Formlabs-approved distributors for supplies (SLS)
The Fuse 1, Fuse Sift, and Fuse Blast need regular maintenance to ensure full functionality. Some maintenance tasks require supplies that are not available for sale at formlabs.com but can be acquired through an external seller. In addition to maintenance, a range of tools and miscellaneous items can be purchased from external suppliers to ease your SLS workflow.
Before maintaining your Fuse ecosystem, check the required resources in the corresponding support article and ensure you have all required supplies at your disposal. For more information about approved distributors in your region, please contact your local certified service provider.
Do not use swabs, pre-moistened or dry wipes, surfactants, denaturants, or any other tool, chemical, or cleaning agent to maintain the Fuse 1's optical components that are not explicitly recommended by Formlabs or a certified service provider.
Tip:
Visit the following support articles to learn more about which maintenance procedure requires which supplies:
ItemSupplierPriceNotes
nTopnTopCall nTop for pricenTop is the leading computational design software for developing high-performance parts quickly and efficiently. Get dramatically better products to market sooner with nTop by using data to automate design exploration and optimization. By seamlessly fitting into established workflows and integrating with existing design, analysis, and simulation tools, nTop makes it easy to share design knowledge, accelerate iteration, and drive innovation faster than ever before.
GrasshopperRhino 6
Grasshopper
USD 995
Free
Most ubiquitous topOp software, exists exclusively as a plug-in for Rhino.
Fusion 360 Generative Design ExtensionAutodeskUSD 4K/year + USD 495/yearAutodesk’s extension for F360, user-defined desired performance metrics to generate designs that incorporate topOp into results. Basically topOp + AI = 24 proposed designs.
Materialise MagicsMaterialiseUSD 20K per licenseAM process software that sits in-between CAD and output in a workflow. Generates optimal supports based on per part FEA, relative to the AM process; optimised pack/orientation, etc.
Knowledge resources
Design specifications for 3D models (Fuse 1)FormlabsFree
3D Hubs SLS Design Guide3D HubsFreeComprehensive design guide covering minimum features, things to avoid/be cautious of, example applications. Formlabs beta customers report designs printed with advice derived from this guide came out exceptionally well.
3D Hubs SLS Post-Processing Guide3D HubsFreeSame format as their design guide but covers various post-processing techniques that are applicable to SLS-printed parts.
North America
Consumables (NA)
Item Region Supplier Notes
Nitrile gloves,
non-reactive
USA McMaster-Carr
PEC*PADs USA B&H
Manufacturer: Photographic Solutions
Polyester cloth swabs,
TX714A
USA SOS Cleanroom
Alconox,
1104-1
USA McMaster-Carr
Manufacturer: Alconox
Distilled water USA McMaster-Carr
Manufacturer: PTI Process Chemicals
Ethyl alcohol,
laboratory-grade
USA McMaster-Carr
Ethyl alcohol,
laboratory-grade
Canada E-nrg
Glass blasting media USA Grainger 212–300 µm / 50–70 mesh size, compatible with Fuse Blast
Glass blasting media USA Blast-It-All 50–70 mesh size, compatible with Fuse Blast
Glass blasting media USA Amazon 40–50 grit / 313–387 μm, compatible with Fuse Blast
Delfin vacuum bags USA Delfin Anti-Static “M” filter safe bag replacement
Formlabs Powder-Safe Vacuum filters North America Festool Replacement main filter for Formlabs Powder-Safe Vacuum
Formlabs Powder-safe Vacuum bags North America Festool Replacement bags for Formlabs Powder-Safe Vacuum
Tools (NA)
Dremel Versa Power Scrubber Kit USA Dremel Powered rotating brush, useful for removing the bulk of loose powder from parts. Dremel lists it as “waterproof” but does not supply an IP rating.
Eastwood Elite QST 30/60 Scroll Air Compressor with Quiet Technology USA Eastwood Air compressor compatible for use with the Fuse Blast Requires 220–240 V outlet.
Fittings for Eastwood air compressor USA
  1. 3/8” NPT female to ¼” industrial quick disconnect hose socket for air (1x)
  2. ½” male to ⅜” female NPT reducer (1x)
  3. EPDM air hose, ⅜ NPT male (1x)
  4. Compressed air filter (1x, if applicable)
  5. Pressure regulator (1x, if applicable)
Manufacturer: McMaster-Carr
For full instructions, see Setting up a compressed air supply for the Fuse Blast. Recommended fittings are for connecting the recommended air compressor to the Fuse Blast. Use thread sealant as needed to ensure airtight seal.
