Recommended print settings for True Cast Resin on third-party printers
True Cast Resin is compatible with most third-party resin 3D printers. Formlabs recommends using the recommended print settings for these printers for improved printing and casting success.
Print setting file downloads
PrinterSlicing software
ChituboxLychee
AnyCubic Photon D2Download CFGX fileDownload LYR file
Elegoo Mars 2 ProDownload CFGX fileDownload LYR file
Elegoo Mars 3 ProDownload CFGX fileDownload LYR file
Elegoo Mars 4 UltraDownload CFGX fileDownload LYR file
Elegoo Mars 5 UltraDownload CFGX fileDownload LYR file
Elegoo Saturn 3 UltraDownload CFGX fileDownload LYR file
Elegoo Saturn 4 UltraDownload CFGX fileDownload LYR file
Elegoo Saturn 4 Ultra 16KDownload CFGX fileDownload LYR file
Phrozen Sonic Mini 8KDownload CFGX fileDownload LYR file
Phrozen Sonic Mini 8K SDownload CFGX fileDownload LYR file
Table of print settings
Printer Layer Height Bottom Layer Exposure Time (s) Bottom Layer Count Bottom Layer Lift Distance (mm) Bottom Layer Lift Speed (mm/min) Bottom Layer Retract Distance (mm) Bottom Layer Retract Speed (mm/min) Bottom Rest Time After Retract (s) Bottom Rest Time Before Lift (s) Transition Layers Transition Layer Type Standard Layer Exposure Time (s) Standard Layer Lift Distance (mm) Standard Layer Lift Speed (mm/min) Standard Layer Retract Distance (mm) Standard Layer Retract Speed (mm/min) Standard Rest Time After Retract (s) Standard Rest Time Before Lift (s) Internal OBO External OBO
AnyCubic Photon D2 30 μm 35 5 1 + 4 50 + 200 4 + 1 200 + 50 0.5 0.2 5 Linear 7.2 1 + 4 50 + 200 4 + 1 200 + 50 0.2 0.2 0 0.05
Elegoo Mars 2 Pro 30 μm 26 15 1 + 4 25 + 100 4 + 1 100 + 25 0.5 0.2 0 N/A 6.8 1 + 3 50 + 150 4 + 1 150 + 50 0.2 0.2 -0.05 0.05
Elegoo Mars 3 Pro 30 μm 35 10 1 + 3 30 + 150 3 + 1 150 + 30 0.5 0.2 5 Linear 7.4 1 + 3 50 + 150 3 + 1 150 + 50 0.2 0.2 -0.035 0
Elegoo Mars 4 Ultra 30 μm 30 10 1 + 3 80 + 180 3 + 1 180 + 80 0.5 0.2 5 Linear 6 1 + 3 80 + 180 3 + 1 180 + 80 0.2 0.2 -0.03 -0.03
Elegoo Mars 5 Ultra 30 μm 28 10 N/A N/A N/A N/A 0.5 0.2 5 Linear 6 N/A N/A N/A N/A 0.2 0.2 -0.03 -0.03
Elegoo Saturn 3 Ultra 30 μm 40 10 2 + 4 60 + 180 4 + 2 180 + 60 0.5 0.2 5 Linear 7.4 2 + 4 60 + 180 4 + 2 180 + 60 0.2 0.2 -0.03 -0.03
Elegoo Saturn 4 Ultra 30 μm 28 10 N/A N/A N/A N/A 0.5 0.2 5 Linear 6.8 N/A N/A N/A N/A 0.2 0.2 -0.03 -0.03
Elegoo Saturn 4 Ultra 16K 30 μm 33 10 N/A N/A N/A N/A 0.5 0.2 5 Linear 7.5 N/A N/A N/A N/A 0.2 0.2 -0.03 -0.03
Phrozen Sonic Mini 8K 30 μm 28 10 2 + 3 30 + 150 3 + 2 150 + 30 0.5 0.2 0 Linear 7.8 2 + 3 60 + 150 3 + 2 150 + 60 0.2 0.2 -0.02 -0.04
Phrozen Sonic Mini 8K S 30 μm 28 10 1 + 4 30 + 150 4 + 1 150 + 30 0.5 0.2 5 Linear 7.8 1 + 4 30 + 150 4 + 1 150 + 30 0.2 0.2 -0.02 -0.04
