Note:
The powder must be at the correct refresh rate for the results to be valid. If you have run out of used powder, age some fresh powder first to create some.
SLS printed parts typically have a grainy matte finish. If material is not heated optimally during printing, the surface finish can worsen, exhibiting a texture similar to birchbark, orange peel, or sandpaper.
Symptoms
Causes
Troubleshooting steps
General troubleshooting steps
If the steps do not resolve the issue or you need assistance with interpreting the results of a diagnostic print, upload diagnostic logs from your printer, then contact Formlabs Support or a certified service provider and upload diagnostic logs.
Nylon 12 Powder troubleshooting
Note:
Nylon 12 GF Powder troubleshooting
Note:
Increasing the bed temperature will make the powder cake harder to break apart and the Surface Armor more difficult to remove.
Nylon 12 White Powder troubleshooting
Note:
You must use 100% fresh powder for the results of the tuning print to be valid.
Nylon 12 Tough Powder troubleshooting
Note:
Nylon 11 Powder troubleshooting
Note:
Nylon 11 CF Powder troubleshooting
Note:
