Using BioMed Clear Resin
Hinweis:
Überprüfen Sie zur Vermeidung von Schäden am Gerät die Kompatibilitätstabelle für Harztanks unter Verwendung des richtigen Materials, damit Sie einen für dieses Material kompatiblen Harztank verwenden.
BioMed Clear Resin is a medical-grade material designed for rigid, non-brittle, biocompatible parts that require long-term skin and mucosal membrane contact and for end-use medical devices. It can be sterilized by autoclave, E-beam, gamma, and ethylene oxide.
Note:
To learn more about the performance or specific material properties of BioMed Clear Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
 BioMed Black ResinBioMed White ResinBioMed Clear ResinBioMed Amber Resin
Sterilisierbar
Transparent
Polierbar
Kompatibel mit Form 2
Kompatibel mit Form 3B/3B+//3BL
ZertifizierungenUSP Klasse VI
ISO 10993-5, -10,-23
USP Klasse VI
USP <151> Pyrogen + ISO 10993-11 Akute systemische Toxizitätsprüfung
USP Klasse VI
ISO 18562-1,-2,-3,-4
ISO 13485
Schichtdicke50 Mikrometer
100 Mikrometer
50 Mikrometer
100 Mikrometer
50 Mikrometer
100 Mikrometer
50 Mikrometer
100 Mikrometer
Supported with an FDA Device Master File, which assists customers’ medical device registrations. For more information, contact Sales at Formlabs.
Ultimate tensile strength (MPa)35.745.85273
Tensile modulus (GPa)1.52.02.12.9
Elongation at break (%)14101212.3
Flexural modulus (GPa)1.72.02.32.5
IZOD Impact strength (J/m)24.815.13528
Heat deflection temperature (HDT) @ 1.8 MPa49.452.45465
Heat deflection temperature (HDT) HDT @ 0.45 MPa (°C)68676778
Erforderliches Zubehör
Made by Formlabs:
Printing with BioMed Clear Resin
For full compliance and biocompatibility, BioMed Clear Resin requires a dedicated resin tank, build platform, and Finish Kit which should not be used with any other resins.
Waschen
Befolgen Sie die Empfehlungen zum Waschen der Teile im Herstellungsleitfaden, um die klarsten und bestmöglichen Ergebnisse zu erzielen. Unsachgemäßes Waschen kann zu suboptimalen mechanischen und biokompatiblen Eigenschaften führen.
Nachhärtungsanforderungen
Befolgen Sie die Nachhärteempfehlungen im Herstellungsleitfaden für die klarsten und bestmöglichen Ergebnisse. Wenn beim Nachhärten nicht die empfohlenen Werte eingehalten werden, können sich die mechanischen und Biokompabilitätseigenschaften verschlechtern.
Hinweis:
  • Härten Sie nicht über die empfohlenen Nachhärteeinstellungen hinaus nach, da dies zur Verfärbung von Teilen führen kann.
  • Lassen Sie nachgehärtete Schienen vollständig abkühlen, bevor Sie Stützstrukturen oder Passungen entfernen.
  • Entfernen Sie Stützstrukturen erst nach dem Nachhärten, um sicherzustellen, dass Druckteile sich nicht verziehen.
Weitere Ressourcen
