Welcome to the Form 3 Series Training
Congratulations on your new Form 3 Series printer! Learn everything you need to get up and running quickly and successfully with your printer through our training videos and support articles.
To get started, create a Dashboard account to prepare to register your printer after it is unboxed and set up. Dashboard allows you to remotely monitor your prints and printers, track material usage, and explore past and future Formlabs purchases. For detailed instructions, refer to our support article.
1. Preparing Your Space
Before receiving your printer, watch an expert outline how to prepare your space so you’re ready to install and operate your printer once it arrives, and house the necessary accessories and consumables.
This video only covers the Form 3/B+ printers.  For the Form 3L/3BL, check out our support article.
2. Receiving and Unboxing Your Printer
Know what to expect when your printer arrives. Package contents, unboxing, and how to locate your printer’s serial name are all detailed in the unboxing videos below and support articles for Form 3/B+ and Form 3L/BL.
Check out this video for additional information on how to unbox and set up your Form Wash or this video for Form Cure.
3. Setting up Your Form 3/B/L
Check out our support articles for Form 3/B+ and Form 3L/BL and the video to learn how to turn the printer on and insert the resin tank, build platform, and resin cartridge.
4. Starting a Print With PreForm
If you haven’t already, download PreForm, Formlabs' print preparation software. Check out our support article and the video to learn the basics of how to orient and support your model and send your print job from PreForm to your printer.
 If you want to take the pressure off your first print, start with our provided part. We’ve tested this part to make sure it prints well, giving you a chance to familiarize yourself with how your printer works before jumping into more complex prints.
5. Post-Processing Your Print
Once your print is complete, it needs to go through a few post-processing steps to look and perform its best. Check out our support article and the video to learn how to remove parts from the printer, wash your parts, clean your build platform, remove supports, and post-cure your parts.
6. Maintaining the Form 3/B/L
The Form 3/B/L is a very low-maintenance machine. While there is some preventative maintenance, such as keeping software and firmware up to date, most maintenance steps will be performed when dictated by certain print events. Listen to an expert from our Services team explain the most important maintenance steps in this video.
Below you can also find the support documentation for the most common maintenance steps:
7. Advancing Your PreForm Skills
Watch the video to hear an expert walk through the different types of PreForm warnings, tools for support editing, and best practices for setting up a print.
Additionally, check out our blog post to learn more about PreForm warnings/how to adjust, optimizing support generation/placement, and raft printing vs printing directly on the Build Platform.
