What is the largest part I can print on a Formlabs printer?
Form 4 and Form 4B
The Form 4 and Form 4B both have a build volume of 200 x 125 x 210 mm, or 7.9 x 4.9 x 8.3 inches (5.2 L).
Check the Form 4 design specifications before designing your part.
Form 4L and Form 4BL
The Form 4L and Form 4BL both have a build volume of 353 x 196 x 350 mm, or 13.9 x 7.7 x 13.8 inches (24.2 L).
Check the Form 4L design specifications before designing your part.
Form 3 and Form 3B
The Form 3 and Form 3B both have a build volume of 145 x 145 x 185 mm, or 5.7 x 5.7 x 7.3 inches.
Check the Form 3 design specifications before designing your part.
Form 3L and Form 3BL
The Form 3L and Form 3BL both have a build volume of 335 × 200 × 300 mm, or 13.2 × 7.9 × 11.8 inches.
Check the Form 3L design specifications before designing your model.
Fuse 1 and Fuse 1+
Due to varying thermal expansion rates for different materials, the largest parts size printable in the Fuse Series printers varies. The largest part sizes achievable are given in the table below:
| Material | Largest part size |
| Nylon 12 Powder | 159.8 × 159.8 × 295.5 mm |
| Nylon 12 GF Powder | 159.8 × 159.8 × 295.5 mm |
| Nylon 12 Tough Powder | 158.8 × 158.8 × 293.5 mm |
| Nylon 12 White Powder | 159.8 × 159.8 × 293.8 mm |
| Nylon 11 Powder | 158.6 × 158.6 × 294.4 mm |
| Nylon 11 CF Powder | 162.0 × 162.0 × 287.6 mm |
| TPU 90A Powder | 152.1 × 152.1 × 294.9 mm |
| Polypropylene Powder | 159.4 × 159.4 × 296.0 mm |
Check the design specifications for the Fuse 1 before designing your model.
