Understanding print speed (Form 4L generation)
Form 4L generation printers deliver blazing fast print speeds with excellent reliability, print quality, accuracy, materials performance, and build volume size. Most MSLA printers sacrifice one or several aspects of print performance to achieve comparable speeds.
Print speed is mostly impacted by material and layer height and also by part geometry. The most accurate way to calculate the print time for your model is by using the Print Time estimation feature in PreForm, our free print preparation software.
How we measure and validate print speed
For Form 4L generation printers, we measure print speed in vertical height printed per hour, with units of millimeters per hour or inches per hour.
We rigorously validate the print speed, reliability, print quality, accuracy, and mechanical properties for every material and layer height available on Form 4L generation printers. For every material and layer height, we run roughly 100 prints across 40+ different printers, using 20+ unique models covering a range of key applications and part geometries. Then we inspect, measure, and test every one of those prints.
Print speed by material and layer height
This table shows median and typical print speeds by material, layer height, and print setting, as measured during the Formlabs validation process.
For a given material and layer height, the Typical Print Speed column shows 25th and 75th percentile print speeds measured during our validation process. This range represents the level of variation you might see based on part geometry for a given material and layer height.
Material
Layer Height
(µm)
Print Setting
Median Print Speed
Typical Print Speed,
25th - 75th percentile
Alumina 4N v1
50
Default
Alumina 4N v1
25
Default
BioMed Amber v1
100
Default
BioMed Amber v1
50
Default
BioMed Black v1
100
Default
BioMed Black v1
50
Default
BioMed Clear v1
100
Default
BioMed Clear v1
50
Default
BioMed Durable v1.1
100
Default
BioMed Elastic 50A v1
100
Default
BioMed Flex 80A v1
100
Default
BioMed Flex 80A v1
50
Default
BioMed White v1
100
Default
BioMed White v1
50
Default
Black v5
100
Default
21 mm/hr
0.8 in/hr
17-22 mm/hr
0.7-0.9 in/hr
Black v5
50
Default
13 mm/hr
0.5 in/hr
10-23 mm/hr
0.4-0.9 in/hr
Black v5
25
Default
Castable Wax 40 v1
50
Default
Castable Wax 40 v1
25
Default
Castable Wax v1
50
Default
Castable Wax v1
25
Default
Clear v5
100
Default
22 mm/hr
0.9 in/hr
16-25 mm/hr
0.6-1 in/hr
Clear v5
50
Default
11 mm/hr
0.4 in/hr
9-17 mm/hr
0.4-0.7 in/hr
Clear v5
25
Default
Color Base v1
100
Default
Color Base v1
50
Default
Color Base v1
25
Default
Custom Tray v1
100
Default
34 mm/hr
1.3 in/hr
29-39 mm/hr
1.1-1.5 in/hr
Dental LT Clear v2
100
Default
22 mm/hr
0.9 in/hr
14-25 mm/hr
0.6-1 in/hr
Dental LT Comfort v1.1
100
Default
26 mm/hr
1 in/hr
19-39 mm/hr
0.71.5 in/hr
Denture Base LP v1
50
Default
Denture Base OP v1
50
Default
Denture Base RP v1
50
Default
Durable v2.1
100
Default
20 mm/hr
0.8 in/hr
16-27 mm/hr
0.6-1.1 in/hr
Durable v2.1
50
Default
Elastic 50A v2
100
Default
ESD v1
100
Default
ESD v1
50
Default
Fast Model v1
160
Default
50 mm/hr
2 in/hr
49-59 mm/hr
2-2.3 in/hr
Fast Model v1
160
Fast Arch
Fast Model v1
100
Default
35 mm/hr
1.4 in/hr
25-41 mm/hr
1-1.6 in/hr
Fast Model v1
100
Fast Arch
Flame Retardant v1
100
Default
Flame Retardant v1
50
Default
Flexible 80A v1.1
100
Default
13 mm/hr
0.5 in/hr
10–17 mm/hr
0.4–0.7 in/hr
Flexible 80A v1.1
50
Default
Grey v5
100
Default
29 mm/hr
1.1 in/hr
24-32 mm/hr
0.9-1.3 in/hr
Grey v5
100
Fast Arch
Grey v5
50
Default
20 mm/hr
0.8 in/hr
17-21 mm/hr
0.7-0.8 in/hr
Grey v5
25
Default
High Temp v2
100
Default
High Temp v2
50
Default
IBT Flex v1
100
Default
IBT Flex v1
50
Default
Precision Model v1
50
Default
12 mm/hr
0.5 in/hr
8-17 mm/hr
0.3-0.7 in/hr
Precision Model v1
25
Default
Premium Teeth A2 v1
100
Default
Premium Teeth A2 v1
50
Default
Premium Teeth A3 v1
100
Default
Premium Teeth A3 v1
50
Default
