Replacing the Fuse 1+ 30W doser assembly
In Fuse 1 generation printers, the doser controls the flow of powder from the hopper into the hopper trough before it is spread by the recoater. A faulty or malfunctioning doser will prevent the printer from printing normally.
Use this guide to replace the doser assembly on a Fuse 1+ 30W printer. To replace this component on a Fuse 1 printer, see Replacing the Fuse 1+ 30W doser assembly.
Fuse 1 doser assembly
Required supplies:
Third-party:
Estimated time: 45–60 minutes, plus time to empty the powder hopper and print the hopper vacuum attachment, if needed
Danger:
Warning:
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the doser assembly.
Step 1: Print the hopper vacuum attachment
If you have access to another 3D printer or your Fuse 1 generation printer can complete a print before servicing, print and post-process the hopper vacuum attachment. The STL file is available here.
Step 2: Prepare the workspace
Step 3: Empty the hopper
Insert an empty build chamber. Tap Settings > Calibration > Empty Hopper on the printer’s touchscreen. Follow the on-screen prompt on the Empty Hopper screen to transfer the powder from the hopper to the build chamber. This process may take up to an hour.
Step 4: Clean the hopper and powder troughs
Follow the instructions for cleaning the hopper and cleaning the powder troughs from the support article Cleaning all powder out of a Fuse 1 generation printer. You do not need to clean the other components of the printer to replace the doser assembly.
Step 5: Unplug the printer
Danger:
Removing the top panel
Overview: Remove the top panel to access the interior of the printer.
Step 1: Remove the top panel screws
Using a 2.5 mm hex driver, remove the 26 6 mm M4 countersunk screws securing the top panel to the printer:
Remove the top enclosure panel
  • Six 6 mm screws on the front end of the buffer-side
  • 12 6 mm screws on top of the printer
  • Eight 6 mm screws on the hopper-side
Set the screws aside.
Step 2: Remove the top panel
Lift the top panel off of the printer by grabbing the IR sensor door and the rear-most edge. Set the top panel aside.
Removing the hopper-side panel and hopper shell
Overview: Remove paneling on the hopper side of the printer to access the doser assembly.
Step 1: Begin removing the hopper-side panel screws
Using a 2.5 mm hex driver, loosen and remove the two black (circled in red) and one chrome (circled in blue) 8.0 mm M4 button head screws from the back-left of the printer. Take note of the locations of these screws, as the placement of the chrome screws is critical to the printer's electrical grounding. Set the screws aside.
Remove the top & hopper-side panels
Step 2: Continue removing the hopper-side panel screws
Move to the hopper side of the printer. Using a 2.5 mm hex driver, loosen and remove the 10 M4 countersunk screws holding the hopper-side panel to the printer. Remove the top-most 6.0 mm countersunk screws last to make removing the panel easier. Set the screws aside.
  • Three 16.0 mm screws, circled in green
  • Three 12.0 mm screws, circled in blue
  • Four 6.0 mm screws, circled in red
Step 3: Tilt the hopper-side panel
Allow the panel to tilt away from the printer, allowing access to the interlock switch cables. Do not remove the panel at this time.
Step 4: Disconnect the interlock switch and remove the hopper-side panel
Locate the black and red cables leading to the interlock switch on the inner left-hand side of the panel. Disconnect the cable labeled C033.
Separate the hopper-side panel from the printer, taking care to ensure that none of the cables are caught or tangled. Set the panel down on a flat, clean surface.
Step 5: Remove the inner door handle
Using a 2.0 mm hex driver, loosen and remove the four 10.0 mm M3 black countersunk screws holding the inner door handle to the printer. Remove the door handle and set it and the screws aside.
Step 6: Remove the hopper shell
Lift the hopper shell upwards then pull it away from the printer. Set the hopper shell and lid aside
Removing the hopper
Overview: Remove the hopper to access the doser assembly underneath.
Step 1: Disconnect the cables from the hopper
Locate and disconnect the connectors for the hopper LEDs and two powder sensors.
Remove the hopper
Step 2: Remove the hopper mounting screws
Remove the hopper
Remove the hopper
The hopper is secured to the printer using four 4 mm M3 chrome socket head screws: two on each side towards the bottom of the hopper. Using a 2.5 mm hex driver, loosen and remove the four screws. Set the screws aside.
Step 3: Remove the hopper
Tilt the hopper away from the printer and lift it off the doser.
Set the hopper down on the side opposite the window on a flat, clean surface. Do not set the hopper down on either of the gasketed ends or or the windowed side with the powder sensors, as these components may become damaged.
Remove the hopper
Removing the original doser assembly
Overview: Disconnect and remove the original doser assembly.
Step 1: Disconnect the doser cables
Disconnect the doser motor and encoder cables from the doser assembly.
Unplug the doser assembly cables
Step 2: Remove the doser assembly mounting screws
The doser assembly is secured to the printer frame by four 8 mm standoff nuts. There is a washer between each standoff nut and the doser assembly. Using an 8 mm nut driver, loosen and remove the standoff nuts. It may be helpful to use a telescoping magnet wand to catch and retrieve the washers; if they fall into the printer, they may be difficult or impossible to retrieve. Set the standoff nuts and washers aside.
