Note:
The corners of the Fuse 1 generation build chamber are rounded. In PreForm, the inner radius of the corner is 16 mm. As a result square part that fully spans the build chamber in the X and Y directions will not be printable.
Due to varying thermal expansion rates for different materials, the largest parts size printable in the Fuse Series printers varies. The largest part sizes achievable are given in the table below. The maximum achievable dimensions for each material are tuned for each new print setting release, so these dimensions may change over time. The best way to ensure that your part will fit in the build chamber is to test in PreForm.
Note:
| Material | Largest Part Size |
| Nylon 12 Powder | 160.2 × 160.2 × 297.3 mm |
| Nylon 12 GF Powder | 159.9 × 159.9 × 294.1 mm |
| Nylon 12 Tough Powder | 158.8 × 158.8 × 293.5 mm |
| Nylon 12 White Powder | 159.9 × 159.9 × 293.8 mm |
| Nylon 11 Powder | 158.3 × 158.3 × 295.0 mm |
| Nylon 11 CF Powder | 164.6 × 164.6 × 291.7 mm |
| TPU 90A Powder | 161.2 × 161.2 × 295.0 mm |
| Polypropylene Powder | 159.4 × 159.4 × 296.0 mm |
Tip:
Check the design specifications for the Fuse 1 before designing your model.
