Ultimate Tensile Strength (MPa)
Tensile Modulus (GPa)
Flexural Modulus (GPa)
Heat Deflection Temp @0.45 MPa (°C)
Elongation at Break (%)
Notched IZOD (J/m)
Materials Catalog. Advanced Resins and Powders for 3D Printing.
Material Compare
Try Out Now
Nylon 12 Powder 10 kg
Popular
SLSRobustHigh StrengthWear ResistantUV ResistantBiocompatible
Nylon 12 Powder is a general purpose, versatile, and biocompatible material with high detail and great dimensional accuracy. As the go-to material for SLS 3D printing, it is ideal for both functional prototyping and end-use production of complex assemblies and durable parts with high environmental stability.
CompareSample
Tough 2000 Resin
Tough 2000 Resin
Popular
SLAStiff & StrongABS-LikeHigh StrengthWear ResistantImpact Resistant
Tough 2000 Resin has similar strength and stiffness to ABS plastics, making it ideal for functional parts that are difficult to bend and will hold up with extended use. Choose Tough 2000 Resin for prototyping strong and sturdy parts that should not bend easily, as well as jigs and fixtures requiring minimal deflection.
CompareSample
Grey Resin V4.1
Grey Resin V4.1
New
SLAStiff & StrongMatteFast PrintingHigh AccuracyFine Details
Grey Resin is ideal for general-purpose prototyping and detailed models, offering a matte finish, opaque appearance, and precise details. Grey Resin V4 is compatible with Form 3 and Form 2 Series printers, while Grey Resin V5 for the Form 4 Series offers faster speed and improved mechanical properties.
CompareSample
Black Resin V4.1
Black Resin V4.1
New
SLAStiff & StrongMatteHigh StrengthHigh AccuracyFine Details
Black Resin is perfect for general-purpose prototyping and design, and models with intricate details. Black Resin V4.1 is compatible with Form 3 Series printers, produces deeper black parts, and offers improved print reliability compared to Black Resin V4.0. Choose Black Resin V5 on the Form 4 Series for three times faster print speed and improved mechanical properties.
CompareSample
Clear Resin V4.1
Clear Resin V4.1
New
SLAStiff & StrongHigh StrengthTransparentHigh AccuracyFine Details
Clear Resin is a rigid material that polishes to near optical transparency. Clear Resin V4.1 is compatible with Form 3 Series printers and creates more color-neutral and transparent parts compared to Clear Resin V4.0. Choose Clear Resin V5 on the Form 4 Series for three times faster print speed and improved mechanical properties.
CompareSample
Clear Cast Resin
Clear Cast Resin
New
SLAFine DetailsInvestment CastingTransparentHigh Accuracy
Clear Cast Resin is a resin designed for investment casting, to directly print patterns that can be invested and cast. It has an extremely low thermal expansion, low ash, and no trace heavy metals.
CompareSample
White Resin V5
White Resin V5
New
SLAStiff & StrongMatteHigh StrengthHigh AccuracyFine DetailsPost-Curing Optional
White Resin is a versatile General Purpose Resin, offering an optimal balance of speed, accuracy, aesthetics, and mechanical properties to create parts that rival injection molding. Formulated specifically for the Form 4 Series, White Resin V5 prints three times faster than the previous version.
CompareSample
Fast Model Resin
Fast Model Resin
New
SLAPost-Curing OptionalHigh ThroughputFast PrintingHigh Strength
Fast Model Resin is Formlabs’ fastest resin, capable of printing at speeds of over 100 mm per hour. Print dental models in minutes or large prototypes in less than two hours. Formulated specifically for the Form 4 ecosystem, this material prints three times faster than the previous version.
CompareSample
Black Resin V5
Black Resin V5
New
Black Resin is a versatile General Purpose Resin, offering an optimal balance of speed, accuracy, aesthetics, and mechanical properties to create parts that rival injection molding. Formulated specifically for the Form 4 ecosystem, Black Resin V5 prints 3 times faster than the previous version.
CompareSample
Color Kit (Form 4)
Color Kit (Form 4)
Color Kit is the first integrated color mixing solution for resin 3D printing. It enables 3D printing in a range of colors without the manual work of finishing, dying, or painting.
Color Kit contains a Color Base cartridge and all five Color Pigments. Use Color Kit to mix and print matte, opaque parts in a range of colors without the manual work of finishing and painting.
