Using the PreForm Print Settings Editor (SLA)
The PreForm Print Settings Editor allows you to tailor print performance with Formlabs materials and certified third-party materials by customizing a range of print settings that control exposure, layer height, resolution, scaling, heating, wiping, and interlayer motion. The tool should only be used by advanced users who understand how to modify print parameters and debug any resulting issues. If you have an issue when printing with your custom print settings, Formlabs Support will ask you to revert back to the Formlabs default print setting. Due to the complex nature of custom print settings, we are unable to assist with fine-tuning or developing custom print settings.
Use of the Print Settings Editor or any third-party material comes with risks, including risk of damage to the printer. Please read the terms of service to understand the risks.
You may also be restricted in editing certain settings depending on the material being printed, including materials that are FDA-registered medical devices.
If you use PreForm Print Settings Editor to edit the print settings for biocompatible materials, you acknowledge and agree that editing the print settings may impact the biocompatibility of your printed parts. Formlabs makes no representations or warranties that any part printed with custom print settings will be biocompatible. You are solely responsible for testing and validating your printed parts to ensure that they meet your biocompatibility requirements.
Note:
The Print Settings Editor was introduced in PreForm 3.33.0. Keep PreForm updated to access the latest print preparation features.
Introduction to tuning
Tuning is a multi-parameter optimization problem. When you change one parameter, you often need to change other parameters. For example, if you increase Perimeter Fill Exposure, you may need to adjust Outer Boundary Offset to maintain the same level of dimensional accuracy on small features.
Print performance is heavily dependent on your model geometry and how your model is oriented and supported. You might create a custom print setting that works well for one model but works poorly for a different model. If you plan to use your custom print setting regularly, make sure to test the custom print setting using a range of models.
Tip:
  • Any time you change exposure, there will be some impact to dimensional accuracy.
  • Layer thickness can heavily impact reliability. You may have to update almost all other parameters when you change layer thickness.
Creating a custom print setting
  1. Click Edit > Print Settings Editor. The Print Settings Editor window appears, showing a list of the existing custom print settings.
  2. Create a new print setting.
Based on a Formlabs print setting Based on a custom print setting
  1. Click New Print Setting. A list of Formlabs print settings appears.
    1. Alternatively, click Formlabs Settings. A list of Formlabs print settings appears.
  2. Select an existing print setting on which you want to base your custom print setting. Each print setting is for a specific combination of printer type, material, layer thickness, and version (e.g., Default or Legacy).
    1. Filter the print settings list for a specific printer type or material using the dropdown menus at the top of the list.
    2. Use the search box to search for a print setting. You can search for a material name, layer thickness, or a term in the print settings description.
  3. Click Copy & Edit Selected. A screen appears with the new print setting.
  1. Select the existing custom print setting on which you want to base your new custom print setting.
  2. Click the Copy & Edit icon next to the selected print setting. A screen appears with the new print setting.
  1. If you are creating a print setting for a material for a biocompatible application, read and agree to the notice at the top of the screen.
  2. Click the pencil icon next to the print setting name at the top of the screen to rename your custom print setting. The default name of a new print setting is the name of the base setting with the prefix Copy of. For example, if you base your custom print setting on the Black Resin V4 0.050 mm Legacy print setting, the default name would be Copy of Legacy.
  3. Click the pencil icon next to the print setting description to input a description for your custom print setting. The default description of a new print setting is the same as the description of the print setting on which it is based.
  4. Edit the available parameters.
  5. When you are done editing your custom print setting, click Save. Your custom print setting is saved and the My Settings list appears.
    1. Click Cancel to discard your current changes instead of saving.
Editing a custom print setting
  2. Select the existing custom print setting you want to edit.
  3. Click the Edit icon next to the selected print setting. An editing screen appears.
Tip:
  • After changing a parameter, if you are not currently editing another field, click the Undo button at the top of the Print Settings Editor window to revert the most recent change. Click Redo to reapply the change. You can also undo or redo changes with the keyboard shortcuts Ctrl+Z and Ctrl+Shift+Z (Windows) or Command+Z and Command+Shift+Z (MacOS), respectively.
  • Press Esc to close the array editor or the Print Settings Editor window.