If your nut driver cannot reach the nut on the top-right corner of the doser, try using an 8 mm box wrench instead.
Remove the original doser assembly
Step 3: Remove the doser assembly
Grab the doser assembly and pull it straight back from the printer. Set it aside for disposal.
Step 4: Clean the doser interface
Vacuum any powder that remains in the interface between the doser and the printer.
Dirty doser interface
Installing the replacement doser
Overview: Connect, mount, and secure the new doser assembly.
Step 1: Mount the doser assembly
Install the new doser
Align the two locating pins on the back of the doser assembly with the corresponding holes on the doser mounting surface. Slide the doser assembly into place until it sits flush against the printer frame.
Step 2: Secure the doser assembly
Thread the washers and standoff nuts into the four screw holes in the doser assembly. Using an 8 mm socket wrench or torque driver, torque each nut to 1.5 N-m in the sequence shown here.
Torquing the nuts out of order may lead to powder leaks. Over-torquing may strip the threaded stud, which is not repairable.
Step 3: Reconnect the doser motor and encoder cables
Connect the doser motor and encoder cables to the new doser assembly.
Calibrating the replacement doser
Overview: After replacing the doser assembly, calibrate its home position.
Step 1: Turn the printer on
Plug the power cable back into the rear panel then turn the printer on.
Step 2: Calibrate the doser
On the touchscreen, tap Settings > Calibration > Doser Calibration. Follow the on-screen. The printer will automatically find the correct home position for the new doser. The process typically takes up to 30 minutes to complete.
If any errors are encountered during calibration, follow any instructions provided on the touchscreen and re-run the calibration if necessary.
Step 3: Unplug the printer
Disconnect the power cable before continuing with maintenance. Do not continue performing maintenance on the printer while it is connected to power. Wait five minutes after disconnecting the printer from power before proceeding.
Reinstalling the hopper
Overview: After installing and calibrating the new doser assembly, reinstall the hopper.
Step 1: Check and clean the hopper gasket
Check that the bottom gasket of the hopper is free of debris, such as powder or pieces of insulation. Clean the gasket if necessary.
Step 2: Mount the hopper
Guide the hopper down onto the doser at a slight angle, then rotate it towards the printer. Check that the four screw holes in the hopper are aligned the corresponding screw holes in the printer frame.
Replace the hopper
Step 3: Secure the hopper
Replace the hopper
Replace the hopper
Thread one 4 mm M3 chrome socket head screw into each of the four screw holes in the hopper. Using a 2.5 mm hex driver, tighten the screws until snug.
Step 4: Reconnect the hopper cables
Reconnect the hopper LED board cable and the two powder sensor cables.
Replace the hopper
Reinstalling the hopper shell and hopper-side panel
Overview: After reinstalling the hopper, reinstall the paneling on the hopper side of the printer.
Step 1: Mount the hopper shell
Align the hopper shell with the hopper, then slide it down into place.
Replace the top & hopper-side panels
Step 2: Mount and secure the inner door handle
Align the four screw holes in the inner door handle with the corresponding screw holes on the front edge of the hopper side of the printer. Thread one 10.0 mm M3 black countersunk screw into each of the four screw holes, then use a 2.0 mm hex driver to tighten until snug.
Step 3: Reconnect the interlock switch cable
Align the bottom of the hopper-side panel to the bottom of the printer and allow it to lean against you. Reconnect the interlock switch cable, labeled C033, to its receptacle. If necessary, tuck the interlock cable slack into the side of the printer’s frame.
Step 4: Begin securing the hopper-side panel
Thread one M4 countersunk screw into each of the 10 screw holes in the hopper-side panel. Using a 2.5 mm hex driver, tighten until snug. For greatest convenience and ease of installation, thread and tighten in the following order:
  1. Four 6.0 mm screws below the hopper, circled in red
  2. Three 16.0 mm screws below the filter door, circled in green
  3. Three 12.0 mm screws above the filter door, circled in blue
Step 5: Continue securing the hopper-side panel
Thread the two black 8.0 mm M4 button head screws into the screw holes circled in red in the image here. Thread the chrome 8.0 mm M4 button head screw into the screw hole circle in blue here. Using a 2.5 mm hex driver, tighten until snug.
Reinstalling the top panel
Overview: After reinstalling the hopper-side paneling, reinstall and secure the top panel.
Step 1: Align the top panel
Lift the top panel and place it on top of the printer. Align the screw holes in the top panel with the corresponding holes in the printer frame.
Step 2: Secure the top panel screws
Thread a 6 mm M4 countersunk screw into each of the 18 marked screw holes in the top panel:
Finalizing the repair
Overview: After installing the replacement doser assembly, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Test the repair
Start a print. Monitor the printer to ensure that the print proceeds normally. Contact Formlabs Support or your certified service provider to share the results of the procedure.
