Required Supplies:
- Touchscreen ribbon cable
- 2.5 mm hex driver (included in the Form 4 tool caddy)
Third-party:
- Nitrile gloves
The touchscreen ribbon cable transfers data from the touchscreen assembly to the motherboard. If the touchscreen ribbon cable is malfunctioning or broken, the printer’s touchscreen may stop functioning.
Use this guide to replace the Form 4 touchscreen ribbon cable.
Required Supplies:
Third-party:
Estimated time: 20 minutes
Preparing the workspace
Overview: Prepare the Form 4 and workspace for replacing the touchscreen ribbon cable.
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 3: Remove and store the resin tank and mixer
Step 4: Prepare the workspace
Step 5: Clean the printer
Warning:
Open the printer cover and clean any resin pooled on and around the LPU with paper towels. Dampen the paper towels with isopropyl alcohol if necessary to fully remove the resin.
Danger:
Step 6: Unplug the printer
Danger:
Performing maintenance on the printer while it is plugged in increases the risk of electric shock. Never remove the printer panels while the printer is plugged in. Never reconnect the printer to power while the panels are uninstalled.
Removing the touchscreen assembly
Overview: Remove the touchscreen assembly from the printer.
Open the printer cover and slide the mixer base to the center of the LPU.
Use a 2.5 mm hex driver to remove the four screws securing the left panel to the printer. Set the left panel and the screws aside.
Use a 2.5 mm hex driver to remove the three screws securing the left side of the touchscreen assembly to the printer. Set the screws aside.
Use a 2.5 mm hex driver to remove the four screws securing the right panel to the printer. Set the right panel and the screws aside.
The touchscreen ribbon cable is retained with a latch. Rotate the black plastic tab on the connector away from the printer to unlatch the touchscreen ribbon cable from the motherboard. Do not pull on the touchscreen ribbon cable. Once the black tab is properly released, the cable slides out of the connector with minimal force.
Use a 2.5 mm hex driver to remove the three screws securing the right side of the touchscreen assembly to the printer. Set the screws aside.
Step 7: Loosen the bottom panel retention screws
Close the printer cover and carefully lay the printer on its back with the cover facing upwards. Use a 2.5 mm hex driver to loosen the two screws securing the bottom panel. Do not fully remove the screws.
Gently pull the bottom panel away from the printer to expose the two bottom tabs of the touchscreen assembly. If the tabs are not visible, loosen the two bottom panel screws further.
Grip the touchscreen assembly by its bottom corners. Carefully pull the touchscreen assembly towards you. The bottom of the touchscreen assembly fits snugly to the printer and may require extra force to remove. Set the touchscreen assembly aside.
Replacing the touchscreen ribbon cable
Overview: After removing the touchscreen assembly, remove and replace the touchscreen ribbon cable.
Step 1: Disconnect the touchscreen ribbon cable
Rotate the black plastic tab on the connector away from the touchscreen assembly to unlatch the touchscreen ribbon cable. Do not pull on the cable. Once the black tab is properly released, the cable slides out of the connector with minimal force. Set the cable aside for disposal.
Step 2: Connect the replacement cable
Slide the ribbon cable into the connector on the touchscreen assembly. Make sure the cable is inserted evenly. The blue mark should face upwards.
Step 3: Secure the replacement cable
Flip down the black tab on the connector to secure the cable to the touchscreen assembly. Take care not to pull on the cable during installation.
Reinstalling the touchscreen assembly
Overview: After replacing the touchscreen ribbon cable, reinstall the touchscreen assembly.
Step 1: Position the touchscreen assembly for installation
Position the touchscreen assembly on the printer. Make sure that the sheet metal tabs are positioned outside of the printer frame and that they align with the screw holes on the printer. Take care not to crush or fold the new touchscreen ribbon cable.
Step 2: Tighten the bottom panel screws
Make sure that the two bottom tabs of the touchscreen assembly can slide into the printer before tightening the screws. Use a 2.5 mm hex driver to tighten the two screws that secure the bottom panel to the printer.
Step 3: Set the printer upright
Rotate the printer to sit upright. Open the cover.
Use a 2.5 mm hex driver to install the three screws securing the right side of the touchscreen assembly to the printer. Tighten the screws until snug.
Reconnect to the touchscreen ribbon cable to the motherboard. Make sure it is inserted evenly. The blue mark should face outwards. Flip down the black tab on the connector to secure the cable to its connector. Take care not to pull on the cable during installation.
Use a 2.5 mm hex driver to install the four screws that secure the right panel to the printer. Tighten the screws until snug.
Use a 2.5 mm hex driver to install the three screws that secure the left side of the touchscreen assembly to the printer. Tighten the screws until snug.
Use a 2.5 mm hex driver to install the four screws that secure the left panel to the printer. Tighten the screws until snug.
Finalizing the repair
Overview: After replacing the touchscreen ribbon cable, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Test the touchscreen
The touchscreen should respond to touch inputs if the repair was successful. Test a variety of inputs, such as viewing the printer’s settings or exploring past prints via the print queue. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
