Overview: After installing the new mixer assembly, power on the Fuse Sift and calibrate the replacement part.
Step 1: Power on the Fuse Sift
Reconnect the Fuse Sift to its power source. Flip the power switch to the
ON
position.
Step 2: Calibrate the mixer
Ensure that the mixer is oriented so that the blue plastic clips are pointing upwards. Rotate the mixer if necessary. On the touchscreen, tap Maintenance > Calibrate Mixer. Follow the instructions on the UI to complete the calibration procedure.
For more details, see our support article on calibrating the Fuse Sift mixer.
Step 3: Test the mixer calibration
Insert a powder cartridge into the mixer and start a mix cycle. If the mixer stops with the cartridge in a horizontal position at the end of the cycle, the calibration was successful. If it stops at an angle, perform the mixer calibration procedure again.
If you encounter issues with the mixer calibration routine, contact Formlabs Support or your certified service provider.
