After selecting a preset, use the sliders or arrows on the touchscreen to modify the blast, rinse, or tumbler settings. When you modify an existing preset, the displayed name changes to Custom to reflect your changes.
The most important parameter to monitor is the cleanliness of your parts. Formlabs recommends starting with a Standard preset before modifying settings.
When modifying a blasting preset, keep the following in mind:
- Higher blasting pressures are not required to clean parts, except for parts printed in Nylon 12 GF Powder. Higher blasting pressures may damage delicate parts.
- When increasing the blasting or rinsing pressure, ensure that your compressed air source can still supply the required minimum flow rate.
- Higher blasting pressures shorten the life of your blasting media.
Changing the blast pressure setting
Changing the blast pressure affects how aggressive the media blasting and part rinse steps are. Formlabs recommends a blast pressure of 30 psi for blasting and 45 psi for the part rinse.
- Increasing the blast pressure can clean parts faster, but it requires a higher air supply. Higher pressures can also risk damaging delicate parts. Pressures higher than 30 psi / 2 bar are not required to achieve clean parts.
- Decreasing the blast pressure leads to a longer blast cycle, but requires less air flow. Formlabs recommends decreasing the blast pressure when using less powerful air compressors.
Changing the blast and rinse time settings
Compensate for lower or higher blasting pressure by changing the blast and rinse time settings.
- Longer blast cycles increase the likelihood that every surface on a part is exposed to the blast stream. Formlabs recommends increasing the blast cycle times for large parts or for those with complex geometries that tumble poorly.
- Shorter blast cycle times are sufficient for small builds or simple parts without many complex surfaces, holes, or cavities.
Changing the tumbler basket speed
Changing the tumbler basket speed (RPM) affects how often parts tumble throughout the cleaning process. The geometries of individual parts, the number of parts, and size and arrangement of parts all affect how parts tumble.
- A higher RPM causes parts to tumble more frequently, and typically with more impact. Formlabs recommends a higher RPM for small to medium-sized parts.
- A lower RPM causes parts to tumble less frequently, and typically with less impact. Formlabs recommends a lower RPM for large, complex, or delicate parts.
