Finalizing a print job in PreForm with One-Click Print
When orienting and supporting a model, keep in mind that a model has several correct orientations. Clicking One-Click Print shifts models between these different orientations and supports them accordingly.
To orient and support a model with One-Click Print in PreForm:
  1. Click the button. The Job Info dialog box opens.
  2. Click the name of a Printer. The Job Setup window opens.
  3. Scroll down to the Choose Material section. Hover your cursor over your desired material to view the available versions for that material type. Click to select a material and version.
  4. Scroll down to the Choose Layer Thickness section. Click to select a layer thickness.
  5. Click Apply. The selected material and layer thickness settings are applied.
  6. Click the One-Click Print icon. The One-Click Print dialog box opens.
  7. Click Set up your print. The model is oriented and supported, then the Print window opens.
  8. Click the Job Name field. Enter a new name or view the existing name.
  9. Click Upload Job. The model is sent to the printer.
Note:
A single Job may include multiple models. The Job Name identifies a print job on your printer’s touchscreen and in Dashboard.
