![3d printed snap fit enclosure printed on an SLA 3D printer](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2F8d%2F80%2F8d802096-20c3-4633-8fce-08d2cfbfcda9%2Fsnap_fit_enclosure-tough-herojpg__1354x0_q85_subsampling-2.jpg__1354x0_q85_subsampling-2.jpg&w=3840&q=75)
If you’re a product designer or an engineer, chances are you’ll need to make a custom enclosure at some point. This might be a simple container to keep small items organized or a fully functional 3D printed prototype to show stakeholders or test before moving to injection molding.
With CAD software and a desktop professional 3D printer, you can create a custom 3D printed snap-fit enclosure with interlocking parts in five easy steps.
![Stereolithography - Form 3 Resin 3D Printer](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2Fa6%2F12%2Fa612773a-879c-49e4-84e6-9060fb3f8b0b%2Fsla_small.jpg__1354x0_q85_subsampling-2.jpg&w=2048&q=75)
Introduction to 3D Printing With Desktop Stereolithography (SLA)
Looking for a resin 3D printer to realize your 3D models in high resolution? Download our white paper to learn how SLA printing works and why it's the most popular 3D printing process for creating models with incredible details.
![Form 3L Sample Part](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2Fa0%2F20%2Fa0205f3a-2bb2-4425-a667-3eadeba76be4%2Fsample.jpg__1354x0_q85_subsampling-2.jpg&w=1080&q=75)
Request a Free Sample Part
Step 1: Prepare Your Custom Enclosure Design
![Measure your electronic component (left). Begin your 3D model with basic boxes (right).](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2F54%2Ff6%2F54f6c6a1-44b3-4b8f-b303-ab2f0b4b909c%2Fsnapfit_1.jpg__1354x0_q85_subsampling-2.jpg&w=3840&q=75)
For this project, we’re going to make a case for a Pine 64, a single board computer (download the .STL file on Pinshape to follow along). This tutorial uses Solidworks because of its popularity in product design and engineering, but you can use a similar 3D design software.
First, use digital calipers or a ruler to measure your electronic component. We like to start enclosure designs by accurately reverse-engineering the PCB, measuring the board size, the location of mounting holes, and any ports or plugs that will need to be accessed through the enclosure. You might want to simply measure the overall maximum dimensions as a box, but it’s essential to know exactly where the main features are so that you can accommodate them. In Solidworks, reproduce these measurements as a grouping of basic boxes in a single part file.
Step 2: The Bottom Enclosure
In Solidworks, the enclosure is best designed as an assembly, with each half of the enclosure modeled as a separate part. Starting with the base half of the enclosure as a new part, the first important decision is to determine how much of a tolerance to have between the perimeter of the PCB and the enclosure. This depends on the 3D printing process you're planning to use to 3D print parts. SLA and SLS 3D printers are highly accurate, so you can tighten the tolerance to 0.5 mm without much risk.
A desktop FDM 3D printer may warp your design and lift it off of the print plate, so you should allow a larger tolerance of 1.5-2 mm to ensure that the PCB will still fit inside even if the walls are somewhat distorted.
Read our in-depth guide about FDM vs. SLA 3D printers to learn how they compare in terms of print quality, materials, applications, workflow, speed, costs, and more.
![3d printing snap fit - Add space between the perimeter of your electronic component and the enclosure (left). Build the walls of the bottom enclosure in your 3D model (right).](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2F25%2F35%2F25353dce-f67c-4b7a-a46e-363e0f6c7108%2Fsnapfit_2.jpg__1354x0_q85_subsampling-2.jpg&w=3840&q=75)
Our next step is to start cutting away the openings for the ports. One common mistake is that you will only cut away just enough material to expose the port connection, be it a USB or HDMI, without taking into account that many cables around the male connector can be quite bulky and need to reach into your enclosure to connect to the port (especially if the port is set in from the edge of the PCB, farther away from the enclosure). So it’s best to be generous with the port openings. An extra 2 mm all the way around is a good starting point.
![3d printing snap fit - Add extruded cuts and cutouts to the bottom enclosure to fit ports.](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2F06%2F2d%2F062d39e6-92dc-4871-a660-679691512115%2Fsnapfit_3.jpg__1354x0_q85_subsampling-2.jpg&w=3840&q=75)
As you can see in the image above, we included extruded cuts, which go all the way from the top, and one cutout for a Micro SD card. The reason that some of the cuts reach the top is that the ports on the board stick out beyond the edge of the PCB, so in order to fit the PCB, we need to allow room for them to slide down. We will close some of these off with our top enclosure part, but you could choose to create a larger bottom enclosure so that the entire PCB and ports fit inside. Just be aware that you will have to push your connecting cables further inside the enclosure.
Step 3: The Top Enclosure
![3d printing snap fit - In general, the top enclosure mirrors the geometry of the bottom enclosure.](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2F97%2F0d%2F970dff24-38bf-4dc6-b858-5c6c3d050f84%2Fsnapfit_4.jpg__1354x0_q85_subsampling-2.jpg&w=3840&q=75)
Now that you’ve completed the bottom enclosure, the top section is easy. The above image shows the effect of the parting line running around the perimeter between the two enclosure halves. The top enclosure has had the same treatment of cut details to accommodate some of the taller ports, as well as the addition of material to close off some of the gaps left by the bottom enclosure. We also added an optional sunken middle section.