This configuration allows for blasting at 30 psi using the 4 mm orifice or at 60 psi with the 3 mm orifice.
A compressed air filter is only required if your air compressor is not pre-equipped with a filter. Additional hoses are required if using a filter or regulator.
A pressure regulator is only required if supply is at or over 120 psi.
8 ft power cord
P034-008
NEMA 5-15P to IEC 320-C19
USA DigiKey Slightly longer power cord for the Fuse 1 and Fuse Sift if the included ones are too short.
Only acceptable for vacuums that draw 12 A or less.
120 V UPS USA Amazon
Manufacturer: APC
Recommended UPS for the Fuse 1. Lasts 20 minutes when power is cut during heat-up, or 45 minutes if power drops during a print.
Only suitable for 120 V Fuse 1 units.
Note:
APC makes a 230 V equivalent that is expected to work as well, but has not been tested by Formlabs.
120 V line conditioner USA Digi-Key
Manufacturer: Tripp Lite
Only necessary if specifically recommended by Formlabs Support or a certified service provider.
120 V online double conversion UPS USA CDW
Double conversion UPS with line conditioning. Only necessary if specifically recommended by Formlabs Support or a certified service provider.
Nitrogen generator USA Flairmo N2G 40
Manufacturer: Flairmo
Recommended for the Fuse X1.
Different fleet sizes require different nitrogen generators.
Nitrogen generator USA Flairmo N2G 15C
Recommended for the Fuse 1+ 30W.
Nitrogen generator USA Holtec HSS-7
Manufacturer: Holtec Gas Systems
Requires treated, dry compressed air supply. Recommended for the Fuse 1+ 30W.
Different fleet sizes require different nitrogen generators. Formlabs recommends contacting Holtec Gas Systems if using more than one Fuse 1+ 30 W.
Fittings for Holtec nitrogen generator USA
  1. Quick disconnect hose coupling for air (1x)
  2. Quick disconnect hose socket for air (2x)
  3. EPDM air hose (2x; 3x if used with an external compressed air filter)
  5. Thread sealant tape
For connecting the recommended Holtec Gas Systems nitrogen generator to an air compressor and the Fuse 1+ 30W.
A compressed air filter is only required if your air compressor is not pre-equipped with a filter. Three air hoses are necessary if you are using an external compressed air filter.
Stirring rod USA Wood stirring paddle (or similar non-conductive tool)
For stirring powder in the printer or Fuse Sift hoppers. Recommended for materials such as TPU 90A Powder that are prone to clumping.
European Union
Consumables (EU)
Nitrile gloves,
non-reactive
DE Arbeitsschutz-Express
Manufacturer: Semperguard
PEC*PADs EU Calumet Photographic
TX714A
DE/AT Pure11
Manufacturer: Texwipe
TX715
DE/AT Pure11
TX714A
FR Conformat
TX714A
IT AM Instruments
TX714A
ES Vestilab
[email protected]
Alconox,
1104-1
DE Sigma-Aldrich Chemie
Distilled water DE/AT Medicalcorner24
Ethyl alcohol,
purum
DE/AT/FR/NL Höfer Chemie
Glass blasting media DE Schicker Mineral 200–300 µm nominal average range, compatible with the Fuse Blast
Glass blasting media EU Amazon 40–50 grit / 313–387 μm, compatible with Fuse Blast
Vacuum bags EU Delfin Anti-Static “M” filter safe bag replacement
Tools (EU)
Dremel Versa (PC10-1/10) EU Dremel Powered rotating brush, useful for removing the bulk of loose powder from parts. Dremel lists it as “waterproof” but does not supply an IP rating.
2,44 m power cord
P050-008
CEE 7/7 to IEC 320-C19
EU Digi-Key
2 m power cord C14 to C19
IEC-60320-C14 to IEC 60320-C19
DE/AT Amazon
Manufacturer: FSKE
Power cord for power conditioner.
250 V, 16 A
Power conditioner EU Thomann
Manufacturer: Furman
Power conditioner for 230 V units.