CompareSample
Alumina 4N Resin
Alumina 4N Resin
SLAHeat ResistantComplex WorkflowUltra StiffUltra High StrengthCeramic
Alumina 4N Resin is the first accessible high-density and high-purity technical ceramic 3D printing material with exceptional performance in extreme environments: thermally resistant, hard, abrasion resistant, mechanically strong, and chemically inert. Alumina 4N is a Form X material with an advanced workflow suited for expert users.
CompareSample
Elastic 50A Resin V2
SLATranslucentElastomericSoft Silicone-like
Elastic 50A Resin V2 is a soft, translucent elastomer with a 50A Shore durometer that is ideal for prototyping parts normally produced with softer rubbers and silicones. Parts printed in Elastic 50A Resin will bend, stretch, compress, and hold up to repeated cycles without tearing, and spring back quickly to their original shape.
CompareSample
BioMed Elastic 50A Resin
SLAElastomericSoft Silicone-likeBiocompatibleTranslucent
BioMed Elastic 50A Resin is a soft, elastic, and transparent material for biocompatible applications requiring comfort and long-term skin (>30 days) or short-term mucosal membrane contact (<24 hours). BioMed Elastic 50A Resin is manufactured in our ISO 13485 certified facility.
CompareSample
Silicone 40A Resin
Silicone 40A Resin
SLAElastomericSoft100% SiliconeWear ResistantTear Resistant
Silicone 40A Resin is the first accessible 100% silicone 3D printing material, using Formlabs’ patent-pending Pure Silicone Technology™. Eliminate molding and labor-intensive casting processes by directly printing soft, pliable, and durable silicone parts in house in a matter of hours.
CompareSample
BioMed White Resin
BioMed White Resin
SLASterilizableMatteBiocompatible
BioMed White Resin is a rigid material for biocompatible applications requiring long-term skin (>30 days) or short-term bone, tissue, dentin, and mucosal membrane contact (<24 hours). BioMed White Resin is manufactured in our ISO 13485 facility.
CompareSample
BioMed Amber Resin
BioMed Amber Resin
SLAStiff & StrongTranslucentSterilizableBiocompatibleUltra High Strength
BioMed Amber Resin is a strong, stiff material for biocompatible applications requiring long-term skin (>30 days) or short-term bone, tissue, dentin, and mucosal membrane contact (<24 hours). Parts printed with BioMed Amber Resin are compatible with common solvent disinfection and sterilization methods.
CompareSample
Custom Tray Resin
Custom Tray Resin
SLACustom Impression TraysBiocompatibleTranslucent
Custom Tray Resin is a fast-printing biocompatible material used to directly print custom impression trays for implants, dentures, crowns and bridges, and other comprehensive cases. Digitally manufactured impression trays provide consistent, accurate impressions for high-quality dentistry.
CompareSample
Surgical Guide Resin
SLASterilizableTranslucentBiocompatibleSurgical Guides
Surgical Guide Resin is an autoclavable, biocompatible resin for 3D printing dental surgical guides, drilling templates, pilot drill guides, and device sizing templates for implant placement. Surgical Guide Resin was rigorously tested to meet solvent disinfection and autoclave sterilization standards for implant systems.
CompareSample
Durable Resin
Durable Resin
SLAPliableLow FrictionWear ResistantImpact ResistantPE-Like
Durable Resin is a pliable, impact-resistant, and lubricious material for squeezable parts and low-friction assemblies. Parts printed in Durable Resin are robust and have low friction, with similar strength and stiffness to polyethylene (PE) and a coefficient of friction is comparable to Delrin® (POM).
CompareSample
High Temp Resin
High Temp Resin
SLATranslucentFine DetailsHeat ResistantUltra Stiff
High Temp Resin has a heat deflection temperature (HDT) of 238 °C @ 0.45 MPa — the highest among Formlabs resins. Choose it to print detailed, precise prototypes and end use parts with high thermal stability, such as molds and inserts, parts exposed to hot air, gas, and fluid flow, as well as heat-resistant mounts, housings, and fixtures.
CompareSample
Tough 1500 Resin V1
Tough 1500 Resin V1
SLAPP-LikePliableWear ResistantImpact ResistantSkin Contact
Tough 1500 Resin is a resilient, skin-safe material that offers similar strength and stiffness to polypropylene (PP). Choose Tough 1500 Resin for stiff and pliable parts that bend and spring back quickly, prototypes that repeatedly bend and quickly return to shape, and jigs and fixtures requiring repeated deflection.
