Replacing the Fuse 1 hopper trough RTD
The Fuse 1 uses multiple heaters to bring the powder up to the proper temperature for sintering. A faulty or malfunctioning resistance temperature detectors (RTD) on the hopper trough heater will prevent the printer from working properly.
Use this guide to replace the hopper trough heater RTD on a Fuse 1 printer. To replace this component on a Fuse 1+ 30W printer, see Replacing the Fuse 1+ 30W hopper trough heater RTD or heater.
Required supplies:
Third-party:
  • 2 mm hex driver (flat-end)
  • 6.5 mm slotted screwdriver
  • Telescoping magnet wand
  • Utility knife
  • Flush cutters
  • Safety glasses
  • Nonreactive nitrile gloves
  • N95 or better respirator
Estimated time: 45–60 minutes
Danger:
Warning:
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the hopper trough RTD.
Step 1: Prepare the workspace
Step 2: Unplug the printer
Danger:
Step 3: Remove the Wi-Fi antenna
Unscrew and remove the Wi-Fi antenna, if it is connected.
Removing the rear panels
Overview: Remove the rear panels to access the interior of the printer.
Step 1: Remove the lower rear panel screws
The six black lower rear panel screws are circled in red. The four chrome lower rear panel grounding screws are circled in blue.
Using a 2.5 mm hex driver, remove the six black panel screws and the four chrome panel grounding screws securing the lower rear panel to the printer. Set the screws aside, taking care to separate the black and chrome screws for later reinstallation.
Step 2: Remove the lower rear panel from the printer
Pull the lower rear panel straight back and away from the printer. Lay it down on a flat, clean surface.
Step 3: Locate the exhaust duct and ring clamp
Locate the ring clamp attached to the exhaust duct in the center of the printer.
Step 4: Loosen the ring clamp screw
Using a 6.5 mm flathead screwdriver, loosen the ring clamp screw. Do not remove the screw. Pull the exhaust duct away from the exhaust pipe.
Step 5: Locate the exhaust inlet
Open the filter cabinet door on the printer. Locate the exhaust inlet on the right side of the cabinet.
Step 6: Remove the exhaust inlet screws
Using a 2.0 mm hex driver, remove the four screws attaching the exhaust inlet to the filter cabinet. Set the screws aside.
Step 7: Remove the upper rear panel screws
The two black upper rear panel screws are circled in red. The two chrome upper rear panel grounding screws are circled in blue.
Using a 2.5 mm hex driver, remove the two black panel screws and two chrome panel grounding screws securing the upper rear panel to the printer. Set the screws aside, taking care to separate the black and chrome screws for later reinstallation.
Step 8: Remove the upper rear panel screws
Using a 2.5 mm hex driver, remove the eight screws securing the upper rear panel to the printer:
  • Two 6 mm screws on the buffer side of the printer
  • Four 6 mm screws on the top of the printer
  • Two 6 mm screws on the hopper side of the printer
Step 9: Remove the upper rear panel
Pull the upper rear panel straight back and away from the printer. Lay it down on a flat, clean surface.
Removing the original hopper trough RTD
Overview: Unplug and remove the original hopper trough RTD.
Step 1: Unplug the hopper trough RTD
Locate the connector on the hopper side of the printer labeled C012. Disconnect the connector.
Step 2: Remove the hopper trough RTD connector
Use a pair of flush cutters to cut the connector off of the original RTD cable.
Remove the original RTD
Make sure to cut the connector off of the RTD cable and not the extension cable that it attaches to.
Step 3: Locate the hopper trough RTD
Open the filter cabinet door, then manually open the print enclosure door by pulling the blue release handle. Locate the hopper trough RTD, positioned on the inner right-hand wall of the print enclosure underneath the hopper-side flipper trough.
Step 4: Remove the hopper trough RTD retention screw
Using a 2.5 mm hex driver, loosen and remove the 22 mm M3 socket head screw that secures the RTD to the trough. Set the screw aside.
Step 5: Remove the hopper trough RTD
Use a pair of flush cutters to cut the zip tie securing the RTD cable to the trough. Begin pulling the original RTD cable into the print enclosure so it clears the red silicone grommet, the two metal retention clips behind the trough, and the through-hole in the trough. Once the cable is free, remove the original RTD from the printer and set it aside for disposal with electronic waste.
Installing the replacement hopper trough RTD
Overview: Mount, secure, and plug in the replacement hopper trough RTD.
Step 1: Prepare the hopper trough RTD for installation
Unbox the replacement hopper trough RTD. Apply a piece of heat shrink tubing or tape to the end of the wires as shown. This makes it easier to feed the wires through the grommets without damaging them.
