Pinholes or cuts
A “pinhole” or “cut” describes a print defect in which a small region of the part does not form. This void can take the form of a small hole, a tunnel that runs through the part, or a slit that cuts through the part. If other sections of the part would have been supported directly by the missing material, those sections may also fail to cure to the part.
Visual symptoms
  • A void that passes through the entire print, including the raft (if one is used). The void may take the form of a small hole in one portion of the part or a linear slit that extends across the part.
  • A hole or cut may lead to one or more undeveloped features, depending on the geometry and orientation of the part.
Common causes
Either of the following factors, or a combination of them, can cause a hole or cut in a print:
  • Debris or scratches on the bottom surface of the resin tank
  • Debris or scratches on an optical surface
If, while curing a layer, the laser is blocked before it reaches the resin, that portion of the part will not form properly. If the obstruction is on a stationary surface, a hole may develop directly above that point. If the blockage is on a moving surface, a linear cut may develop instead, following the path of the blockage.
Troubleshooting steps
Successful troubleshooting identifies symptoms and systematically narrows down the root cause of an issue. Follow the troubleshooting steps below to check for possible causes, beginning with the most likely cause of the print defect.
Note:
Make sure that your firmware and PreForm versions are up to date. To check your printer’s firmware version, refer to the support article Checking the firmware version for Formlabs SLA printers. To update your PreForm version, refer to the FAQ article How do I update PreForm?.
Step 1: Check the resin tank
Any damage or debris in or on the resin tank can block the laser at that location, preventing the resin directly above it from curing. Inspect the inside and underside of the tank for dirt, dust, and/or fingerprints. The bottom of the tank must be clean for the best print results.
  1. Inspect the resin tank for debris with the plastic scraper that comes with the Finish Kit or a similar tool. Apply minimal force to remove the cured resin. Avoid using the corners of the tool to dig under the print. Do not use metal tools to inspect the resin tank.
  2. Remove any failed prints and cured resin by printing a cleaning sheet.
  3. Filter the resin to remove any contamination or cured resin.
  4. Inspect the film at the bottom of the resin tank for scratches or wear. Excessive wear means the resin tank needs to be replaced.
  5. Inspect the underside of the film for dirt, dust, or fingerprints. Clean it with Formlabs recommended steps and supplies.
  1. Inspect the resin tank for debris with the tank tool.
  2. Remove any failed prints and cured resin using the tank tool.
  3. Alternatively, remove any failed prints and cured resin by printing a cleaning mesh.
  4. Filter the resin to remove any contamination or cured resin.
  5. Inspect the flexible film at the bottom of the resin tank for scratches or wear. Excessive wear means the resin tank needs to be replaced.
  6. Inspect the underside of the flexible film for dirt, dust, or fingerprints. Clean it with Formlabs recommended steps and supplies.
  1. Inspect the resin tank for debris with a scraper.
  2. Remove any failed prints and cured resin with the scraper, being careful not to gouge or cut the elastic layer at the bottom of the tank.
  4. If using Resin Tank LT, skip this step. Inspect the elastic layer of the standard resin tank for clouding. Severe clouding means a standard resin tank needs to be replaced.
  5. Inspect the acrylic tank window on the underside of the resin tank for dirt, dust, cured resin, or fingerprints. Clean it with Formlabs recommended steps and supplies.
Tip:
Keep resin tanks clean and well-maintained between prints for reliable and successful printing.
Step 2: Check the printer's optical surfaces
Any contamination, dust, or debris on the printer’s optical surfaces can cause the laser light to diffuse or weaken, resulting in a print failure. Contamination is most likely to occur on an exposed optical surface in the printer.
The optical surface most likely to be contaminated is the release texture, the top face of the Light Processing Unit (LPU). It prevents suction from forming between the resin tank film and the LPU, reducing peel forces between layers. Any contamination on the release texture can cause the backlight to diffuse or weaken, resulting in print defects.
  1. Remove any inserted consumables from the printer.
  2. Inspect the release texture for contamination.
  3. Follow the instructions for cleaning the release texture.
  4. The underside of the LPU can also become contaminated, particularly if the LPU fan filter is clogged. If you suspect that the underside of the LPU is contaminated rather than the release texture, test the LPU and Backlight Unit, then clean the LPU and LPU fan filter based on the results.
The optical surface most likely to be contaminated is the glass optical window, which sits atop the Light Processing Unit (LPU).
  1. With the printer plugged in and powered on, tap the wrench icon to access the Settings screen, then tap Maintenance > Motor Moves. The Motor Moves screen appears. Tap and hold Left (<) to move the LPU housing to the middle of the printer cavity. Other controls on this screen fully sweep the LPU housing across the printer cavity and control the build platform carriage.
  2. When prompted by the touchscreen, disconnect the power cable before continuing with maintenance.
  3. Inspect the optical window for contamination.
  4. Follow the instructions for cleaning the glass optical window.
  5. If streaks are difficult to remove, contact Formlabs Support or your authorized reseller.
The optical surface most likely to be contaminated is the glass optical window beneath the resin tank that protects internal components from contamination.
  1. Inspect the optical window on the Form 2 or for contamination.
  2. Follow the instructions in Cleaning the glass optical window (Form 2). If streaks are difficult to remove, contact Formlabs Support or your authorized reseller.
Follow the optical surface cleaning guides exactly. Failure to follow instructions could damage the printer.
Contacting Formlabs Support
If the troubleshooting steps above do not resolve the print failure, contact Formlabs Support or your authorized reseller.
To help us provide the fastest and most effective response to your issue, please follow these steps:
  1. Upload diagnostic logs
  2. Serial name of the printer
    • The serial name is on the back panel of the printer in the format AdjectiveAnimal or Machine-AdjectiveAnimal.
    • Form 4 or Form 4L generation printer: Tap Settings > General > About this printer
    • Form 3 or Form 3L generation printer: Tap the printer icon on the Home screen.
    • Form 2: Tap the printer icon on the home screen. The Your Printer screen appears.
  3. Troubleshooting steps attempted
    • Example: “I reoriented the model in PreForm. I inspected the resin tank and did not notice any damage, clouding, or debris.”
  4. Resin formulation and lot number
  5. Layer thickness
    • Form 2: Tap the queue icon on the home screen. The Jobs screen appears.
    • Other Formlabs SLA printers: Tap the queue icon on the printer's touchscreen. The Queue or Jobs screen appears.
  6. Relevant FORM files
    • If available, attach FORM files of the model to the support request.
  7. Previous attempts to print the part and any successful prints
    • Example: “I printed the file part2.form three times previously. The first and second were successful. The third one failed.”