CompareSample
Model V2 Resin
Model V2 Resin
SLAMatteFine DetailsHigh Accuracy
Model Resin V2 is the legacy formulation of Model Resin V3. It offers good aesthetics and accuracy, but prints more slowly than Model Resin V3. Model Resin V2 is compatible with Form 3 and Form 2 Series printers, while Precision Model Resin for the Form 4 Series offers better accuracy, faster speed, and improved aesthetics.
CompareSample
White Resin V4
White Resin V4
White Resin is perfect for general-purpose prototyping and design, and models with intricate details. White Resin V4 is compatible with Form 3 and Form 2 Series printers. Choose White Resin V4.1 on the Form 3 Series for brighter white parts or White Resin V5 on the Form 4 Series for three times faster print speed and improved mechanical properties.
CompareSample
Clear Resin V4
Clear Resin V4
Clear Resin is a rigid material that polishes to near optical transparency. Clear Resin V4 is compatible with Form 3 and Form 2 Series printers. Choose Clear Resin V4.1 on the Form 3 Series for more color-neutral and transparent parts or Clear Resin V5 on the Form 4 Series for three times faster print speed and improved mechanical properties.
CompareSample
Grey Resin V4
Grey Resin V4
CompareSample
Nylon 11 CF Powder 6 kg
SLSHeat ResistantCarbon Fiber FilledUltra StiffImpact ResistantUltra High Strength
Nylon 11 CF Powder is a carbon fiber-filled material, perfect for applications that require both superior stiffness and strength. Produce lightweight, rigid parts that remain structurally and thermally stable and can sustain repeated impact. Nylon 11 CF Powder requires to be printed on Fuse 1+ 30W with inert atmospheric control.
CompareSample
Nylon 11 Powder 6 kg
SLSHigh StrengthWear ResistantImpact ResistantUV ResistantSkin Contact
Nylon 11 Powder is a strong and highly ductile bio-based material. It is ideal for robust biocompatible parts, functional prototyping, and producing custom or low volume end-use parts that need to bend or take impact. For best results, print Nylon 11 Powder using the Fuse 1+ 30W and optional inert atmospheric control.
CompareSample
Color Kit (Form 3)
Color Kit (Form 3)
SLAFine DetailsMatteCustom Colors
Color Kit is the first integrated color mixing solution for resin 3D printing. It enables 3D printing in a range of colors without the manual work of finishing, dying, or painting. Color Kit contains a Color Base cartridge and all five Color Pigments to mix and print matte, opaque parts in a range of colors.
CompareSample
Cyan Pigment
Cyan Pigment
SLACustom Colors
SLACustom Colors
Cyan Pigment adds blue hues to Color Resin when mixed with Color Base Resin. Color Kit is the first integrated color mixing solution for resin 3D printing. It enables 3D printing in a range of colors without the manual work of finishing, dying, or painting.
CompareSample
White Pigment
White Pigment
SLACustom Colors
SLACustom Colors
White Pigment creates lighter shades of Color Resin when mixed with Color Base Resin. Color Kit is the first integrated color mixing solution for resin 3D printing. It enables 3D printing in a range of colors without the manual work of finishing, dying, or painting.
CompareSample
Rigid 10K Resin
Rigid 10K Resin
Popular
SLAHeat ResistantHigh StrengthGlass FilledUltra StiffFine Details
Rigid 10K Resin is highly glass-filled and extremely stiff material that is similar to glass and fiber-filled thermoplastics. Use Rigid 10K Resin to rapidly produce molds, jigs, dies, and other tools, as well as functional prototypes and end use parts requiring dimensional accuracy and stability under high temperatures and pressures.
CompareSample
True Cast Resin
True Cast Resin
New
SLAPatterns for Casting & PressingHigh AccuracyFine DetailsClean BurnoutCasting
True Cast Resin is a wax-filled 3D printing material, designed for precision casting of intricate jewelry and complex engineering components up to 5 mm.
CompareSample
Tough 1500 Resin V2
Tough 1500 Resin V2
New
SLAPliablePP-LikeWear Resistant
Tough 1500 Resin V2 is a resilient material with strength, stiffness, and toughness comparable to polypropylene (PP), offering exceptional resistance to fractures, impacts, and shattering.
CompareSample
White Resin V4.1
White Resin V4.1
New
SLAStiff & StrongFine DetailsHigh StrengthHigh Accuracy
White Resin is perfect for general-purpose prototyping and design, and models with intricate details. White Resin V4.1 is compatible with Form 3 Series printers and produces brighter white parts compared to White Resin V4. Choose White Resin V5 on the Form 4 Series for three times faster print speed and improved mechanical properties.
