A factory reset erases all print job information, custom settings, and diagnostic logs. Upload diagnostic logs before performing a factory reset.
Formlabs regularly releases updated firmware to fix bugs and improve functionality. Check your Fuse Blast's firmware to ensure you're always up to date.
As long as the Fuse Blast has an active internet connection, it receives notification prompts about the latest firmware versions available for download.. Follow the prompts and tap Install on the Firmware Update screen to update.
Automatic firmware updates
Updating firmware
Download the latest firmware version for your Fuse Blast with PreForm, then upload and install the firmware file on the machine. Review the firmware downloads and release notes to learn more about the improvements that come with each version's release.
To update the firmware via PreForm:
Touchscreen freezes during or after firmware update
If the touchscreen freezes during or after the firmware update, perform a power cycle to restart the Fuse Blast.
To power cycle the Fuse Blast:
Decryption error / unable to update firmware
If updating via PreForm does not work, manually update the Fuse Blast’s firmware:
Perform a factory reset
If the Fuse Blast is unable to complete an automatic firmware update or displays a decryption failed error message, perform a factory reset and manually update the device using PreForm.
To troubleshoot a decryption error:
Support
If you see this error message repeatedly, contact Formlabs Support or a certified service provider and prepare your Fuse Blast for remote assistance and log collection.