Install the new RTD
Step 2: Begin routing the hopper trough RTD cable
Install the new RTD
Install the new RTD
From inside the print enclosure, route the sheathed end of the new RTD cable through the trough through-hole, then the red silicone grommet. Do not feed the new RTD cable into the two metal retention clips identified previously.
Step 3: Continue routing the hopper trough RTD cable
Install the new RTD - View 1
Install the new RTD - View 2
From the back of the printer, locate the new RTD cable sticking out of the insulation panel. Route the cable through the red silicone grommet immediately below the hopper flipper motor.
Step 4: Mount and secure the hopper trough RTD
Inside the print enclosure, align the screw hole in the hopper trough RTD with the corresponding screw hole in the bottom of the trough. Thread the 22 mm M3 socket heat screw into the screw hole, then use a 2.5 mm hex driver tighten until snug.
Install the new RTD - Mounting the RTD
Step 5: Expose the heater trough RTD wires
Exposing the heater trough RTD wires - View 1
Exposing the heater trough RTD wires - View 2
Carefully remove the heat shrink tubing or tape from the end of the wires and expose the contacts. If the insulation on any of the individual wires is broken and the conductor is exposed, the RTD cannot be used.
Step 6: Reconnect the hopper trough RTD connector
Install the new RTD - Connector Diagram 1
Install the new RTD - Connector Diagram 2
Install the new RTD - Wire Detail 1
Install the new RTD - Wire Detail 2
Slide the crimped connectors into the new connector. Follow pin order shown here. Reconnect the hopper trough RTD to its extension cable, labeled C012.
Reinstalling the rear panels
Overview: After installing the replacement hopper trough RTD, reinstall and secure the rear panels.
Step 1: Align the upper rear panel with the printer
Lift the upper rear panel and align it with the four screw holes on the top of the printer.
Step 2: Secure the upper rear panel top screws
Thread the four 6.0 mm screws into each of the screw holes on the top of the printer. Using a 2.5 mm hex driver, tighten the screws until finger tight. You may need to adjust the exhaust duct to correctly position the upper rear panel.
Step 3: Secure the buffer side panel screws
Thread the two 6 mm screws into the screw holes on the buffer side and the two 6 mm screws into the screw holes on the hopper side. Using a 2.5 mm hex driver, tighten the screws until snug.
Step 4: Secure the hopper side panel screws
Thread the two 6mm screws into the holes on the hopper side. Using a 2.5 mm hex driver, tighten the screws until snug.
Step 5: Secure the upper rear panel grounding screws
Thread the panel screws into the indicated screw holes on the upper rear panel. Refer to the image for the correct locations of the black and chrome screws. Using a 2.5 mm hex driver, screw in the two black panel screws and two chrome grounding screws securing the upper rear panel to the printer.
The placement of the chrome screws is critical to the printer's electrical grounding. Incorrect placement may lead to printer damage.
Step 6: Slide the exhaust duct into position
Step 6: Slide the exhaust duct into position - View 2
Slide the end of the exhaust duct with the ring clamp back onto the exhaust pipe. Ensure the exhaust duct presses against the insulation panel.
Step 7: Tighten the exhaust duct ring clamp
Using a 6.5 mm flathead screwdriver, tighten the ring clamp until finger tight.
Step 8: Secure the exhaust inlet screws
Open the filter cabinet door on the printer. Thread the four 8.0 mm screws into the screw holes. Using a 2.0 mm hex driver, screw in the four exhaust duct screws until finger tight.
Step 9: Check the exhaust duct seal
To ensure there is no gap between the exhaust duct’s mounting plate and the filter cabinet housing, shine a flashlight or other light source around the exhaust inlet inside the filter cabinet. If any light is visible behind the filter cabinet, the duct is not properly sealed. If necessary, use a 2.0 mm hex driver to tighten the exhaust duct screws. Close the filter cabinet door when finished.
Step 10: Secure the lower rear panel grounding screws
Thread the panel screws into the indicated screw holes on the lower rear panel. Refer to the image for the correct locations of the black and chrome screws. Using a 2.5 mm hex driver, screw in the six black panel screws and four chrome panel grounding screws securing the lower rear panel to the printer.
Step 11: Reinstall the Wi-Fi antenna (optional)
Screw the Wi-Fi antenna onto the jack on the back of the unit.
Finalizing the repair
Step 1: Power on the printer
Step 2: Test the repair
Start a print. Monitor the printer to ensure that the print proceeds normally. Contact Formlabs Support or your certified service provider to share the results of the procedure.
