Choosing an Uninterruptible Power Supply (UPS) for your Formlabs printer
Formlabs 3D printers require power throughout a print. If power is lost or interrupted, any prints in progress cannot be resumed and the print will fail. Some printers are more sensitive to power fluctuations and signal cleanliness than others. As a result, Formlabs recommends customers purchase an uninterruptible power supply (UPS) to ensure that their prints do not fail due to power issues.
When choosing a UPS, consider how many printers you are planning to run with it and how long you want it to last in the event of a power outage. Use a UPS runtime calculator like this one to see how much capacity your UPS needs in order to power your printers for a certain period of time.
Tip:
When calculating UPS capacity, use the peak usage numbers from the table below so your printers stay on during a blackout even when drawing maximum power.
Pure sine wave
Some electronics require pure sine wave output from a UPS. Usually, a UPS that offers this is more expensive.
PrinterPure sine wave output
Form 2Not required
Form 3 generationNot required
Form 3L generationNot required
Form 4 generationNot required
Form 4L generationNot required
Fuse 1 generation*Required
* For specific recommendations, read Formlabs approved distributors for supplies (SLS).
Estimated power requirements
PrinterNormal usagePeak usage
Form 250 W100 W
Form 3 generation100 W200 W
Form 3L generation400 W600 W
Form 4 generation150–250 W480 W
Form 4L generation250–350 W900 W
Fuse 1 generation*700 W1650 W
