Release notes from the year 2019 and earlier are available to view. To find the most recent versions of PreForm, check the support article PreForm downloads and release notes.
Previous versions of PreForm are available for download, as well as a list of their associated changes.
PreForm 3.2.3 — December 19, 2019
PreForm 3.2.3 was a recommended update for Form 3B, Form 3, and Form 2 printers. This release improved print quality for Form 3 and Form 3B printers.
PreForm 3.2.2 — November 26, 2019
PreForm 3.2.2 was a recommended update for Form 3B, Form 3, and Form 2 printers. This release added new material settings and remote printing for Form 3B printers.
PreForm 3.2.1 — November 12, 2019
PreForm 3.2.1 was a recommended update for Form 3B, Form 3, and Form 2 printers. This release added new materials settings for Form 3 printers.
PreForm 3.2.0 — October 29, 2019
PreForm 3.2.0 was a recommended update for Form 3 and Form 2 printers. This release adds new Array and Remote Printing functionality, while also improving support settings.
PreForm 3.1.2 — October 11, 2019
PreForm 3.1.2 was a recommended update for Form 3 and Form 2 printers. This release improved layer thickness settings for existing materials.
PreForm 3.1.1 — September 19, 2019
PreForm 3.1.1 was a recommended update for Form 3 and Form 2 printers. This release improved layer thickness settings for existing materials.
PreForm 3.1.0 — September 12, 2019
PreForm 3.1.0 was a recommended update for Form 3 and Form 2 printers. This release improved support generation, view and camera controls, as well as the design of the Job Info panel and Supports dialog box.
PreForm 3.0.7 — August 29, 2019
PreForm 3.0.7 was a recommended update for Form 3 and Form 2 printers. This release added and improved layer thickness settings for multiple materials.
PreForm 3.0.6 — August 22, 2019
PreForm 3.0.6 was a recommended update for Form 3 and Form 2 printers. This release added and improved layer thickness settings for multiple materials.
PreForm 3.0.5 — August 15, 2019
PreForm 3.0.5 was a recommended update for Form 3 and Form 2 printers. This release improved layer thickness settings and the Layout feature.
PreForm 3.0.4 — August 8, 2019
PreForm 3.0.4 was a recommended update for Form 3 and Form 2 printers. This release improved layer thickness settings and early layer supports.
PreForm 3.0.3 — July 30, 2019
PreForm 3.0.3 was a recommended update for Form 3 and Form 2 printers. This release added support for additional materials.
PreForm 3.0.2 — July 3, 2019
PreForm 3.0.2 was a required update for Form 3 printers, and was a recommended update for Form 2 printers.
Note:
- This version of PreForm is compatible with Firmware 1.0.0 or later
- Large jobs of 400 MB or more may take an hour or longer to upload to the printer
- The Print Time feature is disabled for Form 3 printers
- The displayed print time on the touchscreen may take longer than the actual print time
PreForm 3.0.1 — April 17, 2019
PreForm 3.0.1 was a recommended update for Form 2 printers. This release improved how supports are generated for Flexible Resin and added adjustments for Denture Resin.
Note:
This version of PreForm is compatible with Firmware 1.19.11 or later
PreForm 3.0.0 — April 2, 2019
PreForm 3.0.0 was a recommended update for Form 2 printers. This release was the first to showcase a completely redesigned interface that makes model manipulation easy. New features included changing a model's raft type, the ability to create a mirror copy of a model, and a menu to view a printer's details. Several new materials were also released with this version.
PreForm 2.20.0 — March 12, 2019
PreForm 2.20.0 was a recommended update for Form 2 and Form 1+ printers. This release added features that improve dimensional accuracy and early layer unioning. Updates to existing features refined estimated print time and support structure settings.
Note:
Last supported version of PreForm for the Form 1/1+.
PreForm 2.19.3 — January 23, 2019
PreForm 2.19.3 was a recommended update. This release added further support for Elastic Resin.
PreForm 2.19.2 — January 8, 2019
PreForm 2.19.2 was a recommended update. This release added print settings for Elastic, Denture Teeth A2, and Denture Base LP.
PreForm 2.19.1 — December 6, 2018
PreForm 2.19.1 was a recommended update, adding print settings for High Temp Resin v2.
PreForm 2.19.0 — November 27, 2018
PreForm 2.19.0 was a recommended update, adding faster print settings for dental surgical guides, smaller support touchpoint sizes for highly detailed surfaces, Castable Wax Resin settings revised for dental casting and pressing, and some updates to large model handling.
PreForm 2.18.0 — October 3, 2018
PreForm 2.18.0 was a recommended update, adding several new features and several changes that focus on improving the efficiency and versatility of support structures.
PreForm 2.17.1 — August 7, 2018
PreForm 2.17.0 — July 10, 2018
Note:
Requires Firmware 1.18.4 or later.
PreForm 2.16.0 — May 14, 2018
Note:
Last 32-bit Windows PreForm version.
PreForm 2.15.1 — March 15, 2018
PreForm 2.15.0 — February 20, 2018
PreForm 2.14.1 — January 29, 2018
PreForm 2.14.0 — December 14, 2017
PreForm 2.13.1 — November 7, 2017
PreForm 2.13.0 — October 31, 2017
PreForm 2.12.3 — October 12, 2017
PreForm 2.12.2 — September 25, 2017
PreForm 2.12.1 — September 19, 2017
PreForm 2.12.0 — September 15, 2017
PreForm 2.11.3 — May 29, 2017
PreForm 2.11.2 — May 17, 2017
PreForm 2.11.1 — April 11, 2017
PreForm 2.11.0 — March 14, 2017
PreForm 2.10.3 — January 31, 2017
PreForm 2.10.2 — January 5, 2017
PreForm 2.10.1 — December 19, 2016
PreForm 2.10.0 — December 7, 2016
PreForm 2.9.1 — November 1, 2016
PreForm 2.9 — October 26, 2016
PreForm 2.8 — September 28, 2016
PreForm 2.7.1 — September 6, 2016
PreForm 2.7 — August 29, 2016
PreForm 2.6.1 — August 9, 2016
PreForm 2.6.0 — July 19, 2016
PreForm 2.5.0 — June 13, 2016
PreForm 2.4.1 — May 30, 2016
PreForm 2.4.0 — May 20, 2016
PreForm 2.3.3 — April 19, 2016
PreForm 2.3.2 — April 14, 2016
PreForm 2.3.1 — April 8, 2016
PreForm 2.3.0 — April 7, 2016
PreForm 2.2.1 — March 17, 2016
PreForm 2.2.0 — March 14, 2016
PreForm 2.1.0 — February 3, 2016
PreForm 2.0.2 — January 13, 2016
PreForm 2.0.1 — December 18, 2015
PreForm 2.0.0 — December 1, 2015
PreForm 1.9.2 — November 2, 2015
PreForm 1.9.1 — September 8, 2015
PreForm 1.9.0 — July 1, 2015
PreForm 1.8.2 — February 12, 2015
PreForm 1.8.1 — January 6, 2015
PreForm 1.8 — December 17, 2014
PreForm 1.7.1 — October 23, 2014
PreForm 1.7 — October 23, 2014
PreForm 1.6.1 — September 30, 2014
PreForm 1.6 — August 25, 2014
PreForm 1.5.2 — June 25, 2014
PreForm 1.5.1 — June 17, 2014
PreForm 1.5 — June 9, 2014