CompareSample
Nylon 12 Tough Powder 10 kg
New
Nylon 12 Tough Powder offers the best-in-class refresh rate among Nylon powders, high ductility, and great dimensional accuracy across the build chamber. Print more durable parts for prototyping and small batch production that have reduced warpage without sacrificing strength.
CompareSample
Nylon 12 White Powder 10 kg
New
Nylon 12 White Powder combines all of the great qualities of the general purpose and biocompatible Nylon 12 Powder with the customizability of white parts. Create functional prototypes and end-use customer-facing parts that can be easily dyed to match brand aesthetics as well as medical devices and models with high contrast and detail.
CompareSample
Grey Resin V5
Grey Resin V5
New
SLAStiff & StrongMatteFast PrintingHigh AccuracyFine DetailsPost-Curing Optional
Grey Resin is a versatile General Purpose Resin, offering an optimal balance of speed, accuracy, aesthetics, and mechanical properties to create parts that rival injection molding. Formulated specifically for the Form 4 Series, Grey Resin V5 prints three times faster than the previous version.
CompareSample
Clear Resin V5
Clear Resin V5
New
SLAStiff & StrongHigh StrengthTransparentHigh AccuracyFine DetailsPost-Curing Optional
Clear Resin is an exceptionally clear 3D printing resin formulated to leverage the new Form 4 ecosystem, offering an optimal balance of fast print speed, high accuracy, transparency, and strong mechanical properties to create parts that can be coated or polished to rival acrylic.
CompareSample
New
SLAMatteHigh AccuracyFine Details
Precision Model Resin is a high-accuracy material for creating restorative models with high opacity, beige color, and a smooth, matte finish to capture fine details and create crisp margin lines. Formulated specifically for the Form 4 ecosystem, this material prints three times faster than the previous version.
CompareSample
Flame Retardant Resin
SLAStiff & StrongHeat ResistantRobustLow CreepUL94 V0 Certified
Flame Retardant Resin is a UL 94 V-0 certified, halogen-free material with favorable flame, smoke, and toxicity (FST) ratings for creating self-extinguishing parts. Parts printed in FR Resin are stiff and creep-resistant, and will perform well long-term in indoor and industrial environments with high temperatures or ignition sources.
CompareSample
Color Base Resin
Color Base Resin
SLAFine DetailsCustom ColorsMatte
Color Kit is the first integrated color mixing solution for resin 3D printing. It enables 3D printing in a range of colors without the manual work of finishing, dying, or painting. Color Base Resin is the foundation to mix with any Color Kit pigment and create Color Resin.
CompareSample
BioMed Flex 80A Resin
SLATranslucentElastomericHard Rubber-LikeBiocompatible
BioMed Flex 80A Resin is a firm, flexible, and transparent material for biocompatible applications requiring durability and long-term skin (>30 days) or short-term mucosal membrane contact (<24 hours). BioMed Flex 80A Resin is manufactured in our ISO 13485 certified facility.
CompareSample
BioMed Durable Resin
SLABiocompatibleImpact ResistantWear ResistantTransparent
BioMed Durable Resin is a transparent 3D printing material for biocompatible applications requiring impact, shatter, and abrasion resistance, as well as long-term skin (>30 days) and mucosal membrane (>30 hours) or short-term tissue, bone, and dentin contact (<24 hours).
CompareSample
BioMed Black Resin
BioMed Black Resin
BioMed Black Resin is a rigid, matte material for biocompatible applications requiring long-term skin (>30 days) or short-term mucosal membrane contact (<24 hours). Parts printed with BioMed Black Resin are compatible with common solvent disinfection and sterilization methods. BioMed Black Resin is manufactured in our ISO 13485 facility.
CompareSample
Castable Wax 40 Resin
SLAFine DetailsWax FilledInvestment Casting
Castable Wax 40 Resin is a 40% wax-filled material that offers the easiest workflow on the market for 3D printing and casting challenging, highly detailed designs, from intricate bridal jewelry to large demanding pieces. It supports a wide range of casting conditions and gypsum investments, has low expansion, and burns out cleanly.
CompareSample
ESD Resin
ESD Resin
SLAStiff & StrongABS-LikeESD-SafeRobust
ESD Resin is a specialty material for producing custom ESD-safe prototypes and production tooling to increase operational efficiency and improve the yield of electronics manufacturing lines. Parts printed in ESD Resin are static-dissipative, repel dust and powder, and have high modulus and impact strength similar to ABS.
