Tip:
Check that the resin tank is in good condition between prints and before storing the resin tank in the tank case. Remove debris and clean the tank after a failed print.
Maintain and clean each resin tank using Formlabs instructions to maximize tank performance and to ensure consistent, high-quality prints over a tank’s lifetime. Only use approved materials and processes to clean the resin tank and film.
Tip:
Inspecting the resin tank
For the best results, inspect resin tanks regularly and, if necessary, clean them. Dirty optical surfaces and damage to the flexible film may cause print failures.
Required supplies:
Inspecting the resin tank interior
To inspect the resin tank interior:
Inspecting the resin tank exterior
To inspect the resin tank exterior:
Inspecting the tank frame
To inspect the tank frame:
Cleaning the resin tank
Keep the resin tank—especially the top and underside surfaces of the flexible film—clean and free of cured resin and other debris to ensure print quality and extend the lifetime of the printer.
Warning:
Resin and solvent may cause skin irritation or an allergic skin reaction. Wear gloves when handling liquid resin, resin-coated surfaces, or solvent. Wash skin with plenty of soap and water.
Required resources
Resin tank exterior:
Resin tank interior:
Tank frame:
Cleaning the resin tank interior
To clean the resin tank interior:
Cleaning the resin tank exterior
To clean the resin tank exterior:
Do not clean the inner surface of the flexible film (inside the resin tank) with isopropyl alcohol or any other solvent.
Do not allow liquid resin to become caught or to cure between the two layers of the flexible film. Resin trapped between the film layers renders the resin tank unusable.
Cleaning the tank frame
To clean the tank frame:
