOp software, exists exclusively as a plug-in for Rhino.
Fusion 360 Generative Design ExtensionAutodeskUSD 4K/year + USD 495/yearAutodesk’s extension for F360, user-defined desired performance metrics to generate designs that incorporate topOp into results. Basically topOp + AI = 24 proposed designs.
Materialise MagicsMaterialiseUSD 20K per licenseAM process software that sits in-between CAD and output in a workflow. Generates optimal supports based on per part FEA, relative to the AM process; optimised pack/orientation, etc.
Wissensressourcen
Design specifications for 3D models (Fuse 1)FormlabsFree
3D Hubs SLS Design Guide3D HubsFreeComprehensive design guide covering minimum features, things to avoid/be cautious of, example applications. Formlabs beta customers report designs printed with advice derived from this guide came out exceptionally well.
3D Hubs SLS Post-Processing Guide3D HubsFreeSame format as their design guide but covers various post-processing techniques that are applicable to SLS-printed parts.
Nordamerika
Verbrauchsmaterial (NA)
ItemRegionSupplierNotes
Nitrile gloves,
non-reactive
USAMcMaster-Carr
PEC*PADsUSAB&H
Manufacturer: Photographic Solutions
Polyester cloth swabs,
TX714A
USASOS Cleanroom
Alconox,
1104-1
USAMcMaster-Carr
Manufacturer: Alconox
Distilled waterUSAMcMaster-Carr
Manufacturer: PTI Process Chemicals
Ethyl alcohol,
laboratory-grade
USAMcMaster-Carr
Ethyl alcohol,
laboratory-grade
CanadaE-nrg
Glass blasting mediaUSAGrainger212–300 µm / 50–70 mesh size, compatible with Fuse Blast
Glass blasting mediaUSABlast-It-All50–70 mesh size, compatible with Fuse Blast
Glass blasting mediaUSAAmazon40–50 grit / 313–387 μm, compatible with Fuse Blast
Delfin vacuum bagsUSADelfinAnti-Static “M” filter safe bag replacement
Formlabs Powder-Safe Vacuum filtersNorth AmericaFestoolReplacement main filter for Formlabs Powder-Safe Vacuum
Formlabs Powder-safe Vacuum bagsNorth AmericaFestoolReplacement bags for Formlabs Powder-Safe Vacuum
Werkzeuge (NA)
Artikel Region Zulieferer Hinweise
Universal-Reinigungswerkzeug Dremel Versa USA Dremel Diese rotierende Motorbürste dient zum Entfernen von losem Pulver von den Teilen. Dremel beschreibt das Gerät als „wasserdicht“, macht aber keine Angaben zur Schutzart.
Eastwood Elite QST 30/60 Scroll-Luftkompressor mit geräuscharmer Technologie USA Eastwood Luftkompressor, kompatibel für die Verwendung mit dem Fuse Blast, erfordert eine 220–240-V-Steckdose.
Armaturen für Eastwood Druckluftkompressor USA
  1. 3/8" NPT-Innengewinde auf ¼" Industrieschnellkupplung für Luft (1x)
  2. ½-Zoll-NPT-Reduzierstück von Außengewinde auf ⅜-Zoll-Innengewinde (1x)
  3. EPDM-Luftschlauch, ⅜ NPT Außengewinde (1x)
  4. Druckluftfilter (1x, falls zutreffend)
  5. Druckregler (1x, falls zutreffend)
Hersteller: McMaster-Carr
Ausführliche Anweisungen finden Sie unter Einrichten einer Druckluftversorgung für den Fuse Blast. Die empfohlenen Armaturen dienen zum Anschluss des empfohlenen Luftkompressors an den Fuse Blast. Verwenden Sie bei Bedarf Gewindedichtmittel, um eine luftdichte Verbindung zu gewährleisten.
Diese Konfiguration ermöglicht das Strahlen mit 2 bar (30 psi) unter Verwendung der 4-mm-Düse oder mit 4 bar (60 psi) unter Verwendung der 3-mm-Düse.
Ein Druckluftfilter ist nur dann erforderlich, wenn Ihr Druckluftkompressor nicht selbst mit einem Filter ausgestattet ist. Bei Verwendung eines Filters oder Reglers sind zusätzliche Schläuche erforderlich.
Ein Druckregler ist nur erforderlich, wenn der Anschlussdruck bei oder über 8,3 bar liegt.
2,5 m Netzkabel
P034-008
NEMA 5-15P auf IEC 320-C19
USA Digi-Key Ein etwas längeres Netzkabel für den Fuse 1 und Fuse Sift, falls die mitgelieferten zu kurz sind.
Hinweis:
Nur für Sauger mit einer Stromaufnahme von höchstens 12 A geeignet.
USV mit 120 V USA Amazon
Hersteller: APC
Empfohlene USV für den Fuse 1. Hält 20 Minuten, wenn der Strom während des Aufheizens unterbrochen wird, oder 45 Minuten, wenn der Strom während eines Drucks ausfällt.
Hinweis:
Nur geeignet für Fuse 1 mit 120 V.