CompareSample
Castable Wax Resin
Castable Wax Resin
Castable Wax Resin is a 20% wax-filled material for casting that can capture intricate features and offers a smooth surface finish for accurate castings with zero ash content and clean burnout. It is ideal for ultrafine structures in jewelry, as well as highly accurate patterns for casting and pressing dental prosthetics.
CompareSample
BioMed Clear Resin
BioMed Clear Resin
SLASterilizableRobustHigh StrengthBiocompatibleTransparent
BioMed Clear Resin is a hard, strong, and wear-resistant material for biocompatible applications requiring long-term skin (>30 days), breathing gas pathways, and mucosal membrane contact (>30 hours) or short-term bone, tissue, and dentin (<24 hours). Parts printed with BioMed Clear Resin are compatible with common sterilization methods.
CompareSample
Flexible 80A Resin
Flexible 80A Resin
SLATranslucentHard Rubber-LikeElastomericWear Resistant
Flexible 80A Resin a stiff, soft-touch, translucent elastomer with an 80A Shore durometer that is ideal for prototyping rubber-like parts with the flexibility of harder rubber or TPU. Parts printed in Flexible 80A Resin can withstand bending, flexing, and compression, even through repeated cycles.
CompareSample
Rigid 4000 Resin
Rigid 4000 Resin
SLAHigh StrengthGlass FilledUltra StiffPEEK-LikeFine Details
Rigid 4000 Resin is a glass-filled resin that is stiff, precise, and offers high thermal and chemical resistance. It prints with a smooth, polished finish and is ideal for industrial parts that need to withstand significant load without bending. Parts printed in Rigid 4000 have similar stiffness to PEEK and PEKK thermoplastics.
CompareSample
Grey Pro Resin
Grey Pro Resin
SLAFine DetailsMatteLow CreepHigh Strength
Grey Pro Resin is a tough and heat-resistant material with a low creep, offering improved performance compared to Formlabs General Purpose Resins. Grey Pro Resin is compatible with Form 2 and Form 3 Series printers, while Grey Resin V5 for the Form 4 Series offers improved mechanical properties and faster speed, replacing Grey Pro Resin.
CompareSample
Black Resin V4
Black Resin V4
Black Resin is perfect for general-purpose prototyping and design, and models with intricate details. Black Resin V4 is compatible with Form 3 and Form 2 Series printers. Choose Black Resin V4.1 on the Form 3 Series for deeper black parts and improved print reliability or Black Resin V5 on the Form 4 Series for three times faster print speed and improved mechanical properties.
CompareSample
Model Resin
Model Resin
SLAFine DetailsMatteFast PrintingHigh Accuracy
Model Resin is a fast-printing material for the production of accurate restorative models. Model Resin V3 is compatible with Form 3 and Form 2 Series printers, while Precision Model Resin for the Form 4 Series offers better accuracy, faster speed, and improved aesthetics.
CompareSample
Draft Resin
Draft Resin
SLAFine DetailsHigh AccuracyHigh ThroughputFast Printing
Draft Resin prints up to four times faster than Formlabs' General Purpose Resins on Form 3 and Form 2 Series printers, and is perfect for initial prototypes, rapid iterations, and orthodontic models. Fast Model Resin for the Form 4 Series offers even faster speed and improved mechanical properties.
CompareSample
TPU 90A Powder 6 kg
TPU 90A Powder 6 kg
SLSElastomericImpact ResistantTear ResistantSkin ContactHard Rubber-Like
TPU 90A Powder is a tough elastomer with high elongation at break and superior tear strength for flexible, resilient, and skin-safe prototypes and end-use parts. It is ideal for flexible functional parts that withstand the demands of everyday use.
CompareSample
Nylon 12 GF Powder 6 kg
SLSStiff & StrongHeat ResistantLow CreepGlass FilledUV Resistant
Nylon 12 GF Powder is a glass-filled, biocompatible material with enhanced stiffness and heat resistance for demanding industrial environments. Choose this material to produce stiff functional prototypes or end-use parts for applications where structural rigidity and thermal stability are critical.
CompareSample
Soft Tissue Starter Pack
Gingiva MasksMultiple ShadesFlexible
Soft Tissue Starter Pack enables you to create your own Soft Tissue Resin in customizable dark, medium, and light pink shades to 3D print flexible gingiva masks for use in combination with rigid dental models to confidently check implant prosthetics by adding removable soft tissue components to your model production.
