Dental LT Comfort Resin is engineered to be more flexible than Dental LT Clear Resin, making it more durable and more comfortable for patients. The splint gradually becomes more flexible in the mouth, providing optimal comfort and improving patient compliance with treatment plans.
Dental LT Comfort Resin also provides exceptional clarity, reducing polishing time.
Recommended for:
Dental LT Comfort Resin prints at 100 microns.
| Dental LT Comfort Resin | Dental LT Clear Resin | |
| Ultimate tensile strength (MPa) | 29 | 52 |
| Tensile modulus (MPa) | 994 | 2080 |
| Elongation at break (%) | 33 | 12 |
| Durometer/Shore Hardness | 75D | 78D |
| Flexural modulus (GPa) | 0.64 | 0.23 |
| IZOD Impact strength (J/m) | 98 | 35 |
To learn more about the performance properties of Formlabs resins, refer to the library of material properties data sheets.
Required resources
Made by Formlabs:
Made by third parties:
Printing with Dental LT Comfort Resin
To prepare a model for printing in PreForm, follow the instructions in the manufacturing guide. When printing occlusal splints and guards, follow the steps in our application guide 3D Printing Splints with Formlabs SLA 3D Printers [EN] [DE] [ES] [FR] [IT] [JA] [KO] [PT] [RU] [ZH]:
Note:
If you encounter fit issues when the default Dental Workspace preset, reduce the angle of the splints relative to the build platform.
Finishing
The Form Wash agitates the solvent bath and removes parts from the bath after a set time. Wash parts according to the application guide. Pay particular attention to information that affects mechanical properties or biocompatibility requirements.
If the model is hollow or has internal channels, ensure liquid resin is flushed out thoroughly from these features. If you encounter fit issues, be sure to clean the splints extensively, including flushing with fresh solvent and using compressed air. Allow parts to fully dry before post-curing.
Post-curing requirements
Dental LT Comfort Resin requires post-curing to reach its optimal mechanical properties. Refer to the application guide for post-curing recommendations.
Newly post-cured splints have a slight green tint. Over time the part will photobleach to a clear blue hue.
Follow post-curing recommendations from Formlabs for the clearest and best possible results. Improper post-curing can lead to suboptimal mechanical and biocompatibility properties.
Additional resources
