Using Elastic 50A Resin
Flexible 50A Resin is an elastomeric material designed for applications requiring high elongation and high energy return. Use Flexible 50A Resin for parts that will bend, stretch, compress, and hold up to repeated cycles without tearing. Elastic is transparent, which makes it well suited for medical models for simulation or education. To learn more about potential applications for this material, read the blog post Introducing Elastic Resin: A Soft, Resilient 3D Printing Material (English only).
Note:
As of June 9, 2026, Elastic 50A Resin V2 has been renamed to Flexible 50A Resin. This better describes its performance relative to other flexible Formlabs resins.
Recommended for:
  • Wearables and consumer goods prototyping
  • Medical models and devices
  • Compliant features for robotics
  • Special effects props and models
Note:
To learn more about the performance or specific material properties of Flexible 50A Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
Elasticity is the ability of an object or material to resume its normal shape after being stretched or compressed. Flexible 50A Resin is designed to “bounce back” and return to its original shape quickly.
Durometer is the hardness of a material. Flexible 50A Resin has a lower durometer than other Formlabs resins, making it suitable for prototyping parts normally produced with silicone. Flexible 50A Resin also has a higher tear strength than comparable materials, making it capable of repeated cycles of use.
See the table below for a comparison of relevant material properties with other engineering resins and with other products:
 Formlabs Flexible 50A Resin, post-curedFormlabs Flexible 80A Resin
Durometer/shore hardness50A80A
Elongation at break (%)160120
Tensile strength (MPa)3.48.9
Tear strength (kN/m)12.324.0
ColorClearClear
Weitere Informationen zu den Leistungseigenschaften der jeweiligen Formlabs-Kunstharze erhalten Sie in den Materialdatenblättern.
Printing with Flexible 50A Resin
Hinweis:
  • Überprüfen Sie zur Vermeidung von Schäden am Gerät die Kompatibilitätstabelle für Harztanks unter Verwendung des richtigen Materials, damit Sie einen für dieses Material kompatiblen Harztank verwenden.
  • Gelegentlich kann kristallisiertes oder geliertes Harz das Beißventil blockieren. Wenn das Harz nicht normal abgegeben wird, drücken Sie das Beißventil mit einer behandschuhten Hand zusammen, um die Verstopfung zu beseitigen.
Flexible 50A Resin is a unique material that requires more support than some other Formlabs resins. Increase support density for parts with large cross sections, and keep large cross sections closer to the build platform. Avoid orienting parts with merging features-- areas that begin printing separately and then merge together later in the printing process.
  1. Open a model.
  3. Orient to preserve fine details.
  4. Generate supports.
Avoid long unconnected supports when printing with Flexible 50A Resin. Generating isolated supports more than 20 mm long may lead to print failures. Increase support density or add additional supports manually to the model to increase trussing between supports. Supports printed with Flexible 50A Resin normally distort slightly from the force of the peel cycle.
Print feature recommendations
Improve print success with Flexible 50A Resin by designing features according to Formlabs recommendations.
Supported wall thickness
Minimum: 400 microns
Recommended: 600 microns
Unsupported wall thickness
Minimum: 600 microns
Recommended: 800 microns
Shallow angles
Minimum: 19 degrees
Recommended: 45 degrees
Horizontal span/bridge
Maximum: 600 microns
Vertical wire diameter
Minimum: 300 microns
Maximum: 1500 microns
Clearance between adjacent parts
Minimum: 1000 microns
Hole diameter
Minimum: 800 microns
Fertigstellung
The Form Wash agitates the solvent bath and removes parts from the bath after a set time. Wash parts according to the support article Form Wash time settings. Pay particular attention to information that affects mechanical properties or biocompatibility requirements.
The surface of parts printed with Flexible 50A Resin may feel slightly sticky after washing.
Nachhärtungsanforderungen
Flexible 50A Resin requires post-curing to reach its optimal mechanical properties.
Anmerkung:
Zum Nachhärten dieses Harzes tauchen Sie die Teile in einen Glasbehälter mit einem Fassungsvermögen von mindestens 500 ml Wasser ein. Die Teile sollten vollständig eingetaucht sein und keine Luftblasen auf der Oberfläche aufweisen.
Lassen Sie die Teile vor dem Nachhärten immer vollständig trocknen. Empfehlungen für die Nachhärtung finden Sie im Supportartikel Zeit- und Temperatureinstellungen beim Form Cure.