CompareSample
Black Pigment
Black Pigment
SLACustom Colors
SLACustom Colors
Black Pigment creates darker shades of Color Resin when mixed with Color Base Resin. Color Kit is the first integrated color mixing solution for resin 3D printing. It enables 3D printing in a range of colors without the manual work of finishing, dying, or painting.
CompareSample
Magenta Pigment
Magenta Pigment
SLACustom Colors
SLACustom Colors
Magenta Pigment adds pink hues to Color Resin when mixed with Color Base Resin. Color Kit is the first integrated color mixing solution for resin 3D printing. It enables 3D printing in a range of colors without the manual work of finishing, dying, or painting.
CompareSample
Yellow Pigment
Yellow Pigment
SLACustom Colors
SLACustom Colors
Yellow Pigment adds yellow hues to Color Resin when mixed with Color Base Resin. Color Kit is the first integrated color mixing solution for resin 3D printing. It enables 3D printing in a range of colors without the manual work of finishing, dying, or painting.
CompareSample
Popular
CompareSample
Rigid 10K Resin
Rigid 10K Resin
Popular
CompareSample
Tough 2000 Resin
Tough 2000 Resin
Popular
CompareSample
True Cast Resin
True Cast Resin
New
CompareSample
Grey Resin V4.1
Grey Resin V4.1
New
CompareSample
Tough 1500 Resin V2
Tough 1500 Resin V2
New
CompareSample
Black Resin V4.1
Black Resin V4.1
New
CompareSample
White Resin V4.1
White Resin V4.1
New
CompareSample
Clear Resin V4.1
Clear Resin V4.1
New
CompareSample
New
CompareSample
Clear Cast Resin
Clear Cast Resin
New
CompareSample
New
CompareSample
White Resin V5
White Resin V5
New
CompareSample
Grey Resin V5
Grey Resin V5
New
CompareSample
Fast Model Resin
Fast Model Resin
New
CompareSample
Clear Resin V5
Clear Resin V5
New
CompareSample
Black Resin V5
Black Resin V5
New
CompareSample
New
CompareSample
Color Kit (Form 4)
Color Kit (Form 4)
CompareSample
CompareSample
Alumina 4N Resin
Alumina 4N Resin
CompareSample
Color Base Resin
Color Base Resin
CompareSample
CompareSample
CompareSample
CompareSample
CompareSample
Silicone 40A Resin
Silicone 40A Resin
CompareSample
BioMed Black Resin
BioMed Black Resin
CompareSample
BioMed White Resin
BioMed White Resin
CompareSample
CompareSample
BioMed Amber Resin
BioMed Amber Resin
CompareSample
ESD Resin
ESD Resin
CompareSample
Custom Tray Resin
Custom Tray Resin
CompareSample
Castable Wax Resin
Castable Wax Resin
CompareSample
CompareSample
BioMed Clear Resin
BioMed Clear Resin
CompareSample
Durable Resin
Durable Resin
CompareSample
Flexible 80A Resin
Flexible 80A Resin
CompareSample
High Temp Resin
High Temp Resin
CompareSample
Rigid 4000 Resin
Rigid 4000 Resin
CompareSample
Tough 1500 Resin V1
Tough 1500 Resin V1
CompareSample
Grey Pro Resin
Grey Pro Resin
CompareSample
Model V2 Resin
Model V2 Resin
CompareSample
Black Resin V4
Black Resin V4
CompareSample
White Resin V4
White Resin V4
CompareSample
Model Resin
Model Resin
CompareSample
Clear Resin V4
Clear Resin V4
CompareSample
Draft Resin
Draft Resin
CompareSample
Grey Resin V4
Grey Resin V4
CompareSample
TPU 90A Powder 6 kg
TPU 90A Powder 6 kg
CompareSample
CompareSample
CompareSample
CompareSample
CompareSample
Color Kit (Form 3)
Color Kit (Form 3)
CompareSample
Black Pigment
Black Pigment
SLACustom Colors
SLACustom Colors
CompareSample
Cyan Pigment
Cyan Pigment
SLACustom Colors
SLACustom Colors
CompareSample
Magenta Pigment
Magenta Pigment
SLACustom Colors
SLACustom Colors
CompareSample
White Pigment
White Pigment
SLACustom Colors
SLACustom Colors
CompareSample
Yellow Pigment
Yellow Pigment
SLACustom Colors
SLACustom Colors
CompareSample
What Material is Right for You?
Compare All Materials
Overview
Material properties1
1: Post-cured measurements. See more details in material properties data
