Replacing the Form 4 Light Processing Unit fan
Form 4 LPU fan with pins
Required Supplies:
  • Light Processing Unit fan
  • Fan mounting hardware
  • 2.5 mm hex driver (included in the Form 4 tool caddy)
Third-party:
  • Nitrile gloves
  • Flush cutters or scissors
  • Needle nose pliers
The LPU fan cools the Form 4 optical system. Damage to the LPU fan may cause the optical system to overheat and prevent the printer from functioning properly.
Use this guide to replace the Form 4 LPU fan.
Estimated time: 45 minutes
Preparing the workspace
Overview: Prepare the Form 4 and workspace for replacing the LPU fan.
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 3: Remove and store the resin tank and mixer
Step 4: Prepare the workspace
Step 5: Clean the printer
Warning:
Open the printer cover and clean any resin pooled on and around the LPU with non-abrasive wipes. Dampen the wipes with isopropyl alcohol if necessary to fully remove the resin.
Danger:
Step 6: Unplug the printer
Danger:
Performing maintenance on the printer while it is plugged in increases the risk of electric shock. Never remove the printer panels while the printer is plugged in. Never reconnect the printer to power while the panels are uninstalled.
Removing the LPU fan
Overview: Remove the LPU fan from the printer.
Step 1: Remove the left panel retention screws
Remove the Form 4 left panel retention screws
Use a 2.5 mm hex driver to remove the four screws securing the left panel to the printer. Set the left panel and the screws aside.
Step 2: Rotate the printer
Form 4 LPU fan visible with printer on its right side
Rotate the printer onto its right side so the LPU fan is facing up.
Step 3: Disconnect the cable
Disconnecting the Form 4 LPU fan cable
Release the cable that connects to the LPU fan by pressing on the plastic tab on the connectors. Take care when unplugging the cable to avoid damage. Once the plastic tab is pressed, the cable easily slides from the connector. Do not pull on the wires.
Step 4: Remove the tape
Carefully removing the tape from the Form 4 LPU fan
The LPU fan is secured by tape. Carefully remove the tape from the LPU fan. Set the tape aside for reuse during installation.
Step 5: Remove the LPU fan
Gripping the Form 4 LPU fan to lift it out of the printer
Form 4 LPU fan removed from printer
The LPU fan is secured to the printer frame with three rubber pins. Grip the LPU fan and lift it out of the printer. If the LPU fan is difficult to remove or the rubber mounting pins become damaged during removal, proceed to the next section Optional: Replacing the fan mounting hardware.
Overview: Replace the fan mounting hardware to remove the LPU fan from the printer.
Step 1: Remove the Backlight Unit
To access the fan mounting hardware, the printer's backlight unit must be removed. To remove the backlight unit, follow the instructions in the repair guide Replacing the Form 4 Backlight Unit. Complete the steps in the section Removing the Backlight Unit.
Step 2: Locate the fan mounting hardware
Form 4 LPU fan mounting hardware location annotated
The fan mounting hardware consists of three rubber pins that mount the LPU fan in the printer.
Step 3: Remove the fan mounting hardware
Cutting the Form 4 LPU fan rubber mounting pins annotated
Use flush cutters or scissors to cut the three rubber mounting pins.
Step 4: Remove the fan mounting hardware and the LPU fan
Removing the Form 4 LPU fan and cut mounting hardware
Grip the LPU fan and remove it from the printer. Remove the cut pieces of the mounting pins from the printer. Set the cut pieces aside for disposal and the LPU fan aside for disposal with electronic waste.
Step 5: Install the lower fan mounting hardware
Inserting replacement rubber mounting pins into the lower holes
Lower replacement rubber mounting pins annotated
The lower fan mounting hardware consists of two rubber pins. Insert the replacement rubber mounting pins into the two lower holes in the sheet metal.
Step 6: Grip the upper mounting pin
Gripping the upper LPU fan mounting pin with needle nose pliers
The upper fan mounting hardware is a single rubber pin. Grip the rubber pin with a pair of needle nose pliers, leaving 5–10 mm of the pin visible above the pliers.
Step 7: Insert the mounting pin
Inserting the upper LPU fan mounting pin with pliers
Upper LPU fan mounting pin inserted and annotated
Use the pliers to insert the rubber pin into the bottom of the printer between the black plastic optics shroud and the sheet metal until the rubber pin pops through the upper fan mounting hole. Take care not to touch or damage any optical components in the printer.
Step 8: Position the mounting pin
Pulling the Form 4 upper LPU fan mounting pin fully into position
Using fingers or a second pair of pliers, pull the rubber pin fully into position.
Installing the LPU fan
Overview: Install the replacement LPU fan.
Step 1: Install the LPU fan
Placing the Form 4 replacement LPU fan in the printer
Aligning the three rubber pins with the holes in the LPU fan
Place the LPU fan in the printer. Align the three rubber pins with the holes in the fan.
Using needle nose pliers to pull LPU fan mounting pins into position
If the rubber mounting pins do not thread into the holes, use a pair of needle nose pliers to pull the pins into position. Push down on the fan until the fan is properly seated and the pins are fully seated in their holes.
Step 2: Reconnect the cable
Reconnecting the Form 4 LPU fan cable
Reconnect the cable that connects the LPU fan to the printer. The plastic tabs should click into place to secure the connection. Take care not to pull on the wires.
Step 3: Attach the tape
Reattaching the tape to the Form 4 LPU fan
Form 4 LPU fan with tape reattached
Reattach the tape to the LPU fan to secure it to the printer. Press firmly on the tape to adhere it to the fan and printer frame.
Step 4: Reinstall the Backlight Unit (Optional)
If you previously uninstalled the Backlight Unit to access the fan's rubber mounting pins, reinstall the Backlight Unit. Follow the instructions in the repair guide Replacing the Form 4 Backlight Unit. Complete the steps in the section Installing the replacement Backlight Unit.
Step 5: Mount the left panel
Place the left panel on the printer. Ensure that the screw holes in the panel align with those in the printer frame and that it sits flush with the touchscreen assembly and the back of the machine.
Step 6: Install the left panel screws
Installing the Form 4 left panel screws
Use a 2.5 mm hex driver to install the four screws that secure the left panel to the printer. Tighten the screws until snug.
Finalizing the repair
Overview: After installing the new LPU fan, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Run a test print
Insert any missing consumables and upload and start a print. Perform a small test print to ensure that the printer works normally. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
