Learn how to recognize common causes of resin spills and how to minimize the likelihood of resin spills.
While resin spills occur for a variety of reasons, the most common reasons are failed prints in the resin tank, damage to the resin tank, and damage to the resin cartridge bite valve.
Failed prints
When a print fails, the entire print or a part of the print may fall into the resin tank. The mixer is designed to detect such a failure and pause the printer, but some resin may still be spilled.
To avoid print failures, exercise these Form 3/Form 3B best practices:
Damaged resin tank
A damaged resin tank can cause resin to leak onto the printer. The flexible film at the bottom of the tank can be damaged by improper storage (such as placing a tank down on top of another object) or rough handling (such as using a sharp tool to remove cured resin). Similarly, the plastic frame of the resin tank can crack due to an impact or other significant force. Use the provided plastic tank tool to inspect the flexible film and always handle the resin tank with care.
Damaged bite valve
A damaged bite valve on the resin cartridge can cause the printer to dispense too much resin, which can cause the resin tank to overflow. Learn how to inspect and protect the bite valve.
