Using Tough 1500 Resin V2
Tough 1500 Resin produces stiff and pliable parts that bend and spring back quickly under repeated use. This material is ideal for functional prototypes, jigs and fixtures, and connectors undergoing temporary deflection or high impacts.
alt text
Formlabs developed Tough 1500 Resin to bridge the gap in mechanical properties between Tough 1000 Resin and Tough 2000 Resin. Tough 1500 Resin performs similarly to polypropylene in terms of strength and stiffness, which makes it an excellent choice for prototyping products that will be made from that material.
Recommended for:
  • Prototyping
  • Functional assemblies
  • Snap fits
  • Hinges
  • Jigs and fixtures
Note:
  • To learn more about the performance or specific material properties of Tough 1500 Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
  • As a result of its reformulation for improved mechanical properties, Tough 1500 Resin V2 has a stronger odor than its predecessor. This odor does not pose a safety risk but may be noticeable by some users.
alt text
Tough 1500 Resin has material properties that fall between Tough 1000 Resin and Tough 2000 Resin, making it a resilient, robust and versatile material.
See the table below for a comparison of relevant material properties:
ResinTough 1000 Resin (post-cured)Tough 1500 Resin V2 (post-cured)Tough 2000 Resin V2 (post-cured)
Ultimate Tensile Strength (MPa)26.33440.4
Tensile Modulus (MPa)9321,4601,800
Elongation at Break (%)18015579
Gardner Impact Strength @ 1/32 in (0.8 mm) (J)13.15.91.6
Work of Fracture (J/m2)32001,011305
Heat Deflection Temp @ 0.45 MPa (ºC)55.36670
To learn more about the performance properties of Formlabs resins, refer to the library of material properties datasheets.
Required resources:
Printing with Tough 1500 Resin
  1. Open a model.
  3. Orient to preserve fine details.
  4. Generate supports.
Always use supports when printing with Tough 1500 Resin. Do not print parts directly on the build platform.
  1. Send the print job to the printer.
PreForm has two settings for Tough 1500 Resin: 50 microns and 100 microns. For more information about available settings and compatibility, see the support article Choosing the right material.
Printing and installing a cartridge shim
The newest Tough family of resins (Tough 1000 Resin V1, Tough 1500 Resin V2, and Tough 2000 Resin V2) cause the resin cartridge bite valve to swell over time. A swollen bite valve dispenses resin more slowly, especially towards the end of a cartridge’s life. In a limited and contained number of cases, the bite valve can ultimately fall off the resin cartridge entirely, leading to a significant resin spill.
If your resin cartridge is from lot number 20251022 or later, it is not at risk for a resin spill, so you can print a shim that mitigates poor dispensing even if the valve swells. To prevent dispense interruptions caused by valve swelling, Formlabs recommends using this shim.
If your resin cartridge’s lot number is earlier than 20251022, do not add a shim. Use it as normal until the printer displays Error 1.227.5 or Error 1.227.6, pour resin from the cartridge into the resin tank until the resin level reaches the maximum fill line marked on the resin tank frame, then discontinue use of the resin cartridge and contact Formlabs Support.
Printed cartridge shim
To install the cartridge shim:
  1. Download the shim file.
  2. Prepare the print job.
    1. Import the shim file into PreForm.
    2. Select your printer and resin type. The shim is designed to print with any General Purpose Resin, Fast Model Resin, or any resin in the Tough family.
    3. Set the Raft Type to None and generate supports. This will support the overhanging portions of the shim while leaving it flat against the build platform.
  3. Print and post-process the shim.
  4. Position the shim so that its rounded edges are aligned with the cartridge skirt.
  5. Insert the retention tabs straight into the opening next to the bite valve. They should click into place with minimal force. The flat portion between the tabs should sit next to, not on top of, the bite valve.
Installing the Tough family cartridge shim
  1. Check that the four grooves around the shim align with the walls on the bottom of the cartridge.
Finishing
The Form Wash agitates the solvent bath and removes parts from the bath after a set time. Wash parts according to the support article Form Wash time settings. Pay particular attention to information that affects mechanical properties or biocompatibility requirements.
If parts printed with Tough 1500 Resin will be used for skin contact use, wash parts in ≥99% IPA in a Form Wash for 20 minutes to comply with biocompatibility requirements.
Post-curing requirements
Tough 1500 Resin requires post-curing to reach its optimal mechanical properties. Cure parts printed in Tough 1500 Resin on supports to prevent warping or distortion. Refer to the time and temperature settings for your machine for post-curing recommendations:
Additional resources
