Painting prints
Required resources:
  • Spraypaint
  • Drill
  • Dowel
  • Wood block
  • Nail buffing sticks
  • Fiber backed polishing paper
  • Tack cloth
  • Masking tape
  • Spray clearcoat
  • Safety equipment: gloves and mask
Step 1: Mount the primed part
Drill a starter hole in an inconspicuous spot and mount the primed part on a thin dowel. Insert the dowel into the wood block.
alt text
Step 2: Polish the surface
Gently polish the surface with the nail buffing sticks, starting with the "buff" side and finishing with the "polish" side until the surface is glossy.
alt text
Step 3: Remove dust
Run a tack cloth over the surface to remove dust.
alt text
Step 4: Stir the paint
Gently swirl the can for 2 to 3 minutes. Avoid shaking the can to prevent bubbly paint.
alt text
Step 5: Spray on the undercoat
Always start and end your spray off the model. Keep the nozzle 6 inches away and move quickly across the surface while rotating the model. Let the model dry for 20 to 30 minutes between layers. Apply two to three layers.
alt text
TIP:
Polish between layers with the finest sanding paper and a polishing stick for a glossy finish.
Step 6: Mask areas you want to keep in the undercoat
Cut the masking tape with scissors or a hobby knife. Apply the tape firmly. Press down on the edges to keep paint from seeping underneath.
alt text
Step 7: Apply the topcoat (optional)
A contrasting topcoat can create rich gradients. One or two light topcoats is enough.
alt text
Step 8: Finish with the clearcoat
Apply one or two thin layers of clearcoat.
alt text
