Uploading and confirming a print (SLS)
After orienting your models, connect to your printer via USB, Ethernet, or Wi-Fi. Ensure your printer is connected to the same network as your computer, then send a print job to the printer.
While uploading a print job to the printer, PreForm and the touchscreen show that the FORM file upload is in progress. Once transferred, print jobs must be confirmed on the touchscreen to start the print.
Uploading a print job to a printer
To upload a print job from PreForm to a printer:
  1. Select the Printer and the Job Settings. Click Apply.
  2. Click the orange Upload to Queue button. The model is sent to the printer. A slider and percentage display allows you to monitor the upload progress.
Do not disconnect your printer while the upload is in progress.
Upload to Queue is unavailable in PreForm
If the orange Upload to Queue button is unavailable in PreForm:
  1. Verify that there are no other instances of PreForm open on your computer.
  2. Check that the printer is connected to the same network as the computer running PreForm.
  3. If the computer is not connected to the same network, save any files in progress and close PreForm.
  4. Connect the computer to the same network the printer is on, open PreForm, and connect to the printer.
If the orange Upload to Queue button remains unavailable, you may need to manually add the printer to PreForm.
Add to Running Job
With PreForm version 3.46.0 or later, use the Add to Running Job tool to add additional parts to the currently running print job.
If the current print job enters the cooling phase, Add to Running Job adds these parts to the Queue as a new print job. Parts in an active print job cannot be modified.
To use Add to Running Job:
  1. Update PreForm to version 3.46 or newer.
  2. Update printer firmware to version 1.22.0 or newer.
  3. Upload a print job to the printer. Start the print.
  4. Open PreForm.
  5. Select the printer with the running job. The running job must also have been uploaded with PreForm 3.46 or newer.
  1. Toggle Add to Running Job. The toggle turns blue when active.
Add to Running Job toggle in PreForm.
  1. PreForm displays the available build volume above the current print with a blue inclusion box.
  2. Add, orient, and pack models in the available build volume. The additional models may not exceed the available build volume.
  3. Click Add to Job. PreForm adds the new models to the running print job.
Blue inclusion box in PreForm
Known Issues with Add to Running Job:
  • PreForm may not correctly display the remaining time in the Job Setup card
  • If an add-on job will exceed the total amount of build volume available, PreForm will alert you with a Job Upload Failed error message including how many layers you have available to add-on to. To clear the error state and try again, uncheck “add to current job,” click upload to queue, then cancel and try again starting from step 3 above.
  • Job Upload Failed error message in PreForm
  • Jobs can only be uploaded via a local connection to the printer. Remote upload and Fleet Control are not supported at this time.
  • If you start uploading an add-on job and the printer enters the cooldown, then the add-on job will just go to the Queue and will not start printing as part of the stack. If the icon below appears next to the printer you are selecting in PreForm, it indicates a remote connection. Remote printers can accept and start jobs, but they cannot add additional jobs afterwards.
  • Remote connection icon in PreForm printer selection
  • PreForm will estimate and display packing density per job. It will not account for the packing density of the entire build volume. You should ensure the average density of the build chamber matches the recommendation.
  • PreForm does not subtract the pre-print or post-print height of the job you are preparing from the usable volume visualization since they are only known after slicing. This may lead to jobs that fit in the rendered box being rejected.
  • Preparing the printer
    Follow the instructions in the support article Preparing the Fuse 1 for a print.
