Delivering 10,000 3D printed parts a week requires high throughput from every square foot of a facility. Printers have to be fast and reliable, all with a low cost per part.
At Autotiv, over 200 printers run round the clock, delivering parts for drones, robotics, consumer products, and medical prototypes to customers in the US and beyond — often in a single business day.
“The Fuse X1 has been a game-changer for Autotiv Manufacturing. The sheer speed of the platform allows us to deliver thousands of parts to customers in a matter of days. And thanks to SLS technology's lack of support material, our customers have geometric freedom. You can build walls down to about half a millimeter thick, parts up to 600 mm long, and it can run its entire massive build volume in 24 hours.”
Evan LaBelle, CEO, Autotiv Manufacturing
With the addition of Fuse X1, Autotiv has increased throughput of SLS parts. The fast print speed and the ability to print a high mix of parts in one build, has enabled Autotiv to deliver large parts and thousands of small parts all with shorter delivery times.
In addition to Fuse X1, Autotiv prints on Fuse 1+ 30W 3D printers, regularly changing out materials so that they can offer all SLS materials to their customers.
FDM 3D printers run around the clock at Autotiv.
Talk to Our Sales Team
Whether you need to prototype at speed, or are producing end-use parts, we’re here to help. The Formlabs Sales team is composed of dedicated specialists who know exactly how to support you and your company's needs.
3x the Throughput With Fuse X1
“On the Farsoon, running the full build volume takes about 70 hours. The Fuse X1 has a comparable build volume and it's able to cycle every 24 hours, so you can effectively run about triple the throughput. In addition, the Fuse X1 has a more compact footprint, so you can fit more in the same amount of space.”
Fuse X1 is an accessible, industrial, selective laser sintering (SLS) 3D printer in a small footprint. With a 63 L build volume, 8x larger than Fuse 1+ 30W, Autotiv can print large parts and dense builds with hundreds of parts in minimal space — all within 24 hours.
Prior to Fuse X1, Autotiv would print large parts and high volumes of parts on their Farsoon SS403P (far right), but Fuse X1 (at left) has about 3x the throughput in a smaller footprint.
Throughput is impacted by packing density — a larger build volume with a low packing density produces fewer parts per build than a smaller build volume with a high packing density might. Fuse X1 builds on the thermal processing power of Fuse 1 and Fuse 1+ 30W, processing 700x more thermal data per second. Unlike multi jet fusion (MJF), which has limited packing densities, Fuse X1 has no constraints on packing density or placement in the build chamber. With Dynamic Thermal Control, Fuse X1 can perform real-time thermal tuning for unlimited packing freedom. LaBelle routinely runs packing densities from 20-30%.
Previously, Autotiv would print large parts on their Farsoon SS403P, which would take about 70 hours to cycle. With a cycle time of ~24 hours, Autotiv can effectively run two or three builds on one Fuse X1 in the same amount of time it would take to run one build on the Farsoon. This allows them to scale production without taking up more space, delivering large SLS parts to clients in drastically shorter lead times.
| Farsoon SS403P | Fuse X1 | |||
| Printer size | 2470 × 1500 × 2145 mm (97.24 × 59.06 × 84.45 in) | 1577 x 832 x 1926 mm (62.1 x 31.3 x 75.8 in) | ||
| Build volume | 400 × 400 × 450 mm 72 L | 330 × 330 × 575 mm
63 L | ||
| Time to run a full build | ~70 h | ~24 h | ||
| Cost for printer | ~$294,000 | $85,000 |
Preventing Failures With Print Intelligence™
Fuse X1 includes Print Intelligence™, a real-time AI-powered intelligence architecture that monitors, adapts, and protects every stage of the print process. The new feature senses issues before they happen, preventing users from coming back to failed builds.
LaBelle notes that Print Intelligence™ saves material. If a part fails during a build and the printer keeps printing, it would result in powder waste. When Print Intelligence™ detects a problem, it selectively removes the affected part from the following layers, saving materials. The unaffected parts will continue to print, saving time.
Delivering Quality Parts
“I remember when we built our first large part on the Fuse X1 and we measured it. We were blown away by the dimensional accuracy. The part was about 0.2 mm off and it was about a 340 mm tall part. This is extremely impressive for SLS.”
LaBelle reclaims powder on Fuse Sift X1, a larger version of Fuse Sift designed for post-processing parts printed on Fuse X1.
The Fuse Blast High Capacity Kit is added to Fuse Blast to clean and polish parts printed on Fuse X1.
Parts printed on the Fuse X1 are post-processed in Fuse Sift X1, where powder is reclaimed. Autotiv then uses Fuse Blast for cleaning and polishing. LaBelle says that before Fuse Blast, it could take five or six hours to break down and clean all the parts in a build. “One time we actually had someone who had a shoulder injury from overuse because of how much bead blasting had to be done,” he says. Adding Fuse Blast saves not only significant time, but also labor costs. “Now with the Blast, you turn it on and you walk away. That entire monotonous process is automated at this point.”
Media blasting with Fuse Blast delivers parts with a smooth, semi-gloss surface finish. However, Autotiv also coats and paints parts depending on the application, including adding Cerakote ceramic coatings. This not only achieves desired surface finishes, but can also enhance the performance of 3D printed parts.
Autotiv Cerakotes parts to achieve desired finishes or mechanical properties.
Parts for automotive and aerospace applications are often finished by painting or coating.
Optimizing Packing
“We have several packers and some of them cost over $10,000 a year as subscriptions and I wish that we didn't need them. I wish that we could run everything through PreForm because it's fully featured and incredibly efficient — it makes it easy.”
Builds for Fuse X1 are prepared in PreForm, Formlabs’ free print preparation software.
Builds for Fuse X1 are prepared for printing in PreForm, Formlabs’ free print-preparation software, with the same ease and tools as setting up a build for printing on Fuse 1+ 30W. Builds can be set up with one click, or users can dial in settings for industrial printing with the intuitive workflows users expect from Formlabs. It’s also possible to add parts to an in-progress print, providing sufficient build volume is available. This means LaBelle can start a print on Fuse X1, and add additional parts if a late order arrives — saving the time of finishing the print and starting a new one.
Adding Fuse X1s to Meet Demand
To meet the growing demand for fast turnaround on 3D printed parts, Autotiv is scaling their 3D printing capabilities, adding more FDM, SLA, and SLS 3D printers to their manufacturing facility — including ordering additional Fuse X1s.
“Thanks to its compact footprint, Autotiv can fit many Fuse X1s in the same amount of space that larger SLS platforms would take. This means that we can fill our facility with more machines running more materials, delivering higher volumes of parts for our clients.”
Autotiv orders pallets of Nylon 12 Powder to meet demand. Ordering bulk powder also takes advantage of discounted material pricing.
This beta unit of Fuse X1 is the first of several Fuse X1 printers Autotiv is considering as part of its ongoing expansion.
Bulk powder discounts and fast print times result in a low cost per part on Fuse X1, for a fast return on investment, making it easy for Autotiv to continue to scale SLS 3D printing with Fuse X1.
“The Fuse X1 has returned on investment about five times faster than comparable SLS systems that we already own and are evaluating, thanks to about half the upfront cost and about double the throughput. You can get a return on investment extremely quickly.”
Watch the video to learn more about Fuse X1 or contact sales to start printing.
