Technical Data Sheet
Clear Resin V5
TDS Version : V1
Revision Date : April 30, 2026
Categrory : General Purpose Resin
Material Properties
Green Properties   Method 1
Ultimate Tensile Strength 46 MPa [6700 psi] ASTM D638-14
Tensile Modulus 2200 MPa [320 ksi] ASTM D638-14
Elongation at Break 13% ASTM D638-14
  Default Post-Cure Max Strength Post-Cure Method 2,3
Tensile Properties
Ultimate Tensile Strength 51 MPa [7400 psi] 60 MPa [8700 psi] ASTM D638-14
Tensile Modulus 2600 MPa [380 ksi] 2800 MPa [410 ksi] ASTM D638-14
Elongation at Break 10% 8.0% ASTM D638-14
Flexural Properties
Flexural Strength 92 MPa [13000 psi] 105 MPa [15000 psi] ASTM D790-15
Flexural Modulus 2400 MPa [350 ksi] 2700 MPa [390 ksi] ASTM D790-15
Toughness Properties
Izod Impact Strength (Unnotched) 82 J/m [1.6 (ft·lb)/in] 85 J/m [1.6 (ft·lb)/in] ASTM D4812-11
Izod Impact Strength (Notched) 29 J/m [0.54 (ft·lb)/in] 29 J/m [0.54 (ft·lb)/in] ASTM D256-10
Gardner at 1/16" (1.6 mm) thickness <0.2 J [<2 in·lb] <0.2 J [<2 in·lb] ASTM D5420-21
Maximum Stress Intensity Factor (Kmax) 0.63 MPa·m^(1/2) [570 psi in^(1/2)] -- ASTM D5045-14
Work of Fracture (Wf) 27 J/m^2 [0.0013 (ft·lb)/in^2] -- ASTM D5045-14
Thermal Properties Default Post-Cure Max Strength Post-Cure Method
Heat Deflection Temp. at 1.8 MPa 49 °C [120 °F] 59 °C [138 °F] ASTM D648-16
Heat Deflection Temp. at 0.45 MPa 56 °C [133 °F] 74 °C [165 °F] ASTM D648-16
Glass Transition Temp (Tg) 96 °C [205 °F] -- ASTM D4065
Heat Capacity at 25 °C 1.8 J/(g·K) [0.43 BTU/(lb·°F)] -- ASTM E1269
Coefficient of Thermal Expansion (-30-140 °C) 110 (μm/m)/°C [61 (μm/m)/°F] -- ASTM E 831-19
Thermal Conductivity 0.54 W/m·K [3.7 BTU·in/(hr·ft^2·°F)] --
ASTM E1530-25
Optical Properties Default Post-Cure Max Strength Post-Cure Method
Transmission (2 mm) 85 % 85 %
ASTM D1003-21
a* (2 mm) -4.0 -4.3
ASTM E 1348-15
b* (2 mm) 7.5 5.6
ASTM E 1348-15
Transmission (10 mm) 59 % 59 %
ASTM D1003-21
a* (10 mm) -4.2 -4.0
ASTM E 1348-15
b* (10 mm) 6.0 5.9
ASTM E 1348-15
Refractive Index 1.62 1.62 ASTM D542-22
Gloss Level (60°, XY) 89 GU -- ASTM D523
Gloss Level (60°, Z) 24 GU -- ASTM D523
Electrical Properties Default Post-Cure Method 2,3
Surface Resistivity >1x10^12 Ω/sq ASTM D257
Comparative Tracking Index 600 V ASTM D3638
Dielectric Strength 16 kV/mm [410 V/mil] ASTM D149-20
Dielectric Constant (k') at 1 MHz 4.3 ASTM D150-22
Dielectric Dissipation (D) at 1 MHz 0.036 ASTM D150-22
General Properties
Bulk Density 1.21 g/cm^3 [0.0437 lb/in^3] ASTM D792
Water absorption 0.90% ASTM D570-98
Shore Hardness 80D
ASTM D2240-15
Outgassing properties
TML 1.70% ASTM E595
CVCM < 0.01% ASTM E595
WVR 0.33% ASTM E595
Workflow
Printer Compatibillity
Platform Printer Compatibility
Form 4 Form 4
Form 4B
Form 4L
Form 4BL
Compatible
Form 3 Form 3
Form 3B/+
Form 3L
Form 3BL
Not Compatible
use Clear Resin V4.1
Post Processsing
Step Recommended Hardware Default Max Strength
Washing Form Wash V2
Form Wash L V2
5 minutes in Wash Gen 2 or until clean
Drying -- 10 min
Post-Curing
Form Cure V1
Form Cure L V1
5 min at room temperature 15 min at 60 °C
Form Cure V2
Form Cure L V2
1 min at room temperature 4 min at 60°C
Handling and Storage
Shelf-life 2 years
Storage temperature 10 - 25 °C
Storage and handling notes
Review Safety Data Sheet to ensure safe handling, storage, and disposal.
Shake resin containers before printing to ensure the resin is thoroughly mixed.
To avoid contamination, do not pour resin back into cartridges.
For best performance and shelf life, store resin between 10–25 °C (50–77 °F), and keep opened resin away from direct light.
Short-term freezing during shipping is generally not detrimental to shelf life. Thaw and shake the resin cartridge thoroughly before use.
High temperatures decrease shelf life. Transient high temperature conditions (e.g., during shipping) should have a minimal effect.
Extended Properties
Representative Tensile Curves
Tensile properties were determined according to ASTM D638 (Type I). Samples were prepared following the Default post-processing workflow and conditioned at 23°C and 50% RH for 48 hours prior to testing. The displayed curve represents a single sample selected to illustrate typical stress-strain behavior. See the Material Properties section for average values.
Dynamic Mechanical Analysis (DMA)
DMA was performed using a TA Q800 with dual cantilever clamps from -20°C to 170°C using a heating rate of 3°C/min. Samples were prepared following the Default post-processing workflow. The resulting curve characterizes the material’s viscoelastic response over the temperature range and indentifies the glass transition (Tg).
Chemical Compatibility ASTM D543
Chemical resistance was evaluated according to ASTM D543. Samples were prepared following the Default post-processing workflow then fully immersed in test chemicals for durations of 1 day and 1 week. Following exposure, samples were manually wiped off and conditioned at 23°C and 50% RH for 24 hours. Mechanical testing was conducted per ASTM D638 (Type IV). Results are reported as the percentage change from non-exposed control samples. 4
Light Transmission Curve
Transmission spectra were recorded from 200 nm to 1000 nm using a Varian Cary 50 Spectrophotometer. The 3 mm sample was prepared following the Default post-processing workflow.
Thermal Expansion by TMA
The Coefficient of Thermal Expansion (CTE) was measured according to ASTM E831. Samples were prepared following the Default post-processing workflow. Testing was performed via TMA with a ramp rate of 5°C/min under a High Purity Nitrogen purge (50 cc/min).
Footnotes
  1. Material properties may vary based on part geometry, print orientation, print settings, temperature.
  2. Data was obtained from parts printed on a Formlabs printer with 100 µm Clear Resin V5 settings, washed with IPA, and post-cured according to the default workflow.
  3. Data was obtained from parts printed on a Formlabs printer with 100 µm Clear Resin V5 settings, washed with IPA, and post-cured according to the max strength workflow.
  4. Data was obtained using Grey Resin V5, and is expected to fall in the same approximate range. Some results may vary. Consult Grey Resin V5 TDS for information on printing and post-processing of samples.
  5. Transmission refers to the amount of visible light that passes through the part
    a* and b* are more commonly associated with the CIELAB color space, where they denote axes for color measurement:
    a* axis: Ranges from green to red, with negative values indicating green and positive values indicating red.
    b* axis: Ranges from blue to yellow, with negative values indicating blue and positive values indicating yellow."
