Recover powder fast and at scale, with capacity to keep production running without bottlenecks.
Sift X1 holds 3 to 5 full builds of used powder without crowding your workspace.
330 × 330 × 565 mm build volume, with 30%+ packing density
Production-quality parts for 50% less, all in ½ the space
Same day large parts and 3x the throughput of competitors
AI powered Print Intelligence failure prevention
Install & operate in one hour, start a print in 5 minutes
Deliver full-size parts overnight, or production runs of your latest design.
Production Batches
3280 Parts
41.5 hours
41% mass pack density
High Mix Builds
29 Parts
22.5 hours
10% mass pack density
Full Scale Prototypes
3 Parts
21 hours
2% mass pack density
Case Study: Radio Flyer
How Fuse X1 Helps Radio Flyer Shorten Prototyping Timelines by 90% With 9x Less Labor
“With Fuse X1, we can now print an entire Flyer Loop cargo ebike overnight and be gluing it together the next day. So we went from two months to two weeks to a couple of days.”
Agostino LoBello, Product Development Engineer, Radio Flyer
Scale production, not overhead with 50% lower cost per part.
Case Study: Autotiv Manufacturing
3x the Throughput, Half the Size: How Fuse X1 Enabled a Service Bureau to Scale SLS
“The Fuse X1 has returned on investment about five times faster than comparable SLS systems that we already own and are evaluating, thanks to about half the upfront cost and about double the throughput. You can get a return on investment extremely quickly.”
Evan LaBelle, CEO, Autotiv Manufacturing
Productive no matter how you measure it. Fuse X1 delivers 3x higher throughput in less than half the floor space.
More Parts Per Build
With 30%+ packing density and a 61.5L build volume, the Fuse X1 fits more parts in a single build than competing industrial SLS and MJF systems, adding up to thousands more parts per week.
Fits Where Others Can't
At just 1.3 m², the Fuse X1 takes up less than half the floor space of an HP 5600 (2.80 m²) or EOS P3 Next (2.70 m²). It rolls through a standard doorway, so you can install production-scale SLS without rebuilding your floor plan.
Case Study: Tesla
How Tesla Giga Nevada Prints 20,000 Parts a Month Instead of Injection Molding With Fuse X1
“With the increased throughput and decreased costs, Fuse X1 has completely changed our perspective on what kinds of projects our lab can support versus what we would have traditionally moved to an injection mold.”
Cody Jepson, Engineering Technician, Additive Manufacturing at Tesla Giga NV
Print Intelligence, an industry-first, AI-powered print failure prevention system.
How It Works
The Fuse X1 is the most reliable SLS printer ever developed. By combining computer vision with Adaptive Temperature Control, Print Intelligence detects anomalies in real time and automatically masks the affected area, preventing print failures and maximizing part yield without sacrificing the rest of the build.
Best-in-class accuracy, repeatability, and yield
Dimensional Accuracy and Repeatability Study
Fuse X1 holds ±0.26–0.33 mm in X/Y and ±0.34–0.67 mm in Z at a process capability (Cpk) of 1.33 for features up to 80 mm. With no part-specific scaling, 93% of printed parts have all 18 measured dimensions within ±0.3 mm or ±0.5%, whichever is larger. That’s a higher yield than both the HP Jet Fusion 5620 and the EOS P396.
The Power Behind the Fuse X1
An industrial workflow anyone can run. Install in an hour, start a print in five minutes.
Set up parts in PreForm and organize entire jobs, across builds, materials, and printers, in a single project file.
Quick-connect build chambers, automated powder loading, and no optics cleaning between prints. Hit print and walk away.
Move the build chamber straight into the Sift X1, where an integrated glovebox and compressed air make breakout fast, clean, and contained.
Automated cleaning and polishing in the Fuse Blast, with a 50% larger basket for bigger parts and easy removal for large-format work.
Use the Vacuum Transport System to load used and new powder into the Mix Kit and refresh the material for your next print, making the loading process just as easy.
Scalable and Affordable: Expand Your Fleet As Necessary, On-Demand
Get a complete Fuse X1 ecosystem at 3x lower cost than competitive systems. No facility retrofits, no special infrastructure: start printing parts on day one.
Add printers one at a time as demand grows. Each additional Fuse X1 unit costs 3–5x less than other SLS and MJF printers, so expanding your fleet won’t break the bank.
Low labor requirements, minimal material waste, and bulk powder pricing as low as $45/kg keep your cost per part down as volumes go up.
Fuse Sift X1
powder recovery reimagined.
Built for nonstop builds.
Fuse Blast
finished parts in 15 minutes.
Fully automated cleaning and polishing solution.
Produce end-use finished parts in minutes with fully automated cleaning and polishing.
Deliver clean-to-the-touch parts thanks to the in-line ionizer that prevents dust and media from re-settling on your parts and get a smooth, semi-gloss, and dye-ready surface finish with the Fuse Blast Polishing System.
Performance end-use thermoplastic materials, now available for 50% lower part cost.
Fuse X1
High Performance Industrial 3D Printer
Laser Type:
120 Watt Fiber Laser
Build Volume:
330 × 330 × 565 mm / 61.5L
Throughput:
.330 Kg/Hr
Footprint:
1.3 m²
12.2 Sq.Ft
Print Environment:
Nitrogen
Materials:
Nylon 12, Nylon 11*, Nylon 12 GF**, TPU 90A Powder**, or any 1064 nm powder with Open Material Mode.
*Available in Q1 2027
**Available in Q2 2027
Price:
Hardware starting at $84,999, full ecosystem from $172,996
Fuse 1+
High Performance Benchtop SLS 3D Printer
Laser Type:
30 Watt Fiber Laser
Build Volume:
165 x 165 x 300 mm / 8.2L
Throughput:
.063 Kg/Hr
Footprint:
0.4 m²
4.8 Sq.Ft
Print Environment:
Air and Nitrogen
Materials:
Nylon 12, Nylon 12 Tough, Nylon 12 White, Nylon 11, Nylon 12 GF, Nylon 11 CF, and TPU 90A Powders, or any 1064 nm powder with Open Material Mode.
The FUSE X1 Ecosystem
Complete Your 3D Printing Experience