Premium Teeth B1 v1
100
Default
Premium Teeth B1 v1
50
Default
Premium Teeth BL v1
100
Default
Premium Teeth BL v1
50
Default
PU Rigid 1000 v1
100
Default
PU Rigid 1000 v1
50
Default
PU Rigid 650 v1
100
Default
PU Rigid 650 v1
50
Default
Rigid 10k v1.1
100
Default
34 mm/hr
1.3 in/hr
29-39 mm/hr
1.1-1.5 in/hr
Rigid 10k v1.1
50
Default
Rigid 4000 v1
100
Default
20 mm/hr
0.8 in/hr
14-28 mm/hr
0.6-1.1 in/hr
Rigid 4000 v1
50
Default
Silicone 40A v1
100
Default
Surgical Guide v1
100
Default
22 mm/hr
0.9 in/hr
17-25 mm/hr
0.7-1in/hr
Surgical Guide v1
50
Default
Tough 1500 v1.1
100
Default
Tough 1500 v1.1
50
Default
Tough 2000 v1
100
Default
20 mm/hr
0.8 in/hr
15-23 mm/hr
0.6-0.9 in/hr
Tough 2000 v1
50
Default
White v5
100
Default
25 mm/hr
1 in/hr
18-28 mm/hr
0.7-1.1 in/hr
White v5
50
Default
19 mm/hr
0.7 in/hr
12-22 mm/hr
0.5-0.9 in/hr
For blank cells: we are still collecting data and will update this table when results are available.
How print speed works
On Form 4L generation printers, your expected print speed depends on three main factors:
  1. Material: every material has different curing and flow behavior, which impacts how long each step of the print process takes.
  2. Layer height: the thickness of each layer in your print. If you print the same part with 100 µm layer height and 50 µm layer height, the print with 50 µm layer thickness will have twice as many layers and take longer to print.
  3. Print geometry: When you’re printing with a given material and layer height, you may notice print speeds varying slightly depending on your print geometry. For print jobs with more parts or larger parts, each layer will have a larger cross-sectional area, which may slightly decrease print speeds.
There are four steps of the printing process that occur during every layer of your print. Each of these steps can take a varying amount of time depending on several factors.
StepWhat happens?What variables does the step time depend on?Why does the step time depend on these variables?
ExposeThe Backlight Unit and Light Processing Unit expose liquid resin in the resin tank with precise, powerful light. The liquid resin is cured into a solid layer.Material
Layer height
Different resins and layer heights have different curing behavior.
PeelA solid, cured layer is peeled from the bottom of the flexible film at the bottom of the resin tank. The printer uses its Z-axis force sensor to measure forces exerted on parts and to optimize the peel motion profile for low peel forces and fast print speeds.Print geometryWhen printing larger, chunkier models or more models, the printer may slightly reduce peel speeds to maintain low peel forces.
MixThe high speed mixer quickly remixes resin inside the tank to maintain homogeneity and a uniform temperature.MaterialMixing behavior depends on the flow behavior of a material.
Squish
The partially-complete print is lowered back into the resin tank. The print is squished in the liquid resin until there is one-layer-thickness of liquid resin between the print and flexible film.
The printer uses its Z-axis force sensor to measure forces exerted on parts and to optimize the peel motion profile for low peel forces and fast squish speeds.
Material
Layer height
Print geometry
When printing larger, chunkier models or more models, the printer may slightly reduce squish speeds to maintain low peel forces.
The squish step generally takes longer for smaller layer thicknesses.
How models with cups affect print speed
As noted above, print geometry impacts print speed. In particular, Form 4 and Form 4L generation printers slow down while printing hollow regions in parts, known as cups, to prevent print failures. To reduce this slowdown:
  • Use the Hole tool in PreForm to add drain holes to your model.
  • Create a custom print setting with the PreForm Print Settings Editor and deselect Cup Mitigation Enabled. Disabling this feature can reduce print times but may lead to print defects.