![engineering fit](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2F72%2Fed%2F72ed7b6a-f143-40e3-b91d-e3b7c8ec2f0e%2Ffit.jpg__1354x0_q85_subsampling-2.jpg&w=1080&q=75)
Designing for proper tolerance and fit lowers post-processing time and ease of assembly, and reduces the material cost of iteration. Download our white paper to learn more about tolerance and fit in 3D printing designing functional 3D printed assemblies.
Step 4: Designing the Snap Fit Joint
![3d printing snap fit - With a basic internal cantilever snap, you can lengthen the amount of plastic engaging into the snap for a stronger lock.](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2F2e%2Fd8%2F2ed86f9b-c753-4abb-b5cc-aeb2e6edc4fe%2Fsnapfit_6.jpg__1354x0_q85_subsampling-2.jpg&w=3840&q=75)
There are many designs for snap-fit components, but we opted for a basic internal cantilever joint. Above you can see the main details for the snap-fit design, which is exactly the same on both sides (male and female parts) of the enclosure. Depending on the space you have to work with, you can lengthen the small protrusion engaging into the snap cavity to create a stronger lock. In our snap-fit assembly, it's only 1.2 mm, but 2 mm or more would be much more secure. In this particular design, the pins on the PCB take up a lot of room, so the lock is designed to just squeeze in while providing enough force to hold the enclosure together. The cantilever joint is extruded 20 mm long, which adds to the strength.
![3d printing snap fit - This sectioned exploded view shows the snap details on each side.](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2Fc7%2Fee%2Fc7ee92d2-54f4-4e47-9154-b4835fa0cc0d%2Fsnapfit_7.jpg__1354x0_q85_subsampling-2.jpg&w=3840&q=75)
Above you can see a sectioned exploded view of the snap details on the enclosure, along with the PCB showing the location of the pins (in black), which limit the size of the cantilever joint. Alternatively, instead of the snap cavity hiding inside of the bottom enclosure, you could cut this detail through to the outside, allowing your snap-fit joints to be longer.
![3d printing snap fit - Lugs are small extrusions that slide within the opposite enclosure to secure the two halves.](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2F3a%2F8c%2F3a8c6aae-237f-48ba-8c79-b95084f14d9e%2Fsnapfit_8.jpg__1354x0_q85_subsampling-2.jpg&w=3840&q=75)
Add lugs to your design to keep the two halves from sliding. Lugs are small extrusions that insert into the opposite enclosure. Because we created two snap-fit joints on opposite sides, you might need these on just the two blank sides. For this larger case, we put them in each corner. The material extrudes only 3 mm down, but this is enough to prevent movement on 3D printed interlocking parts.
![3d printing snap fit - This basic snap fit enclosure can be adapted for nearly any small electronic component.](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2Ff2%2Fe4%2Ff2e448e6-08dd-477b-9032-7a293962a25b%2Fsnapfit_9.jpg__1354x0_q85_subsampling-2.jpg&w=3840&q=75)
Step 5: Add Final Details To Your Enclosure
While this might be enough detail for your project, a few added features can bring your 3D printed enclosure to life. For this design, we extruded some text for the Pine 64 name and details like the SD card location. We included the Pine 64 logo as a visual feature, but also to provide ventilation on the top since these boards can heat up. Plus, these details reduce the amount of 3D print material used. Finally, a couple of grip details where the snap-fit joints are located helps indicate where to press your fingers to open the enclosure.
![3d printing snap fit - The final design includes unique features along with the snap fit enclosure, ready to be 3D printed.](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2F3e%2F93%2F3e9389a5-896c-49c1-bca2-916ab3a90a97%2Fsnapfit_10.jpg__1354x0_q85_subsampling-2.jpg&w=3840&q=75)
![Polyurethane Resins](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2F42%2Fa7%2F42a717ac-e28d-46dc-929e-bee318fa81fd%2Fpolyurethane-hero-image-red.jpeg__1354x0_q85_subsampling-2.jpg&w=2048&q=75)
Introducing Polyurethane Rigid Resins: Pushing the Limits of 3D Printing
Join our materials experts as they discuss how the incredible properties of PU Rigid Resins paired with the benefits of 3D printing are eliminating previous limitations of traditional polyurethane manufacturing. Take your 3D printed snap fit enclosures to the next level with two new, true polyurethane materials.
3D Print Your Snap-Fit Enclosure With SLA Printing
SLA 3D printing offers a wide variety of engineering materials for creating accurate 3D printed parts and prototypes and help you reduce costs, iterate faster, and bring better experiences to market.
Want to see what you can create with a SLA 3D printing? We’ll ship a free 3D printed sample part to your office.
![3d printing - Engineering parts - Formlabs](/_next/image/?url=https%3A%2F%2Fformlabs-media.formlabs.com%2Ffiler_public_thumbnails%2Ffiler_public%2Fdc%2F19%2Fdc19a0a5-1bbf-4acb-a76f-15d1069b89ed%2Feng_sample_promo.jpg__1354x0_q85_subsampling-2.jpg&w=3840&q=75)