Anmerkung:
APC stellt ein 230-V-Äquivalent her, das voraussichtlich ebenfalls funktioniert, aber nicht von Formlabs getestet wurde.
EPC für 120 V USA Digi-Key
Hersteller: Tripp Lite
Nur erforderlich, wenn dies vom Formlabs-Kundenservice oder einem zertifizierten Dienstleister ausdrücklich empfohlen wird.
Hinweis:
Online-Doppelwandler-USV mit 120 V USA CDW (Kundenbindungsprogramm)
Doppelwandler-USV mit EPC. Nur erforderlich, wenn dies vom Formlabs-Kundenservice oder einem zertifizierten Dienstleister ausdrücklich empfohlen wird.
Hinweis:
Stickstoffgenerator USA Flairmo N2G 40 Stickstoffgenerator
Hersteller: Flairmo
Empfohlen für den Fuse X1.
Hinweis:
Unterschiedliche Flottengrößen erfordern unterschiedliche Stickstoffgeneratoren.
Stickstoffgenerator USA Flairmo N2G 15C.
Hersteller: Flairmo
Empfohlen für den Fuse 1+ 30W.
Hinweis:
Stickstoffgenerator USA Holtec HSS-7 (Hochgeschwindigkeitsstahl)
Hersteller: Holtec Gas Systems
Erfordert eine Versorgung mit aufbereiteter, trockener Druckluft. Empfohlen für den Fuse 1+ 30W.
Hinweis:
Unterschiedliche Flottengrößen erfordern unterschiedliche Stickstoffgeneratoren. Formlabs empfiehlt, Holtec Gas Systems zu kontaktieren, wenn mehr als ein Fuse 1+ 30W verwendet wird.
Armaturen für Holtec-Stickstoffgenerator USA
  1. Schnelltrennkupplung für Luft (1x)
  2. Schnelltrennkupplung für Luft (2x)
  3. EPDM-Luftschlauch (2x; 3x bei Verwendung mit einem externen Druckluftfilter)
  5. Gewindedichtband
Zum Anschluss des empfohlenen Stickstoffgenerators von Holtec Gas Systems an einen Druckluftkompressor und den Fuse 1+ 30W.
Ein Druckluftfilter ist nur dann erforderlich, wenn Ihr Druckluftkompressor nicht selbst mit einem Filter ausgestattet ist. Wenn Sie einen externen Druckluftfilter verwenden, sind drei Druckluftschläuche erforderlich.
Rührstab USA Holzrührspatel (oder ähnliches nicht leitendes Werkzeug)
Zum Durchrühren von Pulver im Drucker oder in Fuse Sift-Einfülltrichtern. Empfohlen für Materialien wie TPU 90A Powder, die zum Verklumpen neigen.
Europäische Union
Verbrauchsgüter (EU)
Nitrile gloves,
non-reactive
DEArbeitsschutz-Express
Manufacturer: Semperguard
PEC*PADsEUCalumet Photographic
TX714A
DE/ATPure11
Manufacturer: Texwipe
TX715
DE/ATPure11
TX714A
FRConformat
TX714A
ITAM Instruments
TX714A
ESVestilab
[email protected]
Alconox,
1104-1
DESigma-Aldrich Chemie
Distilled waterDE/ATMedicalcorner24
Ethyl alcohol,
purum
DE/AT/FR/NLHöfer Chemie
Glass blasting mediaDESchicker Mineral200–300 µm nominal average range, compatible with the Fuse Blast
Glass blasting mediaEURP-Tools200–300 µm nominal average range, compatible with the Fuse Blast
Glass blasting mediaEUAmazon40–50 grit / 313–387 μm, compatible with Fuse Blast
Vacuum bagsEUDelfinAnti-Static “M” filter safe bag replacement
Werkzeuge (EU)
Dremel Versa (PC10-1/10) EU Dremel Diese rotierende Motorbürste dient zum Entfernen von losem Pulver von den Teilen. Dremel beschreibt das Gerät als „wasserdicht“, macht aber keine Angaben zur Schutzart.
2,44 m langes Netzkabel
P050-008
CEE 7/7 auf IEC 320-C19
EU Digi-Key
Hinweis:
2 m Netzkabel C14 auf C19
IEC-60320-C14 auf IEC 60320-C19
DE/AT Amazon
Hersteller: FSKE
Netzkabel für den Netzaufbereiter.
250 V, 16 A
EPC EU Thomann
Hersteller: Furman
EPC für 230-V-Geräte.
USV mit 230 V DE / AT / FR / ES Bechtle AG
Hersteller: APC
Hinweis:
Nur geeignet für Fuse 1 mit 230 V.
Online-Doppelwandler-USV mit 230 V DE / AT / FR / ES Tripp Lite Doppelwandler-USV mit EPC. Nur erforderlich, wenn dies vom Formlabs-Kundenservice oder einem zertifizierten Dienstleister ausdrücklich empfohlen wird.
Hinweis:
Stickstoffgenerator EU DWT Mini 5–50
Hersteller: DWT GmbH
Hinweis:
Stickstoffgenerator EU Flairmo N2G 40 Stickstoffgenerator
Hersteller: Flairmo
Hinweis:
Stickstoffgenerator EU Flairmo N2G 15C.