Exporting a custom print setting
  2. Select the existing custom print setting you want to export.
  3. Click the Export Print Setting icon next to the selected print setting. A file dialog box appears.
  4. Enter a file name and select a location to export the print setting. The default file name is the same as the Setting Name of your custom print setting.
  5. Click Save. Your custom print setting is saved as an FPS file.
Importing a custom print setting
  2. Click Import FPS File. A file dialog box appears.
  3. Navigate to and select the print setting file you wish to import.
  4. Click Open. The print setting is imported and appears under My Settings.
    • If the imported print setting matches one that is already listed in My Settings, a confirmation window appears. Click Replace to replace the existing print setting with the imported print setting.
Deleting a custom print setting
  3. Click the Delete icon next to the selected print setting. The Delete Setting? prompt appears.
  4. Click Delete. The selected print setting is deleted.
    1. Click Cancel to close the prompt without deleting the selected print setting.
Printing with a custom print setting
  1. Import, orient, and support your models.
  2. Click Edit Job Setup. The Job Setup screen appears.
  3. Select a printer, material, layer thickness, and your custom print setting, as you would with a Formlabs print setting.
  4. Click Apply.
  5. Click the orange Upload Print button and upload your print job to your printer.
Available parameters
Form 4 generation
Note:
This section is under development. Content may change.
Name Description Units Reasons to modify Common issues
Layer Thickness mm To adjust print speed, surface finish, or Z-axis fine feature performance. Increasing this value can improve print speed. Decreasing this value can improve surface finish or fine feature resolution.
Most parameters are tuned around layer thickness. If you change layer thickness significantly, you need to adjust almost every other parameter to get optimal print results.
When changing layer thickness significantly, start by duplicating the Formlabs print setting with the closest layer thickness.
Open MaterialAllow this Print Setting to be used with non-Formlabs materials, which requires an Open Material Mode on the printer. To use, select Open Material in Job Setup and select any Print Setting with this option enabled. Including the material name in this Print Setting's title is recommended for easy identification.unitlessTo print with a third-party material on a printer with the Open Material Mode.
X Correction Factor Scale factor for the X axis to account for print scale correction unitless To adjust dimensional accuracy of large features (larger than several millimeters) in the X direction. This value is preset by Formlabs to compensate for the volumetric shrinkage of each Formlabs material.
Y Correction Factor Scale factor for the Y axis to account for print scale correction unitless To adjust dimensional accuracy of large features (larger than several millimeters) in the Y direction. This value is preset by Formlabs to compensate for the volumetric shrinkage of each Formlabs material.
Z Correction Factor Scale factor for the Z axis to account for print scale correction unitless To adjust dimensional accuracy of large features (larger than several millimeters) in the Z direction. This value is preset by Formlabs to compensate for the volumetric shrinkage of each Formlabs material.
Early Layer Exposure and Offset Heights and energy density of laser power applied to the model for each early layer provided. Array field of layers, with heights in mm and energy densities in mJ/cm²
To adjust how much prints are adhering to the build platform, or to adjust the level of flashing (an "elephant foot") on the early layers of prints. Each height in this array is a waypoint for the exposure and offset values. Intermediary layers between waypoints are linearly interpolated. The exposure values affect how much energy is delivered to the resin on a given layer, while the offset values affect the X and Y dimensions of the layers.
Increase the exposure value to increase adhesion to the build platform. Decrease the exposure value to reduce flashing on the early layers of your prints. A positive offset results in less flashing while a negative offset results in more flashing. Change both exposure and offset to improve adhesion without adding undue flashing to your prints.
Note: The best way to reduce flashing without risking print success rate is to use the Z Axis Fine Tuning feature on your printer's firmware.
Note 2: For a more detailed example of how to use this to tune a material, see our article on reducing flashing or elephant’s foot.
  • Reducing the exposure values too much may cause print failures where your print does not adhere to the build platform.
  • Increasing the exposure values too much can create more flashing (an "elephant foot") on early layers.
Outer Boundary Offset The space between the outermost perimeter display path and the model's nominal boundary. A positive value means the display perimeter will be inset smaller than the model's nominal boundary. mm To correct for cases where small features (millimeter scale) are undersized or oversized.
  • If your positive features are oversized, increase this value
  • If your positive features are undersized, decrease this value
  • If your negative features are oversized. decrease this value
  • If your negative features are undersized, increase this value
Changing this value too much can impact (erode or dilate) negative or positive features. For example, if you set this incorrectly, small negative holes might be filled in or small positive features might not print correctly.
