Raft silhouettes are usually caused by optical surface contamination that blurs or weakens the laser light before it reaches the resin.
The early layers of a print receive additional laser curing, so these layers can cure successfully even if contamination or clouding weaken the laser. Further layers may fail to cure, either partially or completely.
Any of the following factors, or a combination of them, can blur or weaken laser light:
- Debris/clouding/damage in resin tank
- Contaminated optical surfaces
- Form Studio 1: Light Processing Unit release texture, resin tank film
- Form 4 and Form 4L generation: Light Processing Unit release texture, resin tank film
- Form 3 and Form 3L generation: Light Processing Unit optical window, resin tank film
- Form 2: optical window, main mirror, resin tank acrylic window
