How many parts can I print with 1 liter of resin?
White Resin V5 architectural model sample
Rigid 4000 Resin impeller sample
"How long is a piece of string?" Depending on your print size, 1 liter of resin can print various quantities of models. For example, our White Resin V5 sample, an architectural model, measures roughly 74×57×17 mm and uses about 17 cubic centimeters (or 17 mL) of resin. One liter of resin could produce about 57 models! Our Rigid 4000 Resin sample, an impeller, measures roughly 22 mm in height and 46 mm in diameter. It uses 13 mL of resin, for about 76 parts per liter of resin.
PreForm estimates how much resin the model will use before your start each print.