Heater Enabled Enable the heater. unitless To enable the heater and allow the printer to maintain the temperature of the resin during printing or disable the heater and print without any external heating. Higher resin temperatures usually increase resin reactivity and decrease resin viscosity. Increased resin reactivity can impact print speed, dimensional accuracy, and surface finish. Decreased resin viscosity can impact print speed, print success rate, and print quality. When resin temperature changes, resin reactivity and resin viscosity changes as well, which can cause significant changes in print speed, print quality, and dimensional accuracy. Generally speaking, maintaining consistent resin temperature throughout your print helps to achieve consistent print quality and dimensional accuracy over the height of the print.
Operating Temperature The resin temperature that the printer tries to maintain while printing. °C To adjust the resin temperature that the printer tries to maintain during printing. Higher resin temperatures usually increase resin reactivity and decrease resin viscosity. Increased resin reactivity can impact print speed, dimensional accuracy, and surface finish. Decreased resin viscosity can impact print speed, print success rate, and print quality.
Formlabs print settings use a default value of 35 °C to ensure consistent resin temperature regardless of ambient temperature.
Start Temperature The resin temperature at which the printer starts printing normally, without user intervention. °C To adjust the resin temperature at which the printer starts printing. Your printer might take several minutes to reach its start temperature, especially in colder environments. Decrease this value to shorten the amount of time that your printer spends heating before a print. When resin temperature changes, resin reactivity and resin viscosity changes as well, which can cause significant changes in print speed, print quality, and dimensional accuracy. Generally speaking, maintaining consistent resin temperature throughout your print helps to achieve consistent print quality and dimensional accuracy over the height of the print. If you set Start Temperature much lower than Operating Temperature, your resin temperature may change during the first several dozen layers of your print, which can cause dimensional accuracy to change throughout those layers.
Irradiance The power delivered by the LPU during printing. mW/cm² To control the amount of power delivered to the liquid resin while printing. Increase this value to reduce print times. Decrease this value to improve print reliability, extend LPU lifetime, and mitigate resin gelling. Increasing this value too much can reduce LPU lifetime and cause resin to gel in the resin tank.
Model Fill Exposure The energy density applied while printing the interior of the model. mJ/cm² To change the green state strength and stiffness of your model. In most cases, higher green strength results in better print success rate, surface finish, and dimensional accuracy.
  • Reducing this value too much can reduce the green state strength of your model, which may hurt your print success rate or final part properties.
  • Increasing the value might require changes to Outer Boundary Offset to maintain the same dimensional accuracy.
Overhang Fill Exposure The energy density of display power applied to the parts of the model that are overhanging. The first entry is for the immediate previous layer. Successive values are for prior layers. Array field of layers, with heights in mm and energy densities in mJ/cm² To correct for issues where unsupported overhangs are sagging or peeling. PreForm defines unsupported overhangs as any feature that is angled above 45° and more than a few millimeters in length. Decreasing this value may lower print success rates. You may see more support failures on overhang features because you are weakening the surface of the overhang feature that the support is attached to.
Perimeter Fill Exposure The energy density applied while printing the perimeter of the model. mJ/cm² To change the surface hardness and surface tackiness of your model. Increase this value to make your print surfaces harder and less tacky.
  • Increasing this value too much can blur out fine features.
  • Requires changes to Outer Boundary Offset to maintain the same dimensional accuracy.
Supports Fill Exposure The energy density applied while printing supports. mJ/cm² To change the stiffness of your supports. In most cases, stiffer supports result in better print success rate, surface finish, and dimensional accuracy.
  • Reducing this value reduces the stiffness and strength of supports, which may reduce print success rate.
  • Increasing this value increases print times.
Top Surface Exposure The energy density applied while printing the top surfaces of the model. Higher values can reduce tackiness after printing. mJ/cm² Rarely modified. To change the surface tackiness or surface hardness of any flat top surfaces on your print. Formlabs recommends changing Perimeter Fill Exposure instead of changing this value. By default, this value is equal to Perimeter Fill Exposure.
Post Expose Cure Wait The time to wait after exposing to let the part cure. seconds To reduce overall print time or improve reliability of the print setting. Reduce this value to save time. Increase this value to improve print reliability and mitigate wishbone failures, where support touchpoints and similar thin features pull away from the part. If you reduce this parameter too much, you may have undercured resin in your model. Formlabs print settings have optimized Post Expose Cure Wait values for every resin to ensure that the resin is fully cured before moving to the next layer.
Z-Bleed Compensation EnabledEnable or disable Z-bleed compensationunitless
When enabled, the software automatically reduces the exposure in specific downward-facing areas to prevent extra resin from curing where it shouldn't. Enable to ensure the sharpest possible details and most accurate dimensions on the bottom-facing surfaces of your model.
In PreForm version 3.56.2 and earlier, this was disabled by setting Z-Bleed Compensation to 0.
Enabling this feature if you have already accounted for Z-bleed inaccuracies in your model can lead to more significant differences between your models and the final printed parts.
Z-Bleed Compensation OffsetThe amount of Z-Bleed Compensation to apply. Higher values will apply more aggressive Z-Bleed Compensation by reducing exposure in certain regions.unitless
To adjust the strength of Z-bleed compensation, if Z-Bleed Compensation Enabled is turned on. A value of 0 uses the default, factory-recommended amount of correction. The value of this parameter increases or decreases the compensation effect by the selected value multiplied by the layer thickness of the print setting. For example, a value of 2 applied to a 100 µm print setting will result in parts being 200 µm thinner than the default settings. A value of -2 used in a 50 µm print setting would result in the part being 100 µm thicker than the default settings.
If Z-bleed compensation is enabled but downward-facing details are still losing sharpness or coming out too thick, increase this parameter. This tells the printer to apply a stronger, more aggressive correction.
In PreForm version 3.56.2 and earlier, setting this parameter to 0 disabled the correction rather than using the default correction.
Increasing this parameter too much can potentially cause bottom-facing surfaces to be underexposed or too thin.
Preprint Wipe Speed (Left)The speed at which the wiper moves from right to left during the preprint phase.mm/sControl the speed of the mixer during preprint. Decrease this value to minimize the risk of resin splashing while increasing print times. Increase this value to reduce print times but increase the risk of resin splashing.If wipe speed is set too high for a given material, you may either experience resin splashing out of the resin tank or trigger debris detection. This depends on wipe speed, resin viscosity, filler level, resin rheology, and resin temperature.
Preprint Wipe Speed (Right)The speed at which the wiper moves from left to right during the preprint phase.mm/sControl the speed of the mixer during preprint. Decrease this value to minimize the risk of resin splashing while increasing print times. Increase this value to reduce print times but increase the risk of resin splashing.If wipe speed is set too high for a given material, you may either experience resin splashing out of the resin tank or trigger debris detection. This depends on wipe speed, resin viscosity, filler level, resin rheology, and resin temperature.
Wipe Behavior 0 = no wipe
1 = round trip wipe
-1 = one way wipe
unitless To make sure your resin is uniformly mixed during the print. In some cases, wiping can improve surface finish and print success rate. For example, if you see cases of undeveloped features (explosions) in your prints, wiping can help prevent those cases. This does not affect wiping behavior during the pre-print routine.
  • No wipe: reduces print time and maintains best surface finish possible
  • One way wipe: minimizes time spent wiping, but can have an adverse effect on surface finish
  • Round trip wipe: increases print time but maintains best surface and maximum print reliability
Wiping adds approximately one second to every layer, which increases print times. Disabling the wiper may lead to unintended resin curing in the tank or on the edges of parts.
Wipe Speed The speed at which the wiper moves during printing. mm/s Control the speed of the wiper during regular printing. Decrease this value to minimize the risk of resin splashing while increasing print times. Increase this value to reduce print times but increase the risk of resin splashing. If wipe speed is set too high for a given material, you may experience resin splashing out of the resin tank. This depends on wipe speed, resin viscosity, filler level, resin rheology, and resin temperature.
Wipe Wall Approach Speed The speed at which the wiper should move when it reaches the Wipe Distance From Wall. mm/s Control the speed of the wiper as it gets closer to the walls of the tank. Use the Wipe Distance From Wall parameter (see below) to define when this speed should be applied to the wiper. Set the Wipe Wall Approach Speed lower than the Wipe Speed to slow the wiper down as it approaches the tank walls. Tuning this value allows you to maximize Wipe Speed and reduce print times while still minimizing the risk of resin splashing. If wipe speed is set too high for a given material, you may experience resin splashing out of the resin tank. This depends on wipe speed, resin viscosity, filler level, resin rheology, and resin temperature.
Wipe Distance From Wall The distance from the wall at which the Wipe Wall Approach Speed setting should be applied. mm To tune the distance from the wall when the wiper speed changes from the Wipe Speed value to the Wipe Wall Approach Speed value (see above). Use this value to balance print times and resin splashing risk. If the wiper does not have enough time to decelerate while approaching the resin tank wall, you may experience resin splashing out of the resin tank. This depends on wipe speed, resin viscosity, filler level, resin rheology, and resin temperature.
Antialiasing Enabled Whether to enable antialiasing in the xy plane. If disabled, pixels >= 0.5 intensity are snapped to one and other pixels are snapped to zero. unitless Disable antialiasing when clear, sharp edges are required. Enable antialiasing to mitigate artifacting from the pixel grid on fine details.
Scrape Routine EnabledEnables the preprint scrape routine to detect debris.unitlessDisable this feature if false positives stop your print when no debris is present. This is more likely to be triggered by viscous resins.Disabling this feature can lead to print failures if there is any debris in the resin tank before the print starts.
Debris Detection Z-Drop EnabledEnables the debris detection Z-drop routing. Warning: disabling this setting can damage your printer.unitlessDisable this feature if false positives stop your print when no debris is present.Disabling this feature can damage your resin tank or Light Processing Unit if there is cured resin on the inserted build platform.
Custom Peel EnabledPick between Formlabs' validated and tuned Smart Peel or finer control using Custom Peel.unitlessTo enable a custom peel move and disable the tuned Formlabs peel moves. A custom peel move consists of two movement stages. Stage one is typically a short, slow move to lift the film and part off of the LPU while the second stage is typically a long, moderate speed move to separate the part from the tank film. Reducing the peel speeds can lower peel forces on parts, allowing for fewer supports in some cases.The Formlabs Smart Peel takes advantage of several additional factors, so it will tend to produce better results on most resins with similar viscosities and mechanical properties.
Stage One Peel DistanceThe height to which the build platform is raised to pull the tank film off the LPU.mmTo determine at what height the peel move should transition to the second stage. Reducing this parameter will transition to the second stage earlier.Reducing this value may cause print failures while increasing this value can extend print times
Stage One Peel SpeedThe speed at which the build platform is raised to pull the tank film off the LPU.mm/sTo determine at what speed the stage one peel moves should be. Reducing this parameter allows the film to lift off the LPU more gently and increasing this parameter reduces print times.Increasing this value may cause print failures or other unwanted print behavior. Decreasing this value can extend print times.
Stage Two Peel DistanceThe height to which the build platform will be raised to separate the part from the tank.mmTo determine the maximum height of the peel move. Reduce this to stop the second stage move at a lower height and transition to the next motion.Decreasing this value may cause print failures and incomplete release from the film. Increasing this value can extend print times.
Stage Two Peel SpeedThe speed at which the build platform will be raised to separate the part from the tank.mm/sTo determine at what speed stage two peel moves should be. Decreasing this parameter may reduce peel forces.Increasing this value may cause print failures or other unwanted print behavior. Decreasing this value can extend print times.
Cup Mitigation EnabledPick between using Formlabs’ optimized cup mitigation or not.unitlessEnable this feature if your geometry has cups that are causing poor surface finish or print failures.Enabling this feature will extend print times.
Custom Squish EnabledPick between Formlabs' recommended Smart Squish or finer control using Custom Squish.unitlessTo enable a custom squish for your print setting. You may want to enable this if you want to modify the speed of the various motor moves during the squish phase.The Formlabs Smart Squish takes advantage of several additional factors, so it will tend to produce better results on most resins with similar viscosities and mechanical properties.
Squish IntensityScale the intensity of Formlabs’ recommended Smart Squish. Will be ignored if Custom Squish is enabled.unitlessThis feature gives you easier control over Smart Squish. Lower intensity will slow down printer motion, which can help avoid surface defects or debris detection issues. Higher intensities can increase the print speed.Setting this parameter too low can dramatically increase print times. Setting this parameter too high can cause immediate debris detection errors. For reference, most Formlabs use an intensity of roughly 80.
Squish DecelerationThe deceleration limit during squish.mm/s2To determine the deceleration of the build platform when it descends into the resin and sets the printing layer. Reducing this value can improve surface finish and reduce forces on partsReducing this value too much can extend print times.
Early Layer Squish Height CutoffThe cutoff height at which early layer squish parameters are applied.mmThe height at which early layer squish is applied. Increasing this value allows for early layers to extend further into the print while reducing this value reduces the number of early layers.Reducing this value may lead to poor part adhesion and delaminations.
Early Layer Squish WaitDuring early layers, the time to wait after squishing to allow the resin to settle.sTo adjust the duration the printer waits for resin to settle following the squish move for the early layers. You may want to increase this value if you are having issues with part adherence or delamination. Decreasing this value can reduce print times and increase the risk of print failure.Reducing this value may lead to poor part adhesion and delaminations
Max Squish SpeedThe maximum speed of the build platform during the squish phase.mm/sTo determine the maximum speed of the build platform when it descends into the resin. Reducing this value may result in improved surface finish.Reducing this value too much can extend print times.
Squish WaitThe time to wait after squishing to allow the resin to settle.sTo adjust the duration the printer waits for resin to settle following the squish move. Increase this value if you notice poor surface finish or decrease this value to reduce print durationIncreasing this value will extend print times.
Resin ViscosityViscosity of the resin being used.cPThe viscosity of the resin is a base property of the liquid. This viscosity is used as a part of calculations when running the print; for example, lower motor speeds are used to account for resin flow on high viscosity resins.If this viscosity is too different from the actual viscosity of the resin, prints may be excessively slow or the printer may throw false debris detection errors.
Resin Level ThresholdThe minimum height of the resin in the resin tank during the print. If the resin level drops below this height, the printer will pause and try to refill the tank. If this is set to 0, print will run to completion even if the resin tank runs dry.mmTo adjust the required quantity of resin to run a print. For Open Material Mode prints, this can prevent the printer from running out of resin during the printing process, or a value of 0 mm can guarantee that the printer will run through all the layers in a print.Setting this parameter too low increases the chance of seeing bubbles in the print or print defects if there was insufficient resin to print a full layer.
Color IDThe Color ID of the Color resin print setting.unitlessVisible when editing a Color Resin print settings file. This parameter is not editable.
Color HexThe hexadecimal color of the Color resin print setting.unitlessVisible when editing a Color Resin print settings file. This parameter is not editable.
Form 3 and Form 3L generation
NameDescriptionUnitsReasons to modifyCommon issues
Layer Thickness mmTo adjust print speed, surface finish, or Z-axis fine feature performance. Increasing this value can improve print speed. Decreasing this value can improve surface finish or fine feature resolution.
Adaptive Layer Thickness is an advanced print mode option that analyzes the geometry of parts imported into PreForm and assigns layer heights throughout the sliced model to maximize print speeds while preserving fine detail.
X Correction FactorScale factor for the X axis to account for print scale correctionunitlessTo adjust dimensional accuracy of large features (larger than several millimeters) in the X direction. This value is preset by Formlabs to compensate for the volumetric shrinkage of each Formlabs material.
Y Correction FactorScale factor for the Y axis to account for print scale correctionunitlessTo adjust dimensional accuracy of large features (larger than several millimeters) in the Y direction. This value is preset by Formlabs to compensate for the volumetric shrinkage of each Formlabs material.
Z Correction FactorScale factor for the Z axis to account for print scale correctionunitlessTo adjust dimensional accuracy of large features (larger than several millimeters) in the Z direction. This value is preset by Formlabs to compensate for the volumetric shrinkage of each Formlabs material.
Outer Boundary OffsetThe space between the outermost perimeter laser path and the model's nominal boundary. A positive value means the laser perimeter will be inset smaller than the model's nominal boundary.mmTo correct for cases where small features (millimeter scale) are undersized or oversized.
Perimeter Fill ExposureEnergy Density of Laser Power applied to the outer surface of the modelmJ/cm²To change the surface hardness and surface tackiness of your model. Increase this value to make your print surfaces harder and less tacky.