Hersteller: Flairmo
Hinweis:
Stickstoffgenerator EU Holtec HSS-7 (Hochgeschwindigkeitsstahl)
Hinweis:
Adapter für den Fuse Blast EU Druckluftkupplung NW 7,2 auf G3/8" Gewindeadapter Europäischer Standardadapter erforderlich, wenn keine mit dem ¼"-Schnellanschluss der Fuse Blast kompatiblen Anschlüsse gefunden werden können.
Armaturen für Holtec-Stickstoffgenerator EU
  5. Gewindedichtband
Rührstab EU Holzrührspatel (oder ähnliches nicht leitendes Werkzeug)
Schweiz
Verbrauchsmaterial (CH)
Nitrile gloves,
non-reactive,
blue
CHAcuMax
Manufacturer: MaiMed
Nitrile gloves,
non-reactive,
black
CHAcuMax
Nitrile gloves,
non-reactive,
blue
CHAcuMax
PEC*PADsCHars-imago
TX714A
CHPure11
TX715
CHPure11
Alconox,
1104-1
CHFisher Scientific
Alconox,
1104-1
CHSigma-Aldrich Chemie
Distilled waterCHMedicalcorner24
Ethyl alcohol,
purum, ~96%,
02890
Ethyl alcohol,
purum, ~96%,
02857
Glass blasting mediaCHiepco125–250 µm nominal average range
Vacuum bagsCHDelfinAnti-Static “M” filter safe bag replacement
Tools (CH)
Dremel Versa CH Dremel Diese rotierende Motorbürste dient zum Entfernen von losem Pulver von den Teilen. Dremel beschreibt das Gerät als „wasserdicht“, macht aber keine Angaben zur Schutzart.
P050-008
CH Digi-Key
Hinweis:
EPC CH Thomann
Hersteller: Furman
USV mit 230 V CH Bechtle AG
Hersteller: APC
Hinweis:
Hinweis:
Stickstoffgenerator CH DWT Mini 5–50
Hinweis:
Stickstoffgenerator CH Flairmo N2G 40 Stickstoffgenerator
Hersteller: Flairmo
Hinweis:
Stickstoffgenerator CH Flairmo N2G 15C.
Hersteller: Flairmo
Hinweis:
Stickstoffgenerator CH Holtec HSS-7 (Hochgeschwindigkeitsstahl)
Hinweis:
Armaturen für Holtec-Stickstoffgenerator CH
  5. Gewindedichtband
Rührstab CH Holzrührspatel (oder ähnliches nicht leitendes Werkzeug)
Vereinigtes Königreich
Verbrauchsmaterial (UK)
Nitrile gloves,
non-reactive,
black
UKBrosch Direct
Nitrile gloves,
non-reactive,
blue, extra strong
UKBrosch Direct
PEC*PADsUKCinestore
TX714A
UKFisher Scientific
Alconox,
1104-1
UKSigma-Aldrich Chemie
Distilled waterUKReAgent Chemicals
Ethyl alcohol,
purum
UKFisher Scientific
Glass blasting mediaUKKey AbrasivesAverage nominal range:
106–212 µm
150–250 µm
Glass blasting mediaUKAmazon40–50 grit / 313–387 μm, compatible with Fuse Blast
Vacuum bagsUKDelfinAnti-Static “M” filter safe bag replacement
Werkzeuge (UK)
Dremel Versa (PC10-1/10) UK Dremel Diese rotierende Motorbürste dient zum Entfernen von losem Pulver von den Teilen. Dremel beschreibt das Gerät als „wasserdicht“, macht aber keine Angaben zur Schutzart.
2,5 m Netzkabel
P052-008
BS1363A auf IEC 320-C19
UK Digi-Key
Hinweis:
EPC UK Thomann
Hersteller: Furman
USV mit 230 V UK Bechtle AG
Hersteller: APC
Hinweis:
Online-Doppelwandler-USV mit 230 V UK Ballicom
Hinweis:
Stickstoffgenerator UK DWT Mini 5–50
Hinweis:
Stickstoffgenerator UK Flairmo N2G 40 Stickstoffgenerator
Hersteller: Flairmo
Hinweis:
Stickstoffgenerator UK Flairmo N2G 15C
Hersteller: Flairmo
Hinweis:
Stickstoffgenerator UK Holtec HSS-7 (Hochgeschwindigkeitsstahl)
Hinweis:
Armaturen für Holtec-Stickstoffgenerator UK
  5. Gewindedichtband
Rührstab UK Holzrührspatel (oder ähnliches nicht leitendes Werkzeug)
Japan
Tools (JP)
Aufspann-/Abspanntransformator Japan Transformatoren Transformator für 120-V-Geräte in Regionen mit 100-V-Netzstrom.
Stickstoffgenerator Japan Flairmo N2G 40 Stickstoffgenerator
Hersteller: Flairmo
Hinweis:
Stickstoffgenerator Japan Flairmo N2G 15C
Hersteller: Flairmo
Hinweis:
