Replacing a Form 3L leveling foot
The Form 3L has four adjustable feet that raise the printer off the work surface and allow it to be leveled before printing. If one or more of the leveling feet is damaged or missing, it may be difficult to keep the printer level. Unleveled printers may cause print failures.
Use this guide to replace a leveling foot on your Form 3L.
Required supplies:
  • Replacement leveling foot
  • Leveling disc
Third-party:
  • 13 mm nut driver or ratcheting socket wrench
  • Box cutter, knife, or other sharp tool capable of cutting through plastic drip tray
  • T8 or T10 Torx driver for accessing rear leveling feet
  • Nitrile gloves
  • Duct tape or other similar adhesive tape
Estimated time: 15–30 minutes
Preparing the workspace
Overview: Prepare the Form 3L and a dust-free workspace for replacing the leveling foot.
WARNING:
Remove the build platform first to avoid dripping resin onto the LPU or into the printer cavity.
Step 2: Remove the resin cartridges
Remove the resin cartridges and close the vent caps to prevent resin from dripping off the bite valves and into the printer.
Step 3: Remove and store the resin tank
Remove the resin tank, place it in the resin tank case, and cover it with its lid. Set the case and tank aside on a clean, flat surface.
NOTICE:
Step 4: Unplug the printer
Disconnect the power cable, Ethernet cable, and USB cable before continuing with maintenance. Do not perform maintenance on the printer while it is connected to power.
Step 5: Prepare the workspace
Accessing the leveling foot
Overview: Identify the leveling foot you wish to replace. Each leveling foot requires different access instructions. Proceed to the step that is most relevant for your repair needs and remove the leveling foot.
Step 1: Identify the leveling foot in need of replacement