Model Fill ExposureEnergy Density of Laser Power applied to the interior fill of the modelmJ/cm²To change the green state strength and stiffness of your model. In most cases, higher green strength results in better print success rate, surface finish, and dimensional accuracy.
Supports Fill ExposureEnergy Density of Laser Power applied to supportsmJ/cm²To change the stiffness of your supports. In most cases, stiffer supports result in better print success rate, surface finish, and dimensional accuracy.
Top Surface ExposureEnergy Density of Laser Power applied to top surfaces of the model. Higher values can reduce model tackiness.mJ/cm²Rarely modified. To change the surface tackiness or surface hardness of any flat top surfaces on your print. Formlabs recommends changing Perimeter Fill Exposure instead of changing this value. By default, this value is equal to Perimeter Fill Exposure.
Overhang Fill ExposurePer layer energy density of laser power applied to the parts of the model that are overhanging. First entry is for the immediate previous layer. Successive values are for prior layers.Array field of layers, with heights in mm and energy densities in mJ/cm²To correct for issues where unsupported overhangs are sagging or peeling. PreForm defines unsupported overhangs as any feature that is angled above 45° and more than a few millimeters in length.Decreasing this value may lower print success rates. You may see more support failures on overhang features because you are weakening the surface of the overhang feature that the support is attached to.
Early Layer ExposureHeights and energy density of laser power applied to the model for each early layer provided.Array field of layers, with heights in mm and energy densities in mJ/cm²To adjust how much prints are adhering to the build platform, or to adjust the level of flashing (an “elephant foot”) on the early layers of prints. Increase this value to increase adhesion to the build platform. Decrease this value to reduce flashing on the early layers of your prints. Note: the best way to reduce flashing without risking print success rate is to use the Z Axis Fine Tuning feature on your printer’s firmware.
  • Reducing this value too much may cause print failures where your print does not adhere to the build platform.
  • Increasing this value too much can create more flashing (an “elephant foot”) on early layers.
Early Layer Squeeze SpeedHeights and squeeze speeds to be applied on early layers. Each entry dictates the height at which the corresponding squeeze speed is applied. Intermediate values are linearly interpolated.Array field of layers, with heights in mm and velocities in mm/sTo improve adhesion between early layers. If you see early layers that are not adhering to each other, even with high Early Layer Exposure values, try decreasing this value.Increasing this value too much can cause surface roughness artifacts, undeveloped features (explosions), or X-axis motor stalls.
Operating TemperatureThe resin temperature that the printer tries to maintain while printing.°CTo adjust the resin temperature that the printer tries to maintain during printing. Higher resin temperatures usually increase resin reactivity and decrease resin viscosity. Increased resin reactivity can impact print speed, dimensional accuracy, and surface finish. Decreased resin viscosity can impact print speed, print success rate, and print quality.When resin temperature changes, resin reactivity and resin viscosity changes as well, which can cause significant changes in print speed, print quality, and dimensional accuracy. Generally speaking, maintaining consistent resin temperature throughout your print helps to achieve consistent print quality and dimensional accuracy over the height of the print.
Start TemperatureThe resin temperature at which the printer starts printing normally, without user intervention.°CTo adjust the resin temperature at which the printer starts printing. Your printer might take several minutes to reach its start temperature, especially in colder environments. Decrease this value to shorten the amount of time that your printer spends heating before a print.When resin temperature changes, resin reactivity and resin viscosity changes as well, which can cause significant changes in print speed, print quality, and dimensional accuracy. Generally speaking, maintaining consistent resin temperature throughout your print helps to achieve consistent print quality and dimensional accuracy over the height of the print. If you set Start Temperature much lower than Operating Temperature, your resin temperature may change during the first several dozen layers of your print, which can cause dimensional accuracy to change throughout those layers.
Wipe BehaviorA vector of wipes to do on layer 0, 1, …, repeating. 0 means no wipe; 1 means full wipe.Array field of wiper behavior (binary)To make sure your resin is uniformly mixed. In some cases, wiping can improve surface finish and print success rate. For example, if you see cases of undeveloped features (explosions) in your prints, wiping can help prevent those cases. Most Formlabs print settings and materials do not use wiping during printing.
  • Wiping adds several seconds to every layer, which increases print times.
  • Wiping changes the actual printed size of a layer in the X and Y axis. In other words, layers with wiping will typically be a different size (in X and Y) than layers without wiping.
