Dimensional inaccuracy (SLA)
Dimensional inaccuracy refers generally to any case where the final dimensions of printed parts do not match the dimensions of your model, within expected tolerances. Dimensional accuracy is affected by part design, material selection, part setup, post-processing, and printer maintenance, so issues can be multifaceted.
Tip:
Consult the design specifications for your printer (e.g., the Form 4 generation) for more information about maximum/minimum feature sizes and expected tolerances.
Visual symptoms
  • Printed part dimensions do not match designed or model dimensions within expected tolerances
Common causes
  • Model design
  • Material selection
  • Support placement
  • Part orientation
  • Support touch tip size
  • Layer thickness
  • Dirty optical components
Troubleshooting steps
Note:
Make sure that your firmware and PreForm versions are up to date. To check your printer’s firmware version, refer to the support article Checking the firmware version for Formlabs SLA printers. To update your PreForm version, refer to the FAQ article How do I update PreForm?.
When initially troubleshooting dimensional accuracy issues, consider your goals:
GoalPossible solutions
A flat, smooth surfaceReduce the number of supports on that surface. If necessary, reorient the part so that the surface does not need to be supported.
Accurate hole sizingSupport the edges of the hole appropriately but try not to cover it with the support structure.
Roundness
  • Add more supports.
  • Use a stiffer material, if one is available.
Functional assemblies
  • Reduce the number of supports on the interfacing surfaces.
  • Check the tolerances of your model and add space between the interfacing surfaces if needed. Follow the design specifications for your printer (e.g., the Form 4 generation) as a reference.
  • Consider using the Fit Tuning feature (Form 3/Form 3B) if the issue is apparent in the XY plane (i.e., parallel to the build platform).
  • Read this Formlabs whitepaper (EN only) for more information about 3D printed assemblies.
Smooth surface finish
  • Reduce the number of supports on cosmetic surfaces.
  • Reduce the touch tip size, if doing so will not cause your models to be undersupported.
  • Reduce the layer thickness, if possible.
  • Clean your printer’s optical surfaces.
Check the model in PreForm
Part orientation and support are critical to print success and dimensional accuracy. When troubleshooting dimensional accuracy issues, be sure to:
  1. Orient your models so that supports can be placed on non-cosmetic or less-critical surfaces.
  2. Place enough supports and use large enough touchpoints to hold the model steady during printing.
  3. Pick lower layer thicknesses for fine details or smoother layer lines.
Follow post-processing recommendations
Proper post-processing is key for accuracy. Make sure that you are following the washing and post-curing recommendations for your resin.
Check your printer’s optical surfaces
Contaminated optical surfaces generally lead to more severe print defects. Optical surfaces include:
  • Resin tank film (Form 4, Form 3L, and Form 3 generations)
  • Release texture (Form 4 generation)
  • Optical window (Form 2 printers and Form 3L and Form 3 generations)
  • Main mirror (Form 2)
Mild to moderate contamination on these surfaces might not cause failed prints but could still affect dimensional accuracy.
  1. Check your resin tank for cured resin or other debris.
  2. Check the release texture (Form 4 generation) or optical window (Form 2 printers and Form 3L and Form 3 generations).
  3. Check your resin tanks for damage and replace if needed.
Select the correct material for your application
Formlabs offers dozens of materials with different physical properties and intended applications. For the best experience, make sure your selected material is well-suited for your application. For example, stiffer resins tend to hold their shape better during printing, which may result in better dimensional accuracy.
Consult the Formlabs Materials Catalog or materials comparison tool to find the right material for your prints.
Adjust Fit Tuning (Form 3 generation only)
The Fit Tuning test was designed for dentistry applications, but it can sometimes help with specific types of dimensional accuracy issues on other models. It is best suited for adjusting the fit of vertically-printed posts into matching slots or holes. Adjusting Fit Tuning only changes aspects of your models in the XY plane (i.e., parallel to the build platform), so it cannot address dimensional issues occurring in the Z-axis. If your use case matches this, follow the instructions in this article to print the Fit Tuning test and adjust your printer.
Contacting Formlabs Support
If the troubleshooting steps above do not resolve the print failure, contact Formlabs Support or your authorized reseller.
To help us provide the fastest and most effective response to your issue, please provide the following information:
  1. Upload diagnostic logs
  2. Serial name of the printer
    • The serial name is on the back panel of the printer in the format AdjectiveAnimal or Machine-AdjectiveAnimal, where “Machine” is the machine type.
    • On a Form 2: Tap the printer icon on the home screen. The Your Printer screen appears.
    • On other Formlabs SLA printers (Form 3 or later): Tap the printer icon on the Home screen.
  3. Troubleshooting steps attempted
    • Example: “I reoriented the model in PreForm. I inspected the resin tank and did not notice any damage, clouding, or debris.”
  4. Resin formulation and lot number
  5. Layer thickness
    • On a Form 2: Tap the queue icon on the home screen. The Jobs screen appears.
    • On other Formlabs SLA printers (Form 3 or later): Tap Queue on the Home screen. The Queue screen appears.
  6. Relevant FORM files
    • If available, attach FORM files of the model to the support request.
  7. Previous attempts to print the part and any successful prints
    • Example: “I printed the file part2.form three times previously. The first and second were successful. The third one failed.”