230 V UPS DE / AT / FR / ES Bechtle
Manufacturer: APC
Only suitable for 230 V Fuse 1 units.
230 V online double conversion UPS DE / AT / FR / ES Tripp Lite Double conversion UPS with line conditioning. Only necessary if specifically recommended by Formlabs Support or a certified service provider.
Nitrogen generator EU DWT Mini 5-50
Manufacturer: DWT GmbH
Nitrogen generator EU Flairmo N2G 40
Nitrogen generator EU Flairmo N2G 15C
Nitrogen generator EU Holtec HSS-7
Adapter for Fuse Blast EU Compressed air coupling NW 7,2 to G3/8” thread adapter European standard adapter required if not possible to find fittings compatible with the Fuse Blast’s ¼” quick connect.
Fittings for Holtec nitrogen generator EU
Stirring rod EU Wood stirring paddle (or similar non-conductive tool)
Switzerland
Consumables (CH)
Nitrile gloves,
non-reactive,
blue
CH AcuMax
Manufacturer: MaiMed
Nitrile gloves,
non-reactive,
black
CH AcuMax
Nitrile gloves,
non-reactive,
blue
CH AcuMax
PEC*PADs CH ars-imago
TX714A
CH Pure11
TX715
CH Pure11
Alconox,
1104-1
CH Fisher Scientific
Alconox,
1104-1
CH Sigma-Aldrich Chemie
Distilled water CH Medicalcorner24
Ethyl alcohol,
purum, ~96%,
02890
Ethyl alcohol,
purum, ~96%,
02857
Glass blasting media CH iepco 125–250 µm nominal average range
Vacuum bags CH Delfin Anti-Static “M” filter safe bag replacement
Tools (CH)
Dremel Versa CH Dremel Powered rotating brush, useful for removing the bulk of loose powder from parts. Dremel lists it as “waterproof” but does not supply an IP rating.
2.44 m power cord
P050-008
CH Digi-Key
Power conditioner CH Thomann
230 V UPS CH Bechtle
Manufacturer: APC
Nitrogen generator CH DWT Mini 5-50
Nitrogen generator CH Flairmo N2G 40
Nitrogen generator CH Flairmo N2G 15C
Nitrogen generator CH Holtec HSS-7
Fittings for Holtec nitrogen generator CH
Stirring rod CH Wood stirring paddle (or similar non-conductive tool)
United Kingdom
Consumables (UK)
ItemRegionSupplierNotes
Nitrile gloves,
non-reactive,
black
UKBrosch Direct
Nitrile gloves,
non-reactive,
blue, extra strong
UKBrosch Direct
PEC*PADsUKCinestore
TX714A
UKFisher Scientific
Alconox,
1104-1
UKSigma-Aldrich Chemie
Distilled waterUKReAgent Chemicals
Ethyl alcohol,
purum
UKFisher Scientific
Glass blasting mediaUKKey AbrasivesAverage nominal range:
106–212 µm
150–250 µm
Glass blasting mediaUKAmazon40–50 grit / 313–387 μm, compatible with Fuse Blast
Vacuum bagsUKDelfinAnti-Static “M” filter safe bag replacement
Tools (UK)
Dremel Versa (PC10-1/10) UK Dremel Powered rotating brush, useful for removing the bulk of loose powder from parts. Dremel lists it as “waterproof” but does not supply an IP rating.
8 ft power cord
P052-008
BS1363A to IEC 320-C19
UK Digi-Key
Power conditioner UK Thomann
230 V UPS UK Bechtle
Manufacturer: APC
230 V online double conversion UPS UK Ballicom
Nitrogen generator UK DWT Mini 5-50
Nitrogen generator UK Flairmo N2G 40
Nitrogen generator UK Flairmo N2G 15C
Nitrogen generator UK Holtec HSS-7
Fittings for Holtec nitrogen generator UK
Stirring rod UK Wood stirring paddle (or similar non-conductive tool)
Japan
Tools (JP)
Step up/step down voltage transformer Japan Voltage Converter Transformers Voltage transformer for 120 V units in regions with 100 V mains electricity.
Nitrogen generator Japan Flairmo N2G 40
Nitrogen generator Japan Flairmo N2G 15C