    • If you wipe every layer, this layer size change will not be visible on your prints. You can correct for it by changing Outer Boundary Offset.
    • If you wipe every N layers, this layer size change may manifest as a visible, horizontal line in your prints. You cannot correct for this with Outer Boundary Offset because that parameter is constant for every layer.
Wipe SpeedSpeed of the tank wipermm/sTo reduce print times or prevent cases of wiper decoupling. Increase this value to reduce print times. Decrease this value to reduce the risk of wiper decoupling.If wipe speed is set too high for a given material, you may experience higher rates of wiper decoupling. The Form 3 series and Form 3L series wiper is magnetically coupled to its motion axis on the printer. The wiper can decouple from the motion axis during printing depending on wipe speed, resin viscosity, filler level, resin rheology, and resin temperature.
Initial Wipe CountNumber of tank wipes before printing startswipesTo ensure the print plane is clear of debris or to ensure that the resin is uniformly mixed before printing. Formlabs recommends always wiping at the beginning of the print. This is especially important when using pigmented resins (e.g., Model Resin V3) and filled resins (e.g., Rigid 10K Resin).Increasing this parameter increases preprint time. Every wipe takes several seconds to complete.
Roller Squeeze SpeedMaximum roller speed when squeezing resin out from under regions that were lased on the previous layermm/sTo improve surface roughness artifacts on the leading edge of your prints. Decrease this value to improve surface roughness artifacts. Increase this value to save print time.
  • Surface roughness artifacts appear on vertical surfaces and look like wavy lines that aren’t perfectly aligned with layers.
  • On Form 3 series and Form 3L series printers, the leading edge of a print refers to the right edge of the print when facing the printer with the build platform inserted.
Increasing this value can cause surface roughness artifacts, undeveloped features (explosions), or X-axis motor stalls.
Post Laser Cure WaitWait time after lasing to let the part cure before stressing the material by peelingsecondsTo improve surface roughness artifacts on the trailing edge of your prints. Increase this value to improve surface roughness artifacts. Decrease this value to save print time.
  • On Form 3 series and Form 3L series printers, the trailing edge of a print refers to the left edge of the print when facing the printer with the build platform inserted.
If you reduce this parameter too much, you may have undercured resin in your model. Formlabs print settings have optimized Post Laser Cure Wait values for every resin to ensure that the resin is fully cured before moving to the next layer.
Additional explanation and visualization of selected parameters
Custom Squish and Custom Peel
Both Custom Squish and Custom Peel fundamentally change the algorithm used to generate motion, so they may require substantial additional settings modifications to produce your desired results. These are generally much more similar to how other slicers and printers generate squish and peel modes. If you are using a custom squish profile, Formlabs recommends decreasing Squish Deceleration to 5–20 mm/s2 and to reduce Max Squish Speed to around 30 mm/s. Higher values are typically better for low viscosity resins, while lower values are required for high viscosity resins. If these are set too high, the printer will encounter a false debris detection error before starting the first layer.
The Outer Boundary Offset is the space between the exposed boundary of the part and the nominal part. If the exposure exactly matches the part (i.e., an offset of 0), light will spread beyond the intended edge of the part, causing it to cure larger. Setting a positive Outer Boundary Offset will account for this spread.
Figure showing the impact of the Outer Boundary Offset parameter on printed parts
Irradiance, exposure, and exposure time
Many other SLA slicers use exposure time, or some similar time constant, to set the amount of time that each layer is cured. Formlabs uses exposure as an energy dose applied to the material, since this allows different energy doses to be applied to different types of features (e.g., supports vs. touchpoints vs. the part itself) and does not need to be changed between printers. The general calculation for exposure is: Exposure (mJ) = Irradiance (mW) * Exposure Time (s)
If you need to convert to exposure time, you can use the Model Fill Exposure and Irradiance parameters to get a roughly equivalent exposure time. Note that a high irradiance may mean that the resin exposes far faster than with lower-power printers.
Note:
Irradiance is one of the most powerful tools for improving print success and is one of the first parameters Formlabs recommends changing when troubleshooting a custom print setting. Decreasing it will often resolve a variety of issues including gelling and part joining, but does increase print time. Increasing it can dramatically decrease the exposure time and thus the print time.
