What should I use to clean my Fomlabs SLS system? (Fuse 1, Fuse Sift, Fuse Blast)
Keep the Fuse ecosystem clean to ensure maximum functionality throughout the lifetime of the machine. Clean the Fuse 1, Fuse Sift, and Fuse Blast components with the appropriate tools and solvents, depending on what the component is made of.
Fuse 1
Tool or SOLVENTUse it forDo not use it for
Alconox
Distilled water
Polyester cloth swabs
Optical cassettesOther optical surfaces
Quartz heaters
Sensors
Compressed air
Gas duster
Air filters
Hard-to-reach areas
Exhaust fan
Exhaust lines
Outer surfaces
Build chamber
Optical surfaces
Print enclosure
Quartz heaters
Sensors
Ethanol
PEC*PADs
Optical surfaces
Quartz heaters
Sensors
N/A
Non-abrasive microfiber clothOuter surfaces
Powder hopper
Optical surfaces
Quartz heaters
Sensors
Paper towelsOuter surfacesOptical surfaces
Quartz heaters
Sensors
VacuumAir filters
Exhaust fan
Exhaust lines
Outer surfaces
Print enclosure
Optical surfaces
Quartz heaters
Sensors
Fuse Sift
BrushSifter meshVent filter
Vacuum
Area surrounding the sifter mesh
Build chamber
Build chamber enclosure
Fresh powder hopper
Outer surfaces
Part extraction tools
Parts basket
Surface grate
Tool shelf
Used powder hopper
Vent filter
Walls
Workspace
Sifter Mesh
Paper towels
Water
Outer surfaces
Sifter gasket
Sifter mesh turnbuckles
Sifter mesh
Vent filter
Powder hopper
Work deck
Fuse Blast
Cotton swabsIonizer tips
Manually cleaning the blast gun
Media filter mesh
HEPA filter
Antistatic vacuum, founded and bonded (eg, NPFA 652-compliant vacuums)Media filter mesh
HEPA filter
Parts catcher
N/A
Compressed air Polishing System water lineMedia filter mesh
HEPA filter
Parts catcher
Disposal bag (or 11 L container)Emptying waste hopperN/A
