Warning:
Do not look directly at the UV backlight while inspecting the printer optics.
If you experience print defects when using your Form Studio 1 printer, inspect the Backlight Unit and Light Processing Unit (LPU) to ensure they are functioning normally. Start by testing the Backlight Unit, then test the Backlight Unit and LPU together.
Warning:
Testing the Backlight Unit
To test the Backlight Unit in isolation:
Identifying issues by testing the Backlight Unit
Contact Formlabs Support for assistance.
Testing the Backlight Unit with the LPU
To test the Backlight Unit and LPU together:
Identifying issues by testing the Backlight Unit and LPU
If the sheet of paper does not appear uniformly lit or completely unlit during this test or you have questions about the results of these tests, contact Formlabs Support for assistance.
